Python Plugin: MqttMapper
FlyingDomotic
- Domoticz version: 2020.2
Re: Python Plugin: MqttMapper
Could you please copy here content of JSON configuration file?
rron
rron wrote: Sunday 11 January 2026 13:47 I made a new topic in the mapper config file the SOC for my car but the error in the domoticz log is"Error: Mapper: Can't find device key wican/amperae/SOC"
The wican module of my car gives in the mqtt explorer wican/amperae/SOC. I am on Version: 2025.2 (build 16836)
And the json file isCode: Select all
[}, "amperae State of Charge": { "topic": "wican/amperae/SOC", "type": "243", "subtype": "6", "switchtype": "0", "mapping": {"item": "", "multiplier": 0.1} /code] [/quote]
FlyingDomotic
There's a strange thing in the log. MqttMapper says it'll create "amperae State of Charge" and "amperae Hv Capacity" devices but it seems it don't. Going deeper, this message is show at each MqttMapper startup.
Would it be possible to have a look into Domoticz log, to see if "Device creation" is allowed in parameters ("Setup" > "Parameters")?
And check that devices are properly created in device list ("Setup" > "Devices"). If that's the case, check these 2 devices that they have been made available (arrow at end od line should be blue, to the left, and NOT green, to the right)?
rron
There is no item created in the device list alsoFlyingDomotic wrote: Monday 19 January 2026 9:44 There's a strange thing in the log. MqttMapper says it'll create "amperae State of Charge" and "amperae Hv Capacity" devices but it seems it don't. Going deeper, this message is show at each MqttMapper startup.
I do not see Device creation in the logging. I think that should be in the begining?
In the older mapper items like device 1-7 where created in a previous time, so the mapper is working.
FlyingDomotic
Is there any errors into Domoticz log related to these devices creation?
It's look like MqttMapper ask for device creation, but Domoticz don't do it. It normally should give some error messages somewhere.
Just a remark, not related to this issue: why creating a percentage device (243/6) as data seems to be a value, not a percentage?
rron
No there’s no error in domoticz log i will try to investigate this in the weekend. Perhaps the log level should be higher.
I will let you know what happens.
rron
This is the extended logging from domoticz. I cannot see anything weird in it.
2026-01-24 13:50:40.277 Status: Startup Path: /opt/domoticz/
2026-01-24 13:50:40.402 Sunrise: 08:33:00 SunSet: 17:11:00
2026-01-24 13:50:40.402 Day length: 08:38:00 Sun at south: 12:52:00
2026-01-24 13:50:40.402 Civil twilight start: 07:55:00 Civil twilight end: 17:50:00
2026-01-24 13:50:40.402 Nautical twilight start: 07:13:00 Nautical twilight end: 18:31:00
2026-01-24 13:50:40.402 Astronomical twilight start: 06:33:00 Astronomical twilight end: 19:12:00
2026-01-24 13:50:40.460 Status: PluginSystem: Started, Python version '3.11.2', 1 plugin definitions loaded.
2026-01-24 13:50:40.465 Status: : Using default poll interval of 10 secs.
2026-01-24 13:50:40.474 Active notification Subsystems: lms (1/13)
2026-01-24 13:50:40.517 Status: WebServer(HTTP) started on address: :: with port 8080
2026-01-24 13:50:40.529 Status: WebServer(SSL) started on address: :: with port 443
2026-01-24 13:50:40.533 Starting shared server on: :::6144
2026-01-24 13:50:40.534 Status: TCPServer: shared server started...
2026-01-24 13:50:40.535 Status: mDNS: Service started
2026-01-24 13:50:40.536 mDNS: Service: _http._tcp.local.:443 for Hostname: domoticz (1 socket)
2026-01-24 13:50:40.538 Status: RxQueue: queue worker started...
2026-01-24 13:50:42.552 Status: Motherboard: System: ODroid/Raspberry
2026-01-24 13:50:42.553 Status: Motherboard: Hardware Monitor: Started (OStype Linux)
2026-01-24 13:50:42.559 Status: Hue: Worker started...
2026-01-24 13:50:42.560 Status: Weer: Started...
2026-01-24 13:50:42.560 Status: Squeezebox: Worker started...
2026-01-24 13:50:42.567 Mapper: Worker thread started.
2026-01-24 13:50:42.574 Status: Mapper: Started.
2026-01-24 13:50:42.570 Status: anna: AnnaTherm:Worker started...
2026-01-24 13:50:42.573 Status: Slimme meter: attempt connect to 192.168.178.21:23
2026-01-24 13:50:42.570 Status: Squeezebox: 3 player-switch(es) found.
2026-01-24 13:50:42.576 Status: Mapper: Entering work loop.
2026-01-24 13:50:42.584 Status: EventSystem: reset all events...
2026-01-24 13:50:42.606 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/Pvoutput.lua
2026-01-24 13:50:42.595 Status: Slimme meter: Connected to: 192.168.178.21:23
2026-01-24 13:50:42.595 Status: Telefoon: Connected to: 192.168.178.1:1012
2026-01-24 13:50:42.584 Status: NotificationSystem: thread started...
2026-01-24 13:50:42.606 Status: EventSystem: reset all device statuses...
2026-01-24 13:50:42.615 Status: Squeezebox: No playlists found.
2026-01-24 13:50:42.684 Status: Slimme meter: Meter reports as ESMR 5.0
2026-01-24 13:50:42.684 Status: Slimme meter: Current electricity tariff: Low
2026-01-24 13:50:42.864 Status: Python EventSystem: Initializing event module.
2026-01-24 13:50:42.865 Status: EventSystem: Started
2026-01-24 13:50:42.869 Status: EventSystem: Queue thread started...
2026-01-24 13:50:42.905 Status: PluginSystem: 1 plugins started.
2026-01-24 13:50:43.071 Status: Mapper: Initialized version 25.12.9-1, author 'Flying Domotic'
2026-01-24 13:50:43.075 Mapper: Debug logging mask set to: PYTHON PLUGIN
2026-01-24 13:50:43.078 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-24 13:50:43.260 Mapper: pluginV1::__init__
2026-01-24 13:50:43.260 Mapper: 'HardwareID': '48'
2026-01-24 13:50:43.260 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-24 13:50:43.260 Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-24 13:50:43.261 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-24 13:50:43.262 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-24 13:50:43.262 Mapper: 'Language': 'nl'
2026-01-24 13:50:43.263 Mapper: 'Version': '25.12.9-1'
2026-01-24 13:50:43.263 Mapper: 'Author': 'Flying Domotic'
2026-01-24 13:50:43.263 Mapper: 'Name': 'Mapper'
2026-01-24 13:50:43.263 Mapper: 'Address': '192.168.178.50'
2026-01-24 13:50:43.263 Mapper: 'Port': '1883'
2026-01-24 13:50:43.263 Mapper: 'Key': 'MqttMapper'
2026-01-24 13:50:43.263 Mapper: 'Mode1': 'MqttMapper.json'
2026-01-24 13:50:43.263 Mapper: 'Mode6': 'Normal'
2026-01-24 13:50:43.263 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-24 13:50:43.263 Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-24 13:50:43.263 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-24 13:50:43.263 Mapper: Device count: 7
2026-01-24 13:50:43.263 Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '16.0'
2026-01-24 13:50:43.263 Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
2026-01-24 13:50:43.263 Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 12893, sValue: '12893.0'
2026-01-24 13:50:43.263 Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1043, sValue: '1043.448'
2026-01-24 13:50:43.263 Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Ready to Charge'
2026-01-24 13:50:43.264 Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
2026-01-24 13:50:43.264 Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
2026-01-24 13:50:43.265 Mapper: Creating device amperae State of Charge
2026-01-24 13:50:43.265 Mapper: Creating device amperae Hv Capacity
2026-01-24 13:50:43.266 Mapper: MqttClient::__init__
2026-01-24 13:50:43.268 Mapper: Heartbeat interval set to: 3.
2026-01-24 13:50:43.319 Mapper: MqttClient::onConnect
2026-01-24 13:50:43.319 Mapper: MqttClient::onConnect connect to 192.168.178.50:1883, ID=Domoticz_MqttMapper_48_1769259043
2026-01-24 13:50:43.370 Mapper: onMQTTConnected
2026-01-24 13:50:43.370 Mapper: getTopics: '{'SmartEVSE-5572/EVEnergyCharged', 'SmartEVSE-5572/ChargeCurrentOverride', 'wican/amperae/HV_CAPACITY', 'SmartEVSE-5572/MaxCurrent', 'SmartEVSE-5572/ChargeCurrent', 'SmartEVSE-5572/EVTotalEnergyCharged', 'SmartEVSE-5572/Error', 'SmartEVSE-5572/State', 'wican/amperae/SOC'}'
2026-01-24 13:50:43.370 Mapper: MqttClient::Subscribe to [{'Topic': 'SmartEVSE-5572/EVEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrentOverride', 'QoS': 0}, {'Topic': 'wican/amperae/HV_CAPACITY', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/MaxCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVTotalEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/Error', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/State', 'QoS': 0}, {'Topic': 'wican/amperae/SOC', 'QoS': 0}]
2026-01-24 13:50:43.421 Mapper: onMQTTSubscribed
2026-01-24 13:50:43.424 Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '12893'
2026-01-24 13:50:43.425 Mapper: Setting evenergy charged to 12893/12893.0
2026-01-24 13:50:43.428 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-24 13:50:43.428 Mapper: Setting charge current override to 0/0.0
2026-01-24 13:50:43.434 Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-24 13:50:43.435 Mapper: Setting max current to 16/16.0
2026-01-24 13:50:43.439 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-24 13:50:43.439 Mapper: Setting charge current to 16/16.0
2026-01-24 13:50:43.444 Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-24 13:50:43.446 Mapper: testValue="None" (str), readValue="None" (str)
2026-01-24 13:50:43.446 Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-24 13:50:43.446 Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-24 13:50:43.447 Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-24 13:50:43.447 Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-24 13:50:43.447 Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-24 13:50:43.448 Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-24 13:50:43.448 Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-24 13:50:43.448 Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-24 13:50:43.448 Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-24 13:50:43.449 Mapper: Setting SmartEVSE error to 0/0
2026-01-24 13:50:43.456 Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
2026-01-24 13:50:43.458 Mapper: Setting SmartEVSE state to >Ready to Charge<
2026-01-24 13:50:43.570 Status: MQTT: Connecting to 192.168.178.50:1883
2026-01-24 13:50:43.580 anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-01-24 13:50:43.580 anna: Plugwise Plugin Version: 1.0.1
2026-01-24 13:50:43.580 anna: Notice: To change the preset by way of scripts/events, please use the following percentages levels:
2026-01-24 13:50:43.581 anna: 10% for Home, 20% for Away, 30% for Night, 40% for Vacation & 50% for Frost (Lua use 'Set Level: 20')
2026-01-24 13:50:43.581 anna: Any other value will be refused!
2026-01-24 13:50:43.581 anna: To Detect changes in scripts use 'Off, Home, Away, Night, Vacation, Frost'
2026-01-24 13:50:43.581 anna: Adjusting the Temp manually on the ANNA or via App, forces the ANNA to set Scenes to Off!!
