With docker exec you can enter the container and install inside the container. To make this persistent you can use customstart.sh. This is explained in the wiki.
See https://wiki.domoticz.com/Docker
problem installing SolarEdge ModbusTCP plugin
BartSr
- Domoticz version: V2024.7
Re: problem installing SolarEdge ModbusTCP plugin
I know Janni, one day this will happen but 1st I need to get the plugin work.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2025.1
Read the general instructions in the wiki. On recent OS python uses virtual environments (venv). Domoticz Docker is Setup as a virtual environment so there you do not need to do something special.
For Domoticz not running in docker you need to setup a python virtual environment and install the modules inside that.
A python author made a nice instruction for that, it is linked in the wiki https://wiki.domoticz.com/Using_Python_ ... ules_fails
jannl
- Domoticz version: 2025.5.x
But that is way easier with docker. The python environment in de container is already prepared.BartSr wrote: Wednesday 24 December 2025 19:39 I know Janni, one day this will happen but 1st I need to get the plugin work.
