Did you make a PR for this so everyone can make use of it? Else you can change this after every update....Thuis wrote: Tuesday 16 December 2025 19:58 Oh well, i changed the script a bit, so it will not look if domoticz service is running, but it just stops it anyway, if it is running or not, this works...
beta update error over webgui Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2025.1
Re: beta update error
Dave21w
- Domoticz version: Stable
Hi, @ waltervl, I should have been a bit clearer when I said a stop / start, that is indeed what I had to do, like you a restart does not work for me either.
- Thuis
A PR? Yes i like to do that so everyone can use it, but i have no idea how to do this, I am at github, then i click new pull request, because i think that is what i need to do, but the button is grayed out. It says i can compare branches? So im stuck there. Then i read "Contributing to Domoticz" but then i see someting about new hardware and it brings me to the wiki. I see Please base your bug fixes against the development branch. Please also use a descriptive commit message So in short, i have no clue how to PR.
I never used it... Tell me
So i made a fork, changed the updatebeta, but yes, i have no idea what i am doing. So i better stop.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
- jvdz
- Domoticz version: 4.107
A short description of the pull-request creation process :
1. Fork the original repository you'd like to make updates for.
2. Go into your own forked Repository and copy the Branch you like to make an update for into a new Branch, so in this case select the Development branch: 3. Go to the main page and select the newly created Branch. 4. Update the file(s) that need modification and commit the change.
5. On the main page you now see the Contribute option. Click Contribute & Open Pull Request: 6. Add title & Description
Check the Target Repo : Domoticz/Domiticz - Development
Check source Repo: YOU/domoticz - Fix_Update_Process
Click on "Create Pull Request" That's it.
The reason for creating a new Branch is that this allows it to be deleted after the PR is processed, which is an option when merge is done.
On top of that, you shouldn't update the Development branch itself as that will sync with the updates done in Domoticz/Domoticz and else could create conflicts when you want to update you forked version.
- Thuis
Thanks, i tried my best, lots of steps and if you never used it, like me, it is a bit overwhelming, so thank you very much for pointing me in the right direction. I hope all is received in good order and everyone can use it...
- jvdz
I totally agree and felt the same way when I started using Git, coming from a simple SVN versioning setup.Thuis wrote: Wednesday 17 December 2025 15:36 Thanks, i tried my best, lots of steps and if you never used it, like me, it is a bit overwhelming, so thank you very much for pointing me in the right direction. I hope all is received in good order and everyone can use it...
That's why I spent a little time explaining it to you.
I would never want to go back and use it also for all my domoticz scripting to keep a log of all changes I made over time and track them in a local gitbucket server.
lost
I'm probably indirectly at the source of this issue, as I did a PR on this weeks ago:waltervl wrote: Tuesday 16 December 2025 20:55 Did you make a PR for this so everyone can make use of it? Else you can change this after every update....
https://github.com/domoticz/domoticz/pull/6462
But this was much closer to previous script than what was finally changed by Gizmocuz: He asked me to test this but I don't have a beta test system anymore and this was finally IMHO over-engineered vs my quite simple & straightforward proposal (zero-IA inside) I already tested (up to what can be tested without possibility to do the full path including nominal beta archive/download).
IMO, best would be to revert changes for now if no-one available to fix this. The recent PR does many shortcuts, just bypass the changes dedicated to have up-to-date requirements checks that was the reason for change, and would just be unsafe for many users.
cdg0112358
last updatebeta overwrites "domoticz.sh" and "updatebeta"
(lost my changes like user and program directory and the use of sudo)
local ENV file maybe?
I think when @gizmocuz is back from his trip it will be solved. We have to be pcient. The PR of @Thuis seems to be a littble bit too much of a simplification. The script has to work on various linux distros.
As the update scripts gets updated by the update script it is important to keep trying to update from a stable version as the majority of the users are going to do this....
- Thuis
Yes it is better not letting me do PR, haha.
Better wait indeed. Thanks anyway
- gizmocuz
In beta 17003 I now always force Domoticz to stop.
This should hopefully solve the problem, but this can only be testen when there is a new update...
- Thuis
- Spoiler: show
Why does webgui update does not stop and start the service correctly and cli update with ./updatebeta (or ./updaterelease) does it correctly?gizmocuz wrote: Tuesday 06 January 2026 1:49 In beta 17003 I now always force Domoticz to stop.
Re: beta update error over webgui
updating from beta 16997 to beta 17003 still fails over webgui (not sure the change is in it.)
Updating from 17003 to 17030 also did not fix this.....Same error.waltervl wrote: Wednesday 07 January 2026 0:00 updating from beta 16997 to beta 17003 still fails over webgui (not sure the change is in it.)
pfloryann
- Domoticz version: 2025.2
Updating from 17030 to 17031 don't work from webui(reaches 100% but the update does not occur)...works only with sudo ./updatebeta
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5
sudo service domoticz restartpfloryann wrote: Thursday 15 January 2026 9:21 Updating from 17030 to 17031 don't work from webui(reaches 100% but the update does not occur)...works only with sudo ./updatebeta
should also fix it after an error after the webgui update (as a workaround)
In latest beta the webgui update issue has been fixed.
pfloryann
Issue from build 17051 to 17053 ...on github the tichet was closed
- gizmocuz
Yes, you need to be on the last beta to have the web update working again.
So it could you need to use the manual method one more time
Users browsing this forum: jvdz and 1 guest