2026-01-24 13:50:43.581 anna: KNOWN ISSUE: The Gateway will not send an correct update if the previous scene is choosen again!
2026-01-24 13:50:43.581 anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-01-24 13:50:43.635 Status: Squeezebox: 1 connected player(s) found.
2026-01-24 13:50:43.657 Squeezebox: (LibreELEC) Disconnected
2026-01-24 13:50:43.772 Status: MQTT: Connected to: 192.168.178.50:1883
2026-01-24 13:50:43.971 Hue: Color Switch (Hue color spot 1)
2026-01-24 13:50:43.977 Hue: Color Switch (Hue color spot 2)
2026-01-24 13:50:43.982 Hue: Color Switch (Hue color spot 3)
2026-01-24 13:50:44.275 Status: MQTT: Discovered: Zigbee2MQTT Bridge (Restart required)/Zigbee2MQTT Bridge (Restart required) (unique_id: bridge_0x00124b002b5f63e4_restart_required_zigbeeauto)
2026-01-24 13:50:44.293 Hue: Light/Switch (ZGPSwitch Friends of Hue Switch 1)
2026-01-24 13:50:44.377 Status: MQTT: Discovered: Voordeur (Voordeur_any)/Voordeur (Voordeur_any) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-48-0-Any)
2026-01-24 13:50:44.479 Status: MQTT: Discovered: Voordeur (Voordeur_battery_islow)/Voordeur (Voordeur_battery_islow) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-128-0-isLow)
2026-01-24 13:50:44.565 Motherboard: Temp (Internal Temperature)
2026-01-24 13:50:44.580 Status: MQTT: Discovered: Voordeur (Voordeur_event_general_purpose)/Voordeur (Voordeur_event_general_purpose) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-156-0-state-0)
2026-01-24 13:50:44.611 Telefoon: RFXMeter (Bytes Send (MB))
2026-01-24 13:50:44.613 Telefoon: RFXMeter (Bytes Received (MB))
2026-01-24 13:50:44.616 Telefoon: General/Custom Sensor (TX mbps)
2026-01-24 13:50:44.619 Telefoon: General/Custom Sensor (RX mbps)
2026-01-24 13:50:44.681 Status: MQTT: Discovered: Achterdeur (Achterdeur_any)/Achterdeur (Achterdeur_any) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-48-0-Any)
2026-01-24 13:50:44.685 anna: General/Custom Sensor (burner_operation_time)
2026-01-24 13:50:44.688 anna: Lux (illuminance)
2026-01-24 13:50:44.694 anna: Temp (Anna temp)
2026-01-24 13:50:44.698 anna: Setpoint (Anna themp set)
2026-01-24 13:50:44.783 Status: MQTT: Discovered: Achterdeur (Achterdeur_battery_islow)/Achterdeur (Achterdeur_battery_islow) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-128-0-isLow)
2026-01-24 13:50:44.887 Status: MQTT: Discovered: Achterdeur (Achterdeur_event_general_purpose)/Achterdeur (Achterdeur_event_general_purpose) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-156-0-state-0)
2026-01-24 13:50:45.190 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_load_error_status_1)/Kamerdimmer (Kamerdimmer_load_error_status_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-113-1-Power_Management-Load_error_status)
2026-01-24 13:50:45.294 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_over-current_status)/Lamp vensterbank (Lamp vensterbank_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:45.497 Status: MQTT: Discovered: Lamp wand (Lamp wand_over-current_status)/Lamp wand (Lamp wand_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:45.700 Status: MQTT: Discovered: Audio/video (Audio/video_over-current_status)/Audio/video (Audio/video_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:45.903 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_over-current_status)/Lamp overloop (Lamp overloop_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:46.408 Status: MQTT: Discovered: Lamp kast (Effect)/Lamp kast (Effect) (unique_id: 0x00178801088713d8_effect_zigbeeauto)
2026-01-24 13:50:46.611 Status: MQTT: Discovered: Lamp slaapkamer (Effect)/Lamp slaapkamer (Effect) (unique_id: 0x0017880108a70bf7_effect_zigbeeauto)
2026-01-24 13:50:46.714 Status: MQTT: Discovered: Slaapkamer schakelaar (Device mode)/Slaapkamer schakelaar (Device mode) (unique_id: 0x001788010b001d39_device_mode_zigbeeauto)
2026-01-24 13:50:46.918 Status: MQTT: Discovered: Lamp vloer (Effect)/Lamp vloer (Effect) (unique_id: 0x001788010b281074_effect_zigbeeauto)
2026-01-24 13:50:47.021 Status: MQTT: Discovered: Temperatuur badkamer (Temperature units)/Temperatuur badkamer (Temperature units) (unique_id: 0xe0798dfffecc82ee_temperature_units_zigbeeauto)
2026-01-24 13:50:47.125 Status: MQTT: Discovered: Temperatuur zolder (Temperature units)/Temperatuur zolder (Temperature units) (unique_id: 0xf4b3b1fffe29cc78_temperature_units_zigbeeauto)
2026-01-24 13:50:47.228 Status: MQTT: Discovered: Temperatuur slaapkamer (Temperature units)/Temperatuur slaapkamer (Temperature units) (unique_id: 0xf4b3b1fffe94facb_temperature_units_zigbeeauto)
2026-01-24 13:50:47.330 Status: MQTT: Discovered: Zigbee2MQTT Bridge (Version)/Zigbee2MQTT Bridge (Version) (unique_id: bridge_0x00124b002b5f63e4_version_zigbeeauto)
2026-01-24 13:50:47.431 Status: MQTT: Discovered: Zigbee2MQTT Bridge (Coordinator version)/Zigbee2MQTT Bridge (Coordinator version) (unique_id: bridge_0x00124b002b5f63e4_coordinator_version_zigbeeauto)
2026-01-24 13:50:47.533 Status: MQTT: Discovered: Zigbee2MQTT Bridge (Network map)/Zigbee2MQTT Bridge (Network map) (unique_id: bridge_0x00124b002b5f63e4_network_map_zigbeeauto)
2026-01-24 13:50:47.635 Status: MQTT: Discovered: Temperatuur badkamer/Temperatuur badkamer (unique_id: 0xe0798dfffecc82ee_battery_zigbeeauto)
2026-01-24 13:50:47.664 Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:50:47.672 Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:50:47.675 Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:50:47.678 Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:50:47.681 Slimme meter: Usage (Usage L1)
2026-01-24 13:50:47.683 Slimme meter: Usage (Delivery L1)
2026-01-24 13:50:47.686 Slimme meter: Usage (Usage L2)
2026-01-24 13:50:47.690 Slimme meter: Usage (Delivery L2)
2026-01-24 13:50:47.697 Slimme meter: Usage (Usage L3)
2026-01-24 13:50:47.710 Slimme meter: Usage (Delivery L3)
2026-01-24 13:50:47.719 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:50:47.734 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:50:47.739 Status: MQTT: Discovered: Temperatuur badkamer/Temperatuur badkamer (unique_id: 0xe0798dfffecc82ee_temperature_zigbeeauto)
2026-01-24 13:50:47.751 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:47.757 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:47.841 Status: MQTT: Discovered: Temperatuur badkamer/Temperatuur badkamer (unique_id: 0xe0798dfffecc82ee_humidity_zigbeeauto)
2026-01-24 13:50:47.943 Status: MQTT: Discovered: Voordeur (Voordeur_battery_level)/Voordeur (Voordeur_battery_level) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-128-0-level)
2026-01-24 13:50:48.044 Status: MQTT: Discovered: Achterdeur (Achterdeur_battery_level)/Achterdeur (Achterdeur_battery_level) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-128-0-level)
2026-01-24 13:50:48.145 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_v_value)/Wasmachine (Wasmachine_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66561)
2026-01-24 13:50:48.185 Weer: Temp + Humidity + Baro (Thermo buitentemperatuur)
2026-01-24 13:50:48.190 Weer: Wind (Wind)
2026-01-24 13:50:48.193 Weer: UV (UV Index)
2026-01-24 13:50:48.199 Weer: Rain (Rain)
2026-01-24 13:50:48.200 Weer: General/Visibility (Visibility)
2026-01-24 13:50:48.204 Weer: General/Custom Sensor (Solar radiation Sensor)
2026-01-24 13:50:48.207 Weer: General/Percentage (Cloud Cover)
2026-01-24 13:50:48.246 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_a_value)/Wasmachine (Wasmachine_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66817)
2026-01-24 13:50:48.349 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_kwh_value)/Wasmachine (Wasmachine_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-65537)
2026-01-24 13:50:48.450 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_w_value)/Wasmachine (Wasmachine_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66049)
2026-01-24 13:50:48.553 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_a_value_0)/Wasmachine (Wasmachine_electric_a_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66819)
2026-01-24 13:50:48.654 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_w_value_0)/Wasmachine (Wasmachine_electric_w_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66051)
2026-01-24 13:50:48.755 Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_kwh_value_0)/Wasmachine (Wasmachine_electric_kwh_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-65539)
2026-01-24 13:50:48.857 Status: MQTT: Discovered: Koelkast (Koelkast_electric_v_value)/Koelkast (Koelkast_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66561)
2026-01-24 13:50:48.959 Status: MQTT: Discovered: Koelkast (Koelkast_electric_a_value)/Koelkast (Koelkast_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66817)
2026-01-24 13:50:48.983 Status: [web:8080] Incoming connection from: 192.168.178.30
2026-01-24 13:50:49.060 Status: MQTT: Discovered: Koelkast (Koelkast_electric_kwh_value)/Koelkast (Koelkast_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-65537)
2026-01-24 13:50:49.161 Status: MQTT: Discovered: Koelkast (Koelkast_electric_w_value)/Koelkast (Koelkast_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66049)
2026-01-24 13:50:49.262 Status: MQTT: Discovered: Koelkast (Koelkast_electric_v_value_0)/Koelkast (Koelkast_electric_v_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66563)
2026-01-24 13:50:49.365 Status: MQTT: Discovered: Koelkast (Koelkast_electric_a_value_0)/Koelkast (Koelkast_electric_a_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66816)
2026-01-24 13:50:49.466 Status: MQTT: Discovered: Koelkast (Koelkast_electric_w_value_0)/Koelkast (Koelkast_electric_w_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66051)
2026-01-24 13:50:49.567 Status: MQTT: Discovered: Koelkast (Koelkast_electric_kwh_value_0)/Koelkast (Koelkast_electric_kwh_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-65539)
2026-01-24 13:50:49.668 Status: MQTT: Discovered: Koelkast (Koelkast_electric_pulse_count_value)/Koelkast (Koelkast_electric_pulse_count_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66305)
2026-01-24 13:50:49.769 Status: MQTT: Discovered: Koelkast (Koelkast_electric_kvar_value)/Koelkast (Koelkast_electric_kvar_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-67329)
2026-01-24 13:50:49.870 Status: MQTT: Discovered: Koelkast (Koelkast_electric_power_factor_value)/Koelkast (Koelkast_electric_power_factor_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-67073)
2026-01-24 13:50:49.971 Status: MQTT: Discovered: Koelkast (Koelkast_electric_kvah_value)/Koelkast (Koelkast_electric_kvah_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-65793)
2026-01-24 13:50:50.074 Status: MQTT: Discovered: Koelkast (Koelkast_water_cubic_meters_value)/Koelkast (Koelkast_water_cubic_meters_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-196609)
2026-01-24 13:50:50.176 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_kwh_value)/Vaatwasser (Vaatwasser_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-65537)
2026-01-24 13:50:50.277 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_w_value)/Vaatwasser (Vaatwasser_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-66049)
2026-01-24 13:50:50.378 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_v_value)/Vaatwasser (Vaatwasser_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-66561)
2026-01-24 13:50:50.480 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_a_value)/Vaatwasser (Vaatwasser_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-66817)
2026-01-24 13:50:50.581 Status: MQTT: Discovered: Magnetron (Magnetron_electric_kwh_value)/Magnetron (Magnetron_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-65537)
2026-01-24 13:50:50.683 Status: MQTT: Discovered: Magnetron (Magnetron_electric_a_value)/Magnetron (Magnetron_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-66817)
2026-01-24 13:50:50.770 Status: [web:8080] Incoming connection from: 192.168.178.71
2026-01-24 13:50:50.784 Status: MQTT: Discovered: Magnetron (Magnetron_electric_w_value)/Magnetron (Magnetron_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-66049)
2026-01-24 13:50:50.885 Status: MQTT: Discovered: Magnetron (Magnetron_electric_v_value)/Magnetron (Magnetron_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-66561)
2026-01-24 13:50:50.986 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_power_power_1)/Kamerdimmer (Kamerdimmer_power_power_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-49-1-Power)
2026-01-24 13:50:51.088 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_electric_kwh_value_1)/Kamerdimmer (Kamerdimmer_electric_kwh_value_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-50-1-value-65537)
