First of all, thank you for the continued development of Domoticz. It has become a core part of my home automation system.
I would like to request an enhancement to the electricity cost configuration, specifically around dual (or multi-rate) tariffs.
While Domoticz supports dual tariff pricing, the time-of-day switching is not configurable, which makes it impossible to accurately model many real-world electricity contracts.
The Problem
Many electricity providers offer tariffs where the price depends on the time of day, not just a tariff flag.
Example:
• Off-peak rate: £0.065 / kWh between 00:00–05:00
• Peak rate: £0.22 / kWh outside those hours
Currently in Domoticz:
• Two prices can be defined
• The hours during which each price applies cannot be defined
• This prevents Domoticz from calculating accurate energy costs
This is especially problematic for EV charging, heat pumps, and battery storage that intentionally run during off-peak hours.
Proposed Feature / Solution
Add support for time-based tariff definitions.
Suggested approach:
• Allow users to define one or more time ranges
• Assign a price per kWh to each time range
Example configuration:
• 00:00–05:00 → £0.065 / kWh
• 05:00–00:00 → £0.22 / kWh
Optional future extensions:
• Multiple time bands per day
• Different pricing for weekdays vs weekends
• Seasonal tariff schedules
Benefits
• Accurate energy cost tracking
• Better support for time-of-use electricity tariffs
• Improved usefulness of statistics and dashboards
• Reduced need for external scripts or manual correction
Use Case
In my setup, a significant portion of electricity usage is deliberately shifted to off-peak hours. While Domoticz records energy consumption correctly, the financial cost is incorrect due to the lack of time-based pricing, limiting the usefulness of long-term reporting.
Closing
I believe this feature would significantly improve Domoticz’s energy monitoring capabilities and benefit many users on dual-rate or time-of-use tariffs.
Thank you for your consideration. I would be happy to test or provide feedback if needed.
Best regards,
[Paul Jefferson]
Feature Request: Time-based Dual Tariff Electricity Pricing for Accurate Energy Cost Calculation
pauljefferson
- Domoticz version: 2026.3
Re: Feature Request: Time-based Dual Tariff Electricity Pricing for Accurate Energy Cost Calculation
Hi Paul, when enabling the Domoticz dynamic tariff option you can load the current tarif into a device and use that for cost calculation. Also you can load future tarifs into a user variable and use that for planning you usage or planning charge your battery.
There are already some integrations that load energy tarifs automatically (like Enever, Dutch only) so costs are calculated and you can plan on day ahead tarifs (per hour).
See wiki https://wiki.domoticz.com/Application_S ... alculation
Here you have an example: viewtopic.php?t=42935
And here is an example dzvents script:
Prerequisite: A Dummy Custom Sensor of type Custom and set to costs created from the Dummy Hardware. Note down the exact name of this device (e.g., "Current Energy Tariff"). https://wiki.domoticz.com/Dummy_for_vir ... tom_Sensor
You can use this device in the Cost calculation settings in menu Setup-Settings, tab Counters.
timer = {
-- Update the tariff every 30 minutes to prevent ugly time-out of sensor
'every 30 minutes'
execute = function(domoticz)
-- Configuration variables
local tariffDeviceName = 'Current Energy Tariff' -- Replace with your custom sensor name
local highPrice = 0.313136 -- Your high tariff price in EUR/kWh
local lowPrice = 0.194744 -- Your low tariff price in EUR/kWh
-- Define tariff schedule: Low tariff between 22:00 (10 PM) and 07:00 (7 AM), and all weekend
local isLowTariff = false
if (domoticz.time.matches('between 22:00 and 07:00')) or (domoticz.day == 'Saturday') or (domoticz.day == 'Sunday') then
isLowTariff = true
local currentPrice
if isLowTariff then
currentPrice = lowPrice
currentPrice = highPrice
-- Update the Domoticz custom sensor with the current price
local tariffDevice = domoticz.devices(tariffDeviceName)
-- Use updateCustomSensor(value) for custom sensors
tariffDevice.updateCustomSensor(currentPrice)
domoticz.log('Energy tariff updated to: ' .. currentPrice .. ' EUR/kWh', domoticz.LOG_INFO)
