Enphase firmware D8.3.5286
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Arjan2019
Post by Arjan2019 »
With the last update FW D8.3.5286 I get only error on the Enphase Envoy with LAN (HTTP)
2026-01-09 09:15:49.710 Error: Zonne Energie: Error getting http data! (info)
2026-01-09 09:15:59.722 Error: Zonne Energie: Error getting http data! (info)
2026-01-09 09:16:09.737 Error: Zonne Energie: Error getting http data! (info)
2026-01-09 09:16:19.749 Error: Zonne Energie: Error getting http data! (info)
2026-01-09 09:16:29.760 Error: Zonne Energie: Error getting http data! (info)
http://Ip-address Envoy give an error not found
HansSch
Re: Enphase firmware D8.3.5286
Post by HansSch »
Here the same problem, Github Issue #6502 was closed by Gismocuz but didn't resolve my issue.
As the new firmware does not accept http anymore I tried:
- Change in Hardware Envoy LAN port to 443,
- Change in Security settings Http API to disabled.
- Rebooted the system
As the envoy key is valid (tested in GUI) and available in the ..48 and ..48ex variables, i'm out of options.
Does anyone has a solution to resolve this?
Or give tips on how to get more details to increase debugging info about the Envoy hardware part in domoticz logging.
Hans
HansSch
Post by HansSch »
Github case #6503, Beta 17030 Tested OK. :)
Users browsing this forum: gizmocuz and 1 guest