2026-01-24 13:50:51.189 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_electric_w_value_1)/Kamerdimmer (Kamerdimmer_electric_w_value_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-50-1-value-66049)
2026-01-24 13:50:51.291 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_power_power)/Lamp vensterbank (Lamp vensterbank_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-49-0-Power)
2026-01-24 13:50:51.392 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_electric_kwh_value)/Lamp vensterbank (Lamp vensterbank_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-50-0-value-65537)
2026-01-24 13:50:51.493 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_electric_w_value)/Lamp vensterbank (Lamp vensterbank_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-50-0-value-66049)
2026-01-24 13:50:51.595 Status: MQTT: Discovered: Lamp wand (Lamp wand_power_power)/Lamp wand (Lamp wand_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-49-0-Power)
2026-01-24 13:50:51.676 Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-24 13:50:51.676 Mapper: Setting max current to 16/16.0
2026-01-24 13:50:51.678 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-24 13:50:51.678 Mapper: Setting charge current to 16/16.0
2026-01-24 13:50:51.681 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-24 13:50:51.681 Mapper: Setting charge current override to 0/0.0
2026-01-24 13:50:51.696 Status: MQTT: Discovered: Lamp wand (Lamp wand_electric_kwh_value)/Lamp wand (Lamp wand_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-50-0-value-65537)
2026-01-24 13:50:51.746 Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
2026-01-24 13:50:51.746 Mapper: Setting SmartEVSE state to >Ready to Charge<
2026-01-24 13:50:51.749 Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-24 13:50:51.750 Mapper: testValue="None" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-24 13:50:51.750 Mapper: Setting SmartEVSE error to 0/0
2026-01-24 13:50:51.754 Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '12893'
2026-01-24 13:50:51.755 Mapper: Setting evenergy charged to 12893/12893.0
2026-01-24 13:50:51.758 Mapper: onMQTTPublish found SmartEVSE-5572/EVTotalEnergyCharged, Device 'evtotalenergy charged', message '1043448'
2026-01-24 13:50:51.758 Mapper: Setting evtotalenergy charged to 1043/1043.448
2026-01-24 13:50:51.798 Status: MQTT: Discovered: Lamp wand (Lamp wand_electric_w_value)/Lamp wand (Lamp wand_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-50-0-value-66049)
2026-01-24 13:50:51.901 Status: MQTT: Discovered: Audio/video (Audio/video_power_power)/Audio/video (Audio/video_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-49-0-Power)
2026-01-24 13:50:52.005 Status: MQTT: Discovered: Audio/video (Audio/video_electric_kwh_value)/Audio/video (Audio/video_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-50-0-value-65537)
2026-01-24 13:50:52.108 Status: MQTT: Discovered: Audio/video (Audio/video_electric_w_value)/Audio/video (Audio/video_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-50-0-value-66049)
2026-01-24 13:50:52.212 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_power_power)/Lamp overloop (Lamp overloop_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-49-0-Power)
2026-01-24 13:50:52.316 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_electric_kwh_value)/Lamp overloop (Lamp overloop_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-50-0-value-65537)
2026-01-24 13:50:52.417 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_electric_w_value)/Lamp overloop (Lamp overloop_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-50-0-value-66049)
2026-01-24 13:50:52.519 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_kwh_value)/Lamp schilderij (Lamp schilderij_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-65537)
2026-01-24 13:50:52.620 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_w_value)/Lamp schilderij (Lamp schilderij_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-66049)
2026-01-24 13:50:52.661 Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:50:52.666 Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:50:52.669 Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:50:52.673 Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:50:52.677 Slimme meter: Usage (Usage L1)
2026-01-24 13:50:52.682 Slimme meter: Usage (Delivery L1)
2026-01-24 13:50:52.686 Slimme meter: Usage (Usage L2)
2026-01-24 13:50:52.690 Slimme meter: Usage (Delivery L2)
2026-01-24 13:50:52.695 Slimme meter: Usage (Usage L3)
2026-01-24 13:50:52.699 Slimme meter: Usage (Delivery L3)
2026-01-24 13:50:52.703 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:50:52.708 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:50:52.713 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:52.716 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:52.721 Slimme meter: General/kWh (kWh Usage L1 (Calculated))
2026-01-24 13:50:52.721 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_v_value)/Lamp schilderij (Lamp schilderij_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-66561)
2026-01-24 13:50:52.727 Slimme meter: General/kWh (kWh Delivery L1 (Cal))
2026-01-24 13:50:52.731 Slimme meter: General/kWh (kWh Usage L2 (Cal))
2026-01-24 13:50:52.737 Slimme meter: General/kWh (kWh Usage L3 (Cal))
2026-01-24 13:50:52.744 Slimme meter: General/kWh (kWh Delivery L3 (Cal))
2026-01-24 13:50:52.824 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_a_value)/Lamp schilderij (Lamp schilderij_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-66817)
2026-01-24 13:50:52.929 Status: MQTT: Discovered: Achterdeur (Achterdeur_config_switch_9)/Achterdeur (Achterdeur_config_switch_9) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-112-0-9)
2026-01-24 13:50:53.033 Status: MQTT: Discovered: Achterdeur (Achterdeur_config_switch_10)/Achterdeur (Achterdeur_config_switch_10) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-112-0-10)
2026-01-24 13:50:53.135 Status: MQTT: Discovered: Achterdeur (Achterdeur_config_switch_14)/Achterdeur (Achterdeur_config_switch_14) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-112-0-14)
2026-01-24 13:50:53.237 Status: MQTT: Discovered: Wasmachine (Wasmachine_switch)/Wasmachine (Wasmachine_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-37-0-currentValue)
2026-01-24 13:50:53.339 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_3)/Wasmachine (Wasmachine_config_switch_3) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-3)
2026-01-24 13:50:53.442 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_90)/Wasmachine (Wasmachine_config_switch_90) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-90)
2026-01-24 13:50:53.545 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_1)/Wasmachine (Wasmachine_config_switch_101_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-1)
2026-01-24 13:50:53.647 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_2)/Wasmachine (Wasmachine_config_switch_101_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-2)
2026-01-24 13:50:53.750 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_4)/Wasmachine (Wasmachine_config_switch_101_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-4)
2026-01-24 13:50:53.851 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_8)/Wasmachine (Wasmachine_config_switch_101_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-8)
2026-01-24 13:50:53.953 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_1)/Wasmachine (Wasmachine_config_switch_102_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-1)
2026-01-24 13:50:54.057 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_2)/Wasmachine (Wasmachine_config_switch_102_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-2)
2026-01-24 13:50:54.159 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_4)/Wasmachine (Wasmachine_config_switch_102_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-4)
2026-01-24 13:50:54.262 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_8)/Wasmachine (Wasmachine_config_switch_102_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-8)
2026-01-24 13:50:54.366 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_1)/Wasmachine (Wasmachine_config_switch_103_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-1)
2026-01-24 13:50:54.469 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_2)/Wasmachine (Wasmachine_config_switch_103_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-2)
2026-01-24 13:50:54.573 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_4)/Wasmachine (Wasmachine_config_switch_103_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-4)
2026-01-24 13:50:54.647 Telefoon: RFXMeter (Bytes Send (MB))
2026-01-24 13:50:54.650 Telefoon: RFXMeter (Bytes Received (MB))
2026-01-24 13:50:54.653 Telefoon: General/Custom Sensor (TX mbps)
2026-01-24 13:50:54.656 Telefoon: General/Custom Sensor (RX mbps)
2026-01-24 13:50:54.676 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_8)/Wasmachine (Wasmachine_config_switch_103_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-8)
2026-01-24 13:50:54.779 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_200)/Wasmachine (Wasmachine_config_switch_200) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-200)
2026-01-24 13:50:54.882 Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_252)/Wasmachine (Wasmachine_config_switch_252) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-252)
2026-01-24 13:50:54.985 Status: MQTT: Discovered: Koelkast (Koelkast_switch)/Koelkast (Koelkast_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-37-0-currentValue)
2026-01-24 13:50:55.087 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_3)/Koelkast (Koelkast_config_switch_3) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-3)
2026-01-24 13:50:55.188 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_90)/Koelkast (Koelkast_config_switch_90) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-90)
2026-01-24 13:50:55.290 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_1)/Koelkast (Koelkast_config_switch_101_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-1)
2026-01-24 13:50:55.391 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_2)/Koelkast (Koelkast_config_switch_101_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-2)
2026-01-24 13:50:55.494 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_4)/Koelkast (Koelkast_config_switch_101_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-4)
2026-01-24 13:50:55.595 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_8)/Koelkast (Koelkast_config_switch_101_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-8)
2026-01-24 13:50:55.698 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_1)/Koelkast (Koelkast_config_switch_102_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-1)
2026-01-24 13:50:55.801 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_2)/Koelkast (Koelkast_config_switch_102_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-2)
2026-01-24 13:50:55.903 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_4)/Koelkast (Koelkast_config_switch_102_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-4)
2026-01-24 13:50:56.006 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_8)/Koelkast (Koelkast_config_switch_102_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-8)
2026-01-24 13:50:56.109 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_1)/Koelkast (Koelkast_config_switch_103_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-1)
2026-01-24 13:50:56.211 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_2)/Koelkast (Koelkast_config_switch_103_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-2)
2026-01-24 13:50:56.313 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_4)/Koelkast (Koelkast_config_switch_103_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-4)
2026-01-24 13:50:56.415 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_8)/Koelkast (Koelkast_config_switch_103_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-8)
2026-01-24 13:50:56.518 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_200)/Koelkast (Koelkast_config_switch_200) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-200)
2026-01-24 13:50:56.621 Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_252)/Koelkast (Koelkast_config_switch_252) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-252)
2026-01-24 13:50:56.722 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_switch)/Vaatwasser (Vaatwasser_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-37-0-currentValue)
2026-01-24 13:50:56.823 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_1)/Vaatwasser (Vaatwasser_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-1)
2026-01-24 13:50:56.925 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_5)/Vaatwasser (Vaatwasser_config_switch_5) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-5)
