Adding RFX device
PSUtec
Domoticz version: 12896
Adding RFX device
Post by PSUtec »
When I want to add an RFX switch via "Learn Light/Switch", when I activate the device button, I receive the error message: "Already in use by VS_EGOq_Stove, a virtual switch.
How to avoid this error.
PSUtec
Re: Adding RFX device
Post by PSUtec »
Thanks for your help!
However, I don't think that the RFX ID is the real problem; VS_EGOq_Stove is a virtual switch generated by a hardware of type "Dummy (Does nothing, use for virtual switches only)" and therefore has no RFX ID or assignment.
Regards,
Domoticz version: 2026.3
I removed the answer as is was an AI answer that looked real but told rubbish.
As I do not use RFX I have no idea why you have this issue.