2026-01-24 13:50:57.027 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_7)/Vaatwasser (Vaatwasser_config_switch_7) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-7)
2026-01-24 13:50:57.129 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_8)/Vaatwasser (Vaatwasser_config_switch_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-8)
2026-01-24 13:50:57.230 Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_10)/Vaatwasser (Vaatwasser_config_switch_10) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-10)
2026-01-24 13:50:57.332 Status: MQTT: Discovered: Magnetron (Magnetron_switch)/Magnetron (Magnetron_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-37-0-currentValue)
2026-01-24 13:50:57.434 Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_1)/Magnetron (Magnetron_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-1)
2026-01-24 13:50:57.536 Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_5)/Magnetron (Magnetron_config_switch_5) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-5)
2026-01-24 13:50:57.638 Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_7)/Magnetron (Magnetron_config_switch_7) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-7)
2026-01-24 13:50:57.642 Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:50:57.648 Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:50:57.650 Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:50:57.653 Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:50:57.655 Slimme meter: Usage (Usage L1)
2026-01-24 13:50:57.658 Slimme meter: Usage (Delivery L1)
2026-01-24 13:50:57.661 Slimme meter: Usage (Usage L2)
2026-01-24 13:50:57.664 Slimme meter: Usage (Delivery L2)
2026-01-24 13:50:57.666 Slimme meter: Usage (Usage L3)
2026-01-24 13:50:57.668 Slimme meter: Usage (Delivery L3)
2026-01-24 13:50:57.671 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:50:57.675 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:50:57.680 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:57.681 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:57.739 Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_8)/Magnetron (Magnetron_config_switch_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-8)
2026-01-24 13:50:57.841 Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_10)/Magnetron (Magnetron_config_switch_10) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-10)
2026-01-24 13:50:57.945 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_21)/Kamerdimmer (Kamerdimmer_config_switch_21) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-21)
2026-01-24 13:50:58.049 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_22)/Kamerdimmer (Kamerdimmer_config_switch_22) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-22)
2026-01-24 13:50:58.156 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_23)/Kamerdimmer (Kamerdimmer_config_switch_23) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-23)
2026-01-24 13:50:58.262 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_1)/Kamerdimmer (Kamerdimmer_config_switch_24_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-1)
2026-01-24 13:50:58.368 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_2)/Kamerdimmer (Kamerdimmer_config_switch_24_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-2)
2026-01-24 13:50:58.474 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_4)/Kamerdimmer (Kamerdimmer_config_switch_24_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-4)
2026-01-24 13:50:58.578 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_8)/Kamerdimmer (Kamerdimmer_config_switch_24_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-8)
2026-01-24 13:50:58.681 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_16)/Kamerdimmer (Kamerdimmer_config_switch_24_16) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-16)
2026-01-24 13:50:58.784 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_1)/Kamerdimmer (Kamerdimmer_config_switch_25_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-1)
2026-01-24 13:50:58.888 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_2)/Kamerdimmer (Kamerdimmer_config_switch_25_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-2)
2026-01-24 13:50:58.992 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_4)/Kamerdimmer (Kamerdimmer_config_switch_25_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-4)
2026-01-24 13:50:59.095 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_8)/Kamerdimmer (Kamerdimmer_config_switch_25_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-8)
2026-01-24 13:50:59.203 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_16)/Kamerdimmer (Kamerdimmer_config_switch_25_16) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-16)
2026-01-24 13:50:59.307 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_26)/Kamerdimmer (Kamerdimmer_config_switch_26) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-26)
2026-01-24 13:50:59.409 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_1)/Kamerdimmer (Kamerdimmer_config_switch_27_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-1)
2026-01-24 13:50:59.511 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_2)/Kamerdimmer (Kamerdimmer_config_switch_27_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-2)
2026-01-24 13:50:59.613 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_4)/Kamerdimmer (Kamerdimmer_config_switch_27_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-4)
2026-01-24 13:50:59.715 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_8)/Kamerdimmer (Kamerdimmer_config_switch_27_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-8)
2026-01-24 13:50:59.817 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_29)/Kamerdimmer (Kamerdimmer_config_switch_29) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-29)
2026-01-24 13:50:59.919 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_37)/Kamerdimmer (Kamerdimmer_config_switch_37) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-37)
2026-01-24 13:51:00.021 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_46)/Kamerdimmer (Kamerdimmer_config_switch_46) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-46)
2026-01-24 13:51:00.123 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_47)/Kamerdimmer (Kamerdimmer_config_switch_47) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-47)
2026-01-24 13:51:00.225 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_48)/Kamerdimmer (Kamerdimmer_config_switch_48) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-48)
2026-01-24 13:51:00.326 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_49)/Kamerdimmer (Kamerdimmer_config_switch_49) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-49)
2026-01-24 13:51:00.424 Status: LUA: Fan control
2026-01-24 13:51:00.424 Status: LUA: Current humidity:44.0
2026-01-24 13:51:00.424 Status: LUA: targetFanOffHumidity:46.0
2026-01-24 13:51:00.426 Status: LUA: humidityTmin5: 44.0
2026-01-24 13:51:00.430 Status: LUA: humidityTmin10: 44.0
2026-01-24 13:51:00.430 Status: LUA: fanMaxTimer: 15
2026-01-24 13:51:00.430 Status: LUA: humCounter:2
2026-01-24 13:51:00.430 Status: LUA: fanFollowsProgram:0
2026-01-24 13:51:00.432 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_54)/Kamerdimmer (Kamerdimmer_config_switch_54) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-54)
2026-01-24 13:51:00.437 Status: EventSystem: Script event triggered: Fan control
2026-01-24 13:51:00.538 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_9)/Kamerdimmer (Kamerdimmer_config_switch_9) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-9)
2026-01-24 13:51:00.641 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_28)/Kamerdimmer (Kamerdimmer_config_switch_28) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-28)
2026-01-24 13:51:00.745 Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_45)/Kamerdimmer (Kamerdimmer_config_switch_45) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-45)
2026-01-24 13:51:00.846 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_switch)/Lamp vensterbank (Lamp vensterbank_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-37-0-currentValue)
2026-01-24 13:51:00.948 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_1)/Lamp vensterbank (Lamp vensterbank_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-1)
2026-01-24 13:51:01.051 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_2)/Lamp vensterbank (Lamp vensterbank_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-2)
2026-01-24 13:51:01.153 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_15)/Lamp vensterbank (Lamp vensterbank_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-15)
2026-01-24 13:51:01.255 Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_20)/Lamp vensterbank (Lamp vensterbank_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-20)
2026-01-24 13:51:01.298 Status: [web:8080] Incoming connection from: 192.168.178.32
2026-01-24 13:51:01.356 Status: MQTT: Discovered: Lamp wand (Lamp wand_switch)/Lamp wand (Lamp wand_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-37-0-currentValue)
2026-01-24 13:51:01.459 Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_1)/Lamp wand (Lamp wand_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-1)
2026-01-24 13:51:01.561 Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_2)/Lamp wand (Lamp wand_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-2)
2026-01-24 13:51:01.663 Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_15)/Lamp wand (Lamp wand_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-15)
2026-01-24 13:51:01.765 Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_20)/Lamp wand (Lamp wand_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-20)
2026-01-24 13:51:01.868 Status: MQTT: Discovered: Audio/video (Audio/video_switch)/Audio/video (Audio/video_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-37-0-currentValue)
2026-01-24 13:51:01.970 Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_1)/Audio/video (Audio/video_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-1)
2026-01-24 13:51:02.073 Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_2)/Audio/video (Audio/video_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-2)
2026-01-24 13:51:02.175 Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_15)/Audio/video (Audio/video_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-15)
2026-01-24 13:51:02.277 Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_20)/Audio/video (Audio/video_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-20)
2026-01-24 13:51:02.380 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_switch)/Lamp overloop (Lamp overloop_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-37-0-currentValue)
2026-01-24 13:51:02.482 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_1)/Lamp overloop (Lamp overloop_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-1)
2026-01-24 13:51:02.584 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_2)/Lamp overloop (Lamp overloop_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-2)
2026-01-24 13:51:02.677 Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:51:02.684 Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:51:02.687 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_15)/Lamp overloop (Lamp overloop_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-15)
2026-01-24 13:51:02.689 Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:51:02.695 Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:51:02.700 Slimme meter: Usage (Usage L1)
2026-01-24 13:51:02.705 Slimme meter: Usage (Delivery L1)
2026-01-24 13:51:02.710 Slimme meter: Usage (Usage L2)
2026-01-24 13:51:02.716 Slimme meter: Usage (Delivery L2)
2026-01-24 13:51:02.720 Slimme meter: Usage (Usage L3)
2026-01-24 13:51:02.724 Slimme meter: Usage (Delivery L3)
2026-01-24 13:51:02.729 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:51:02.732 Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-24 13:51:02.734 Mapper: Setting max current to 16/16.0
2026-01-24 13:51:02.738 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:51:02.740 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-24 13:51:02.741 Mapper: Setting charge current to 16/16.0
2026-01-24 13:51:02.747 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:51:02.751 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-24 13:51:02.751 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:51:02.753 Mapper: Setting charge current override to 0/0.0
2026-01-24 13:51:02.758 Slimme meter: General/kWh (kWh Usage L1 (Calculated))
2026-01-24 13:51:02.761 Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
2026-01-24 13:51:02.761 Mapper: Setting SmartEVSE state to >Ready to Charge<
2026-01-24 13:51:02.765 Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-24 13:51:02.765 Mapper: testValue="None" (str), readValue="None" (str)
2026-01-24 13:51:02.765 Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-24 13:51:02.765 Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-24 13:51:02.765 Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-24 13:51:02.765 Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-24 13:51:02.766 Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-24 13:51:02.766 Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-24 13:51:02.766 Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-24 13:51:02.766 Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-24 13:51:02.766 Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-24 13:51:02.766 Mapper: Setting SmartEVSE error to 0/0
2026-01-24 13:51:02.772 Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '12893'
2026-01-24 13:51:02.773 Mapper: Setting evenergy charged to 12893/12893.0
2026-01-24 13:51:02.781 Slimme meter: General/kWh (kWh Delivery L1 (Cal))
2026-01-24 13:51:02.782 Mapper: onMQTTPublish found SmartEVSE-5572/EVTotalEnergyCharged, Device 'evtotalenergy charged', message '1043448'
2026-01-24 13:51:02.782 Mapper: Setting evtotalenergy charged to 1043/1043.448
2026-01-24 13:51:02.789 Slimme meter: General/kWh (kWh Usage L2 (Cal))
2026-01-24 13:51:02.792 Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_20)/Lamp overloop (Lamp overloop_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-20)
2026-01-24 13:51:02.796 Slimme meter: General/kWh (kWh Usage L3 (Cal))
2026-01-24 13:51:02.799 Slimme meter: General/kWh (kWh Delivery L3 (Cal))
2026-01-24 13:51:02.894 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_switch)/Lamp schilderij (Lamp schilderij_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-37-0-currentValue)
2026-01-24 13:51:02.998 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_3)/Lamp schilderij (Lamp schilderij_config_switch_3) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-3)
2026-01-24 13:51:03.102 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_90)/Lamp schilderij (Lamp schilderij_config_switch_90) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-90)
2026-01-24 13:51:03.206 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_1)/Lamp schilderij (Lamp schilderij_config_switch_101_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-1)
2026-01-24 13:51:03.310 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_2)/Lamp schilderij (Lamp schilderij_config_switch_101_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-2)
2026-01-24 13:51:03.414 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_4)/Lamp schilderij (Lamp schilderij_config_switch_101_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-4)
2026-01-24 13:51:03.518 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_8)/Lamp schilderij (Lamp schilderij_config_switch_101_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-8)
2026-01-24 13:51:03.622 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_1)/Lamp schilderij (Lamp schilderij_config_switch_102_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-1)
2026-01-24 13:51:03.726 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_2)/Lamp schilderij (Lamp schilderij_config_switch_102_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-2)
2026-01-24 13:51:03.830 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_4)/Lamp schilderij (Lamp schilderij_config_switch_102_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-4)
2026-01-24 13:51:03.933 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_8)/Lamp schilderij (Lamp schilderij_config_switch_102_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-8)
2026-01-24 13:51:04.037 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_1)/Lamp schilderij (Lamp schilderij_config_switch_103_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-1)
2026-01-24 13:51:04.143 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_2)/Lamp schilderij (Lamp schilderij_config_switch_103_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-2)
2026-01-24 13:51:04.248 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_4)/Lamp schilderij (Lamp schilderij_config_switch_103_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-4)
2026-01-24 13:51:04.350 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_8)/Lamp schilderij (Lamp schilderij_config_switch_103_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-8)
2026-01-24 13:51:04.453 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_200)/Lamp schilderij (Lamp schilderij_config_switch_200) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-200)
2026-01-24 13:51:04.555 Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_252)/Lamp schilderij (Lamp schilderij_config_switch_252) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-252)
2026-01-24 13:51:04.576 Motherboard: General/Percentage (Geheugen)
2026-01-24 13:51:04.577 Motherboard: General/Custom Sensor (Process Usage)
2026-01-24 13:51:04.657 Status: MQTT: Discovered: Voordeur (Voordeur_config_switch_9)/Voordeur (Voordeur_config_switch_9) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-112-0-9)
2026-01-24 13:51:04.682 Telefoon: RFXMeter (Bytes Send (MB))
2026-01-24 13:51:04.684 Telefoon: RFXMeter (Bytes Received (MB))
2026-01-24 13:51:04.685 Telefoon: General/Custom Sensor (TX mbps)
2026-01-24 13:51:04.687 Telefoon: General/Custom Sensor (RX mbps)
2026-01-24 13:51:04.760 Status: MQTT: Discovered: Voordeur (Voordeur_config_switch_10)/Voordeur (Voordeur_config_switch_10) (unique_id:
FlyingDomotic
I'll made a change to trace device creation as it seems there's an not shown error. I won't be able to test it before tomorrow evening or the day after.
Stay tuned!
Stay tuned!
rron
Ok thank you for the affort.
FlyingDomotic
I'm back and just tested a new version which add more trace on device creation, and checks for device just after creating it (as Domoticz Python primitive don't return any error.
Would it be possible to update MqttMapper (git pull), set debug (to "Extra verbose", restart it and send me log ?
rron
Yes I will do that. This weekend I will charge my car again and send you the logging. Thank you.
rron
This is the extra verbose logging
2026-01-30 14:26:29.700 Mapper: MqttClient::onDisconnect Disconnected from 192.168.178.50:1883
2026-01-30 14:26:29.700 Mapper: MqttClient::Close
2026-01-30 14:26:29.700 Mapper: onMQTTDisconnected
2026-01-30 14:26:29.799 Mapper: Worker thread started.
2026-01-30 14:26:29.937 Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-01-30 14:26:29.938 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-30 14:26:29.968 Mapper: pluginV1::__init__
2026-01-30 14:26:29.968 Mapper: 'HardwareID': '48'
2026-01-30 14:26:29.968 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-30 14:26:29.968 Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-30 14:26:29.968 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-30 14:26:29.968 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-30 14:26:29.969 Mapper: 'Language': 'nl'
2026-01-30 14:26:29.969 Mapper: 'Version': '25.12.9-1'
2026-01-30 14:26:29.969 Mapper: 'Author': 'Flying Domotic'
2026-01-30 14:26:29.969 Mapper: 'Name': 'Mapper'
2026-01-30 14:26:29.969 Mapper: 'Address': '192.168.178.50'
2026-01-30 14:26:29.969 Mapper: 'Port': '1883'
2026-01-30 14:26:29.969 Mapper: 'Key': 'MqttMapper'
2026-01-30 14:26:29.969 Mapper: 'Mode1': 'MqttMapper.json'
2026-01-30 14:26:29.969 Mapper: 'Mode6': 'Verbose+'
2026-01-30 14:26:29.969 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-30 14:26:29.969 Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-30 14:26:29.969 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-30 14:26:29.969 Mapper: Device count: 7
2026-01-30 14:26:29.969 Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '16.0'
2026-01-30 14:26:29.969 Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
2026-01-30 14:26:29.969 Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 9864, sValue: '9864.0'
2026-01-30 14:26:29.969 Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1053, sValue: '1053.3120000000001'
2026-01-30 14:26:29.969 Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Charging'
2026-01-30 14:26:29.969 Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
2026-01-30 14:26:29.969 Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
2026-01-30 14:26:29.970 Mapper: Creating device amperae State of Charge
2026-01-30 14:26:29.970 Mapper: Creating device 'amperae State of Charge'.
2026-01-30 14:26:29.970 Mapper: Creating device amperae Hv Capacity
2026-01-30 14:26:29.970 Mapper: Creating device 'amperae Hv Capacity'.
2026-01-30 14:26:29.970 Mapper: MqttClient::__init__
2026-01-30 14:26:29.970 Mapper: Pushing 'ProtocolDirective' on to queue
2026-01-30 14:26:29.970 Mapper: Pushing 'ConnectDirective' on to queue
2026-01-30 14:26:29.972 Mapper: Pushing 'PollIntervalDirective' on to queue
2026-01-30 14:26:29.972 Mapper: Processing 'ProtocolDirective' message
2026-01-30 14:26:29.972 Mapper: Protocol set to: 'MQTT'.
2026-01-30 14:26:29.972 Mapper: Processing 'ConnectDirective' message
2026-01-30 14:26:29.972 Mapper: Transport set to: 'TCP/IP', 192.168.178.50:1883.
2026-01-30 14:26:29.972 Mapper: Connect directive received, action initiated successfully.
2026-01-30 14:26:29.972 Mapper: Processing 'PollIntervalDirective' message
2026-01-30 14:26:29.972 Mapper: Heartbeat interval set to: 3.
2026-01-30 14:26:29.973 Mapper: Pushing 'onConnectCallback' on to queue
2026-01-30 14:26:30.022 Mapper: Processing 'onConnectCallback' message
2026-01-30 14:26:30.022 Mapper: Calling message handler 'onConnect' on 'module' type object.
2026-01-30 14:26:30.022 Mapper: MqttClient::onConnect
2026-01-30 14:26:30.023 Mapper: MqttClient::onConnect connect to 192.168.178.50:1883, ID=Domoticz_MqttMapper_48_1769779590
2026-01-30 14:26:30.023 Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:30.023 Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:30.023 Mapper: Sending 47 bytes of data
2026-01-30 14:26:30.023 Mapper: 10 2d 00 04 4d 51 54 54 04 02 00 3c 00 21 44 6f 6d 6f 74 69 .-..MQTT...<.!Domoti
2026-01-30 14:26:30.023 Mapper: 63 7a 5f 4d 71 74 74 4d 61 70 70 65 72 5f 34 38 5f 31 37 36 cz_MqttMapper_48_176
2026-01-30 14:26:30.023 Mapper: 39 37 37 39 35 39 30 .. .. .. .. .. .. .. .. .. .. .. .. .. 9779590
2026-01-30 14:26:30.024 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.073 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.073 Mapper: Received 4 bytes of data
2026-01-30 14:26:30.073 Mapper: 20 02 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....
2026-01-30 14:26:30.073 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.073 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.073 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.073 Mapper: onMQTTConnected
2026-01-30 14:26:30.074 Mapper: getTopics: '{'wican/amperae/HV_CAPACITY', 'SmartEVSE-5572/EVEnergyCharged', 'SmartEVSE-5572/ChargeCurrent', 'wican/amperae/SOC', 'SmartEVSE-5572/Error', 'SmartEVSE-5572/EVTotalEnergyCharged', 'SmartEVSE-5572/State', 'SmartEVSE-5572/MaxCurrent', 'SmartEVSE-5572/ChargeCurrentOverride'}'
2026-01-30 14:26:30.074 Mapper: MqttClient::Subscribe to [{'Topic': 'wican/amperae/HV_CAPACITY', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrent', 'QoS': 0}, {'Topic': 'wican/amperae/SOC', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/Error', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVTotalEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/State', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/MaxCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrentOverride', 'QoS': 0}]
2026-01-30 14:26:30.074 Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:30.074 Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:30.074 Mapper: Sending 268 bytes of data
2026-01-30 14:26:30.074 Mapper: 82 89 02 00 01 00 19 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 ��.....wican/amperae
2026-01-30 14:26:30.074 Mapper: 2f 48 56 5f 43 41 50 41 43 49 54 59 00 00 1e 53 6d 61 72 74 /HV_CAPACITY...Smart
2026-01-30 14:26:30.074 Mapper: 45 56 53 45 2d 35 35 37 32 2f 45 56 45 6e 65 72 67 79 43 68 EVSE-5572/EVEnergyCh
2026-01-30 14:26:30.074 Mapper: 61 72 67 65 64 00 00 1c 53 6d 61 72 74 45 56 53 45 2d 35 35 arged...SmartEVSE-55
2026-01-30 14:26:30.074 Mapper: 37 32 2f 43 68 61 72 67 65 43 75 72 72 65 6e 74 00 00 11 77 72/ChargeCurrent...w
2026-01-30 14:26:30.074 Mapper: 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f 43 00 00 14 53 ican/amperae/SOC...S
2026-01-30 14:26:30.074 Mapper: 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 45 72 72 6f 72 00 martEVSE-5572/Error.
2026-01-30 14:26:30.074 Mapper: 00 23 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 45 56 54 .#SmartEVSE-5572/EVT
2026-01-30 14:26:30.074 Mapper: 6f 74 61 6c 45 6e 65 72 67 79 43 68 61 72 67 65 64 00 00 14 otalEnergyCharged...
2026-01-30 14:26:30.074 Mapper: 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 53 74 61 74 65 SmartEVSE-5572/State
2026-01-30 14:26:30.074 Mapper: 00 00 19 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 4d 61 ...SmartEVSE-5572/Ma
2026-01-30 14:26:30.074 Mapper: 78 43 75 72 72 65 6e 74 00 00 24 53 6d 61 72 74 45 56 53 45 xCurrent..$SmartEVSE
2026-01-30 14:26:30.074 Mapper: 2d 35 35 37 32 2f 43 68 61 72 67 65 43 75 72 72 65 6e 74 4f -5572/ChargeCurrentO
2026-01-30 14:26:30.074 Mapper: 76 65 72 72 69 64 65 00 .. .. .. .. .. .. .. .. .. .. .. .. verride.
2026-01-30 14:26:30.075 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.125 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.125 Mapper: Received 302 bytes of data
2026-01-30 14:26:30.125 Mapper: 90 0b 00 01 00 00 00 00 00 00 00 00 00 31 2f 00 19 77 69 63 �............1/..wic
2026-01-30 14:26:30.125 Mapper: 61 6e 2f 61 6d 70 65 72 61 65 2f 48 56 5f 43 41 50 41 43 49 an/amperae/HV_CAPACI
2026-01-30 14:26:30.125 Mapper: 54 59 7b 22 48 56 5f 43 41 50 41 43 49 54 59 22 3a 32 33 33 TY{"HV_CAPACITY":233
2026-01-30 14:26:30.125 Mapper: 30 7d 31 24 00 1e 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 0}1$..SmartEVSE-5572
2026-01-30 14:26:30.125 Mapper: 2f 45 56 45 6e 65 72 67 79 43 68 61 72 67 65 64 39 38 36 34 /EVEnergyCharged9864
2026-01-30 14:26:30.125 Mapper: 31 21 00 1c 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 43 1!..SmartEVSE-5572/C
2026-01-30 14:26:30.125 Mapper: 68 61 72 67 65 43 75 72 72 65 6e 74 31 36 30 31 20 00 11 77 hargeCurrent1601...w
2026-01-30 14:26:30.125 Mapper: 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f 43 7b 22 53 4f ican/amperae/SOC{"SO
2026-01-30 14:26:30.125 Mapper: 43 22 3a 33 35 2e 36 39 7d 31 1a 00 14 53 6d 61 72 74 45 56 C":35.69}1...SmartEV
2026-01-30 14:26:30.125 Mapper: 53 45 2d 35 35 37 32 2f 45 72 72 6f 72 4e 6f 6e 65 31 1e 00 SE-5572/ErrorNone1..
2026-01-30 14:26:30.125 Mapper: 14 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 53 74 61 74 .SmartEVSE-5572/Stat
2026-01-30 14:26:30.125 Mapper: 65 43 68 61 72 67 69 6e 67 31 1e 00 19 53 6d 61 72 74 45 56 eCharging1...SmartEV
2026-01-30 14:26:30.125 Mapper: 53 45 2d 35 35 37 32 2f 4d 61 78 43 75 72 72 65 6e 74 31 36 SE-5572/MaxCurrent16
2026-01-30 14:26:30.125 Mapper: 30 31 27 00 24 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 01'.$SmartEVSE-5572/
2026-01-30 14:26:30.125 Mapper: 43 68 61 72 67 65 43 75 72 72 65 6e 74 4f 76 65 72 72 69 64 ChargeCurrentOverrid
2026-01-30 14:26:30.125 Mapper: 65 30 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. e0
2026-01-30 14:26:30.125 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.126 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.126 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.126 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.126 Mapper: onMQTTSubscribed
2026-01-30 14:26:30.127 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.128 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.128 Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '9864'
2026-01-30 14:26:30.128 Mapper: Setting evenergy charged to 9864/9864.0
2026-01-30 14:26:30.128 (evenergy charged) Updating device from 9864:'9864.0' to have values 9864:'9864.0'.
2026-01-30 14:26:30.137 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.137 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.137 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-30 14:26:30.138 Mapper: Setting charge current to 16/16.0
2026-01-30 14:26:30.138 (charge current) Updating device from 16:'16.0' to have values 16:'16.0'.
2026-01-30 14:26:30.143 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.143 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.143 Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-30 14:26:30.143 Mapper: testValue="None" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-30 14:26:30.144 Mapper: Setting SmartEVSE error to 0/0
2026-01-30 14:26:30.144 (SmartEVSE error) Updating device from 0:'0' to have values 0:'0'.
2026-01-30 14:26:30.149 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.150 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.150 Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Charging'
2026-01-30 14:26:30.150 Mapper: Setting SmartEVSE state to >Charging<
2026-01-30 14:26:30.150 (SmartEVSE state) Updating device from 0:'Charging' to have values 0:'Charging'.
2026-01-30 14:26:30.154 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.155 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.155 Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-30 14:26:30.155 Mapper: Setting max current to 16/16.0
2026-01-30 14:26:30.155 (max current) Updating device from 16:'16.0' to have values 16:'16.0'.
2026-01-30 14:26:30.158 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.158 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.158 Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-30 14:26:30.158 Mapper: Setting charge current override to 0/0.0
2026-01-30 14:26:30.158 (charge current override) Updating device from 0:'0.0' to have values 0:'0.0'.
2026-01-30 14:26:30.350 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.363 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.363 Mapper: Received 34 bytes of data
2026-01-30 14:26:30.363 Mapper: 30 20 00 11 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f 0...wican/amperae/SO
2026-01-30 14:26:30.363 Mapper: 43 7b 22 53 4f 43 22 3a 33 35 2e 36 39 7d .. .. .. .. .. .. C{"SOC":35.69}
2026-01-30 14:26:30.363 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.363 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.363 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.516 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.564 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.564 Mapper: Received 49 bytes of data
2026-01-30 14:26:30.564 Mapper: 30 2f 00 19 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 48 56 0/..wican/amperae/HV
2026-01-30 14:26:30.564 Mapper: 5f 43 41 50 41 43 49 54 59 7b 22 48 56 5f 43 41 50 41 43 49 _CAPACITY{"HV_CAPACI
2026-01-30 14:26:30.564 Mapper: 54 59 22 3a 32 33 33 30 7d .. .. .. .. .. .. .. .. .. .. .. TY":2330}
2026-01-30 14:26:30.564 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.564 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.564 Mapper: Calling message handler 'onMessage' on 'module' type object.
rron
Re: Python Plugin: MqttMapper
part 2 logging
2026-01-30 14:26:31.983 Telefoon: RFXMeter (Bytes Send (MB))
2026-01-30 14:26:31.986 Telefoon: RFXMeter (Bytes Received (MB))
2026-01-30 14:26:31.988 Telefoon: General/Custom Sensor (TX mbps)
2026-01-30 14:26:31.991 Telefoon: General/Custom Sensor (RX mbps)
2026-01-30 14:26:32.016 Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-01-30 14:26:32.066 Mapper: Processing 'onHeartbeatCallback' message
2026-01-30 14:26:32.067 Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-01-30 14:26:32.067 Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:32.067 Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:32.067 Mapper: Sending 2 bytes of data
2026-01-30 14:26:32.067 Mapper: c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �.
2026-01-30 14:26:32.067 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:32.117 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:32.117 Mapper: Received 2 bytes of data
2026-01-30 14:26:32.117 Mapper: d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �.
2026-01-30 14:26:32.118 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:32.118 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:32.118 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:33.025 Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-30 14:26:33.030 Slimme meter: General/Voltage (Voltage L1)
2026-01-30 14:26:33.035 Slimme meter: General/Voltage (Voltage L2)
2026-01-30 14:26:33.039 Slimme meter: General/Voltage (Voltage L3)
2026-01-30 14:26:33.042 Slimme meter: Usage (Usage L1)
2026-01-30 14:26:33.046 Slimme meter: Usage (Delivery L1)
2026-01-30 14:26:33.050 Slimme meter: Usage (Usage L2)
2026-01-30 14:26:33.054 Slimme meter: Usage (Delivery L2)
2026-01-30 14:26:33.058 Slimme meter: Usage (Usage L3)
2026-01-30 14:26:33.062 Slimme meter: Usage (Delivery L3)
2026-01-30 14:26:33.066 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-30 14:26:33.071 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-30 14:26:33.075 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-30 14:26:33.078 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-30 14:26:35.023 Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-01-30 14:26:35.073 Mapper: Processing 'onHeartbeatCallback' message
2026-01-30 14:26:35.073 Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-01-30 14:26:35.073 Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:35.073 Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:35.073 Mapper: Sending 2 bytes of data
2026-01-30 14:26:35.074 Mapper: c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �.
2026-01-30 14:26:35.075 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:35.124 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:35.124 Mapper: Received 2 bytes of data
2026-01-30 14:26:35.124 Mapper: d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �.
2026-01-30 14:26:35.124 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:35.124 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:35.124 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:35.420 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:35.425 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:35.425 Mapper: Received 34 bytes of data
2026-01-30 14:26:35.425 Mapper: 30 20 00 11 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f 0...wican/amperae/SO
2026-01-30 14:26:35.425 Mapper: 43 7b 22 53 4f 43 22 3a 33 35 2e 36 39 7d .. .. .. .. .. .. C{"SOC":35.69}
2026-01-30 14:26:35.425 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:35.425 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:35.425 Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:35.543 Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:35.576 Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:35.576 Mapper: Received 49 bytes of data
2026-01-30 14:26:35.576 Mapper: 30 2f 00 19 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 48 56 0/..wican/amperae/HV
2026-01-30 14:26:35.576 Mapper: 5f 43 41 50 41 43 49 54 59 7b 22 48 56 5f 43 41 50 41 43 49 _CAPACITY{"HV_CAPACI
2026-01-30 14:26:35.576 Mapper: 54 59 22 3a 32 33 33 30 7d .. .. .. .. .. .. .. .. .. .. .. TY":2330}
2026-01-30 14:26:35.576 Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:35.576 Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:35.576 Mapper: Calling message handler 'onMessage' on 'module' type object.Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
- Domoticz version: 2020.2
It seems that there's no more "Mapper: Can't find device" in the log.
Is still something wrong?
rron
You’re right it looks that after the git pull something went wrong
FlyingDomotic
Do you mean "everything is ok now" or "there's still something wrong"?
If something is still wrong, please describe it.
rron
I think the mapper does not work anymore after the git pull. There is no update from the the devices anymore.
2026-01-31 11:30:24.376 Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-01-31 11:30:24.377 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-31 11:30:24.404 Mapper: pluginV1::__init__
2026-01-31 11:30:24.404 Mapper: 'HardwareID': '50'
2026-01-31 11:30:24.404 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-31 11:30:24.404 Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-31 11:30:24.404 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-31 11:30:24.404 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-31 11:30:24.404 Mapper: 'Language': 'nl'
2026-01-31 11:30:24.404 Mapper: 'Version': '26.1.26-1'
2026-01-31 11:30:24.404 Mapper: 'Author': 'Flying Domotic'
2026-01-31 11:30:24.404 Mapper: 'Name': 'Mapper'
2026-01-31 11:30:24.405 Mapper: 'Address': '192.168.178.50'
2026-01-31 11:30:24.405 Mapper: 'Port': '1883'
2026-01-31 11:30:24.405 Mapper: 'Key': 'MqttMapper'
2026-01-31 11:30:24.405 Mapper: 'Mode1': 'MqttMapper.json'
2026-01-31 11:30:24.405 Mapper: 'Mode6': 'Verbose+'
2026-01-31 11:30:24.405 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-31 11:30:24.405 Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-31 11:30:24.405 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-31 11:30:24.405 Mapper: Device count: 0
2026-01-31 11:30:24.406 Mapper: Creating device 'SmartEVSE charge current' with key 'SmartEVSE-5572/ChargeCurrent' as unit 1
2026-01-31 11:30:24.406 Mapper: Name='SmartEVSE charge current', Unit='1', Type=243, Subtype=23, Switchtype=0, DeviceID='SmartEVSE-5572/ChargeCurrent', Options='None', Used='True'
2026-01-31 11:30:24.406 Mapper: Creating device 'SmartEVSE charge current'.
2026-01-31 11:30:24.429 Mapper: Local context:
2026-01-31 11:30:24.429 Mapper: ----> 'Devices' '{}'
2026-01-31 11:30:24.429 Mapper: ----> 'Domoticz' '<module 'Domoticz' (built-in)>'
2026-01-31 11:30:24.429 Mapper: ----> 'Images' '{}'
2026-01-31 11:30:24.429 Mapper: ----> 'Parameters' '{'HardwareID': 50, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Verbose+', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-01-31 11:30:24.429 Mapper: ----> 'Settings' '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '1', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-01-31 11:30:24.430 Mapper: ----> '_plugin' '<pluginV1.pluginV1 object at 0xee54daf0>'
2026-01-31 11:30:24.430 Mapper: ----> 'json' '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-01-31 11:30:24.430 Mapper: ----> 'os' '<module 'os' (frozen)>'
2026-01-31 11:30:25.228 Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-31 11:30:25.235 Slimme meter: General/Voltage (Voltage L1)
2026-01-31 11:30:25.240 Slimme meter: General/Voltage (Voltage L2)
2026-01-31 11:30:25.244 Slimme meter: General/Voltage (Voltage L3)
2026-01-31 11:30:25.248 Slimme meter: Usage (Usage L1)
2026-01-31 11:30:25.252 Slimme meter: Usage (Delivery L1)
2026-01-31 11:30:25.256 Slimme meter: Usage (Usage L2)
2026-01-31 11:30:25.260 Slimme meter: Usage (Delivery L2)
2026-01-31 11:30:25.264 Slimme meter: Usage (Usage L3)
2026-01-31 11:30:25.269 Slimme meter: Usage (Delivery L3)
2026-01-31 11:30:25.273 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-31 11:30:25.277 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-31 11:30:25.281 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-31 11:30:25.284 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-31 11:30:29.303 Mapper: Pushing 'onStopCallback' on to queue
2026-01-31 11:30:29.303 Mapper: Processing 'onStopCallback' message
2026-01-31 11:30:29.303 Mapper: Message handler 'onStop' not callable, ignored.
2026-01-31 11:30:30.002 mDNS: Closed 1 socket
2026-01-31 11:31:06.824 Sunrise: 08:23:00 SunSet: 17:24:00
2026-01-31 11:31:06.825 Day length: 09:01:00 Sun at south: 12:54:00
2026-01-31 11:31:06.825 Civil twilight start: 07:46:00 Civil twilight end: 18:01:00
2026-01-31 11:31:06.825 Nautical twilight start: 07:05:00 Nautical twilight end: 18:43:00
2026-01-31 11:31:06.825 Astronomical twilight start: 06:25:00 Astronomical twilight end: 19:23:00
2026-01-31 11:31:06.907 Active notification Subsystems: lms (1/13)
2026-01-31 11:31:06.949 Starting shared server on: :::6144
2026-01-31 11:31:06.952 mDNS: Service: _http._tcp.local.:443 for Hostname: domoticz (1 socket)
2026-01-31 11:31:08.971 Mapper: Worker thread started.
2026-01-31 11:31:08.972 Mapper: Worker thread started.
2026-01-31 11:31:09.299 Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-01-31 11:31:09.304 Mapper: Debug logging mask set to: PYTHON PLUGIN DEVICE
2026-01-31 11:31:09.305 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-31 11:31:09.307 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-31 11:31:09.451 Mapper: pluginV1::__init__
2026-01-31 11:31:09.451 Mapper: 'HardwareID': '48'
2026-01-31 11:31:09.451 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-31 11:31:09.452 Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-31 11:31:09.452 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-31 11:31:09.452 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-31 11:31:09.453 Mapper: 'Language': 'nl'
2026-01-31 11:31:09.453 Mapper: 'Version': '26.1.26-1'
2026-01-31 11:31:09.453 Mapper: 'Author': 'Flying Domotic'
2026-01-31 11:31:09.453 Mapper: 'Name': 'Mapper'
2026-01-31 11:31:09.453 Mapper: 'Address': '192.168.178.50'
2026-01-31 11:31:09.454 Mapper: 'Port': '1883'
2026-01-31 11:31:09.454 Mapper: 'Key': 'MqttMapper'
2026-01-31 11:31:09.454 Mapper: 'Mode1': 'MqttMapper.json'
2026-01-31 11:31:09.454 Mapper: 'Mode6': 'Debug'
2026-01-31 11:31:09.454 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-31 11:31:09.454 Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-31 11:31:09.454 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-31 11:31:09.455 Mapper: Device count: 7
2026-01-31 11:31:09.456 Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '16.0'
2026-01-31 11:31:09.456 Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
2026-01-31 11:31:09.456 Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 10013, sValue: '10013.0'
2026-01-31 11:31:09.457 Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1053, sValue: '1053.461'
2026-01-31 11:31:09.458 Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Charging'
2026-01-31 11:31:09.458 Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
2026-01-31 11:31:09.459 Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
2026-01-31 11:31:09.460 Mapper: Creating device 'amperae State of Charge' with key 'wican/amperae/SOC' as unit 8
2026-01-31 11:31:09.460 Mapper: Creating device 'amperae State of Charge'.
2026-01-31 11:31:09.467 Mapper: pluginV1::__init__
2026-01-31 11:31:09.467 Mapper: 'HardwareID': '50'
2026-01-31 11:31:09.467 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-31 11:31:09.470 Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-31 11:31:09.470 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-31 11:31:09.471 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-31 11:31:09.471 Mapper: 'Language': 'nl'
2026-01-31 11:31:09.471 Mapper: 'Version': '26.1.26-1'
2026-01-31 11:31:09.471 Mapper: 'Author': 'Flying Domotic'
2026-01-31 11:31:09.471 Mapper: 'Name': 'Mapper'
2026-01-31 11:31:09.472 Mapper: 'Address': '192.168.178.50'
2026-01-31 11:31:09.472 Mapper: 'Port': '1883'
2026-01-31 11:31:09.472 Mapper: 'Key': 'MqttMapper'
2026-01-31 11:31:09.472 Mapper: 'Mode1': 'MqttMapper.json'
2026-01-31 11:31:09.472 Mapper: 'Mode6': 'Verbose+'
2026-01-31 11:31:09.472 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-31 11:31:09.473 Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-31 11:31:09.473 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-31 11:31:09.473 Mapper: Device count: 0
2026-01-31 11:31:09.474 Mapper: Creating device 'SmartEVSE charge current' with key 'SmartEVSE-5572/ChargeCurrent' as unit 1
2026-01-31 11:31:09.474 Mapper: Name='SmartEVSE charge current', Unit='1', Type=243, Subtype=23, Switchtype=0, DeviceID='SmartEVSE-5572/ChargeCurrent', Options='None', Used='True'
2026-01-31 11:31:09.475 Mapper: Creating device 'SmartEVSE charge current'.
2026-01-31 11:31:09.586 Mapper: Local context:
2026-01-31 11:31:09.587 Mapper: ----> 'Devices' '{1: <Domoticz.Device object at 0xefb535c0>, 2: <Domoticz.Device object at 0xefb53680>, 3: <Domoticz.Device object at 0xefb53b00>, 4: <Domoticz.Device object at 0xefb530e0>, 5: <Domoticz.Device object at 0xefb53320>, 6: <Domoticz.Device object at 0xee1c8920>, 7: <Domoticz.Device object at 0xee1c8980>}'
2026-01-31 11:31:09.587 Mapper: ----> 'Domoticz' '<module 'Domoticz' (built-in)>'
2026-01-31 11:31:09.587 Mapper: ----> 'Images' '{}'
2026-01-31 11:31:09.588 Mapper: ----> 'Parameters' '{'HardwareID': 48, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Debug', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-01-31 11:31:09.588 Mapper: ----> 'Settings' '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '1', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-01-31 11:31:09.589 Mapper: ----> '_plugin' '<pluginV1.pluginV1 object at 0xee1b4f30>'
2026-01-31 11:31:09.590 Mapper: ----> 'json' '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-01-31 11:31:09.590 Mapper: ----> 'os' '<module 'os' (frozen)>'
2026-01-31 11:31:09.603 Mapper: Local context:
2026-01-31 11:31:09.603 Mapper: ----> 'Devices' '{}'
2026-01-31 11:31:09.603 Mapper: ----> 'Domoticz' '<module 'Domoticz' (built-in)>'
2026-01-31 11:31:09.603 Mapper: ----> 'Images' '{}'
2026-01-31 11:31:09.604 Mapper: ----> 'Parameters' '{'HardwareID': 50, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Verbose+', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-01-31 11:31:09.604 Mapper: ----> 'Settings' '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '1', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-01-31 11:31:09.605 Mapper: ----> '_plugin' '<pluginV1.pluginV1 object at 0xee1b4910>'
2026-01-31 11:31:09.614 Mapper: ----> 'json' '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-01-31 11:31:09.614 Mapper: ----> 'os' '<module 'os' (frozen)>'Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
Would it be possible to check that there's not the same "Mapper" hardware twice (one with hardware 48 and one with 50)?
rron
The first time there were 2 mappers active, I deleted the second but still no luck.There are no devices created anymore.
026-02-01 11:32:30.032 Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-02-01 11:32:30.082 Mapper: Processing 'onHeartbeatCallback' message
2026-02-01 11:32:30.083 Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-02-01 11:32:31.111 Mapper: Pushing 'onStopCallback' on to queue
2026-02-01 11:32:31.112 Mapper: Processing 'onStopCallback' message
2026-02-01 11:32:31.112 Mapper: Message handler 'onStop' not callable, ignored.
2026-02-01 11:32:32.403 mDNS: Closed 1 socket
2026-02-01 11:32:50.697 Sunrise: 08:21:00 SunSet: 17:26:00
2026-02-01 11:32:50.698 Day length: 09:05:00 Sun at south: 12:54:00
2026-02-01 11:32:50.698 Civil twilight start: 07:44:00 Civil twilight end: 18:03:00
2026-02-01 11:32:50.698 Nautical twilight start: 07:03:00 Nautical twilight end: 18:44:00
2026-02-01 11:32:50.698 Astronomical twilight start: 06:23:00 Astronomical twilight end: 19:24:00
2026-02-01 11:32:50.768 Active notification Subsystems: lms (1/13)
2026-02-01 11:32:50.823 Starting shared server on: :::6144
2026-02-01 11:32:50.825 mDNS: Service: _http._tcp.local.:443 for Hostname: domoticz (1 socket)
2026-02-01 11:32:52.850 Mapper: Worker thread started.
2026-02-01 11:32:53.338 Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-02-01 11:32:53.340 Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-02-01 11:32:53.521 Mapper: pluginV1::__init__
2026-02-01 11:32:53.522 Mapper: 'HardwareID': '50'
2026-02-01 11:32:53.522 Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-02-01 11:32:53.522 Mapper: 'StartupFolder': '/opt/domoticz/'
2026-02-01 11:32:53.522 Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-02-01 11:32:53.522 Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-02-01 11:32:53.522 Mapper: 'Language': 'nl'
2026-02-01 11:32:53.523 Mapper: 'Version': '26.1.26-1'
2026-02-01 11:32:53.523 Mapper: 'Author': 'Flying Domotic'
2026-02-01 11:32:53.523 Mapper: 'Name': 'Mapper'
2026-02-01 11:32:53.523 Mapper: 'Address': '192.168.178.50'
2026-02-01 11:32:53.523 Mapper: 'Port': '1883'
2026-02-01 11:32:53.523 Mapper: 'Key': 'MqttMapper'
2026-02-01 11:32:53.523 Mapper: 'Mode1': 'MqttMapper.json'
2026-02-01 11:32:53.523 Mapper: 'Mode6': 'Verbose+'
2026-02-01 11:32:53.524 Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-02-01 11:32:53.524 Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-02-01 11:32:53.524 Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-02-01 11:32:53.524 Mapper: Device count: 0
2026-02-01 11:32:53.525 Mapper: Creating device 'SmartEVSE charge current' with key 'SmartEVSE-5572/ChargeCurrent' as unit 1
2026-02-01 11:32:53.525 Mapper: Name='SmartEVSE charge current', Unit='1', Type=243, Subtype=23, Switchtype=0, DeviceID='SmartEVSE-5572/ChargeCurrent', Options='None', Used='True'
2026-02-01 11:32:53.525 Mapper: Creating device 'SmartEVSE charge current'.
2026-02-01 11:32:53.643 Mapper: Local context:
2026-02-01 11:32:53.644 Mapper: ----> 'Devices' '{}'
2026-02-01 11:32:53.644 Mapper: ----> 'Domoticz' '<module 'Domoticz' (built-in)>'
2026-02-01 11:32:53.645 Mapper: ----> 'Images' '{}'
2026-02-01 11:32:53.645 Mapper: ----> 'Parameters' '{'HardwareID': 50, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Verbose+', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-02-01 11:32:53.646 Mapper: ----> 'Settings' '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '0', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-02-01 11:32:53.646 Mapper: ----> '_plugin' '<pluginV1.pluginV1 object at 0xf0f7e090>'
2026-02-01 11:32:53.647 Mapper: ----> 'json' '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-02-01 11:32:53.647 Mapper: ----> 'os' '<module 'os' (frozen)>'
2026-02-01 11:32:53.851 anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-02-01 11:32:53.851 anna: Plugwise Plugin Version: 1.0.1
2026-02-01 11:32:53.852 anna: Notice: To change the preset by way of scripts/events, please use the following percentages levels:
2026-02-01 11:32:53.852 anna: 10% for Home, 20% for Away, 30% for Night, 40% for Vacation & 50% for Frost (Lua use 'Set Level: 20')
2026-02-01 11:32:53.852 anna: Any other value will be refused!
2026-02-01 11:32:53.852 anna: To Detect changes in scripts use 'Off, Home, Away, Night, Vacation, Frost'
2026-02-01 11:32:53.852 anna: Adjusting the Temp manually on the ANNA or via App, forces the ANNA to set Scenes to Off!!
2026-02-01 11:32:53.852 anna: KNOWN ISSUE: The Gateway will not send an correct update if the previous scene is choosen again!
2026-02-01 11:32:53.852 anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-02-01 11:32:53.913 Squeezebox: (LibreELEC) Disconnected
2026-02-01 11:32:54.217 Hue: Color Switch (Hue color spot 1)
2026-02-01 11:32:54.226 Hue: Color Switch (Hue color spot 2)
2026-02-01 11:32:54.233 Hue: Color Switch (Hue color spot 3)
2026-02-01 11:32:54.523 Hue: Light/Switch (ZGPSwitch Friends of Hue Switch 1)
2026-02-01 11:32:54.855 Motherboard: Temp (Internal Temperature)
2026-02-01 11:32:54.914 Telefoon: RFXMeter (Bytes Send (MB))
2026-02-01 11:32:54.919 Telefoon: RFXMeter (Bytes Received (MB))
2026-02-01 11:32:54.924 Telefoon: General/Custom Sensor (TX mbps)
2026-02-01 11:32:54.928 Telefoon: General/Custom Sensor (RX mbps)
2026-02-01 11:32:54.972 anna: General/Custom Sensor (burner_operation_time)
2026-02-01 11:32:54.978 anna: Lux (illuminance)
2026-02-01 11:32:54.986 anna: Temp (Anna temp)
2026-02-01 11:32:54.992 anna: Setpoint (Anna themp set)
2026-02-01 11:32:57.430 Slimme meter: P1 Smart Meter (Slimme meter)
2026-02-01 11:32:57.437 Slimme meter: General/Voltage (Voltage L1)
2026-02-01 11:32:57.442 Slimme meter: General/Voltage (Voltage L2)
2026-02-01 11:32:57.449 Slimme meter: General/Voltage (Voltage L3)
2026-02-01 11:32:57.454 Slimme meter: Usage (Usage L1)
2026-02-01 11:32:57.459 Slimme meter: Usage (Delivery L1)
2026-02-01 11:32:57.464 Slimme meter: Usage (Usage L2)
2026-02-01 11:32:57.469 Slimme meter: Usage (Delivery L2)
2026-02-01 11:32:57.475 Slimme meter: Usage (Usage L3)
2026-02-01 11:32:57.482 Slimme meter: Usage (Delivery L3)
2026-02-01 11:32:57.488 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-02-01 11:32:57.494 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-02-01 11:32:57.501 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:32:57.506 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:32:58.391 Weer: Temp + Humidity + Baro (Thermo buitentemperatuur)
2026-02-01 11:32:58.398 Weer: Wind (Wind)
2026-02-01 11:32:58.404 Weer: UV (UV Index)
2026-02-01 11:32:58.411 Weer: Rain (Rain)
2026-02-01 11:32:58.414 Weer: General/Visibility (Visibility)
2026-02-01 11:32:58.419 Weer: General/Custom Sensor (Solar radiation Sensor)
2026-02-01 11:32:58.424 Weer: General/Percentage (Cloud Cover)
2026-02-01 11:33:02.014 Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-02-01 11:33:02.065 Mapper: Processing 'onHeartbeatCallback' message
2026-02-01 11:33:02.065 Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-02-01 11:33:02.402 Slimme meter: P1 Smart Meter (Slimme meter)
2026-02-01 11:33:02.410 Slimme meter: General/Voltage (Voltage L1)
2026-02-01 11:33:02.417 Slimme meter: General/Voltage (Voltage L2)
2026-02-01 11:33:02.423 Slimme meter: General/Voltage (Voltage L3)
2026-02-01 11:33:02.429 Slimme meter: Usage (Usage L1)
2026-02-01 11:33:02.436 Slimme meter: Usage (Delivery L1)
2026-02-01 11:33:02.442 Slimme meter: Usage (Usage L2)
2026-02-01 11:33:02.448 Slimme meter: Usage (Delivery L2)
2026-02-01 11:33:02.454 Slimme meter: Usage (Usage L3)
2026-02-01 11:33:02.460 Slimme meter: Usage (Delivery L3)
2026-02-01 11:33:02.467 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-02-01 11:33:02.473 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-02-01 11:33:02.479 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:02.484 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:02.492 Slimme meter: General/kWh (kWh Usage L1 (Calculated))
2026-02-01 11:33:02.499 Slimme meter: General/kWh (kWh Delivery L1 (Cal))
2026-02-01 11:33:02.506 Slimme meter: General/kWh (kWh Usage L2 (Cal))
2026-02-01 11:33:02.512 Slimme meter: General/kWh (kWh Usage L3 (Cal))
2026-02-01 11:33:02.519 Slimme meter: General/kWh (kWh Delivery L3 (Cal))
2026-02-01 11:33:04.972 Telefoon: RFXMeter (Bytes Send (MB))
2026-02-01 11:33:04.975 Telefoon: RFXMeter (Bytes Received (MB))
2026-02-01 11:33:04.978 Telefoon: General/Custom Sensor (TX mbps)
2026-02-01 11:33:04.981 Telefoon: General/Custom Sensor (RX mbps)
2026-02-01 11:33:07.416 Slimme meter: P1 Smart Meter (Slimme meter)
2026-02-01 11:33:07.424 Slimme meter: General/Voltage (Voltage L1)
2026-02-01 11:33:07.430 Slimme meter: General/Voltage (Voltage L2)
2026-02-01 11:33:07.437 Slimme meter: General/Voltage (Voltage L3)
2026-02-01 11:33:07.443 Slimme meter: Usage (Usage L1)
2026-02-01 11:33:07.447 Slimme meter: Usage (Delivery L1)
2026-02-01 11:33:07.451 Slimme meter: Usage (Usage L2)
2026-02-01 11:33:07.455 Slimme meter: Usage (Delivery L2)
2026-02-01 11:33:07.460 Slimme meter: Usage (Usage L3)
2026-02-01 11:33:07.464 Slimme meter: Usage (Delivery L3)
2026-02-01 11:33:07.468 Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-02-01 11:33:07.472 Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-02-01 11:33:07.476 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:07.479 Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:12.032 Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-02-01 11:33:12.082 Mapper: Processing 'onHeartbeatCallback' message
2026-02-01 11:33:12.083 Mapper: Calling message handler 'onHeartbeat' on 'module' type object.Rpi4, Docker, z-wave, zigbee, espeasy, smartevse
FlyingDomotic
Did you authorize Domoticz to create new devices before restarting MqttMapper ?
