Enever: managed Counter kWh -> 1..24 scale for price index?
renerene
Post by renerene »
Has anybody written a script that can destilate kWh position scale 1-24 out of a manager counter device??
Let's say i want to charge my car on the 6 cheapest hours of the day. It would be handy for that use case to have a device that holds the position of current hourly price: 1 for the cheapest, 24 for the most expensiven kWh hour. Than it would be easy to program with kWh scale described above:
if kWhPosition<7 then chargeEV=ON else chargeEV=OFF
I'm struggling reading history values of my 'Daily Electricity Price' managed counter, that's why i'm asking.
Here's my old script, as inspiration:
function getKwhOrderPosition(hour)
            if hour < 0 or hour > 23 then
                dz.log('Invalid hour value: '..hour, dz.LOG_ERROR)
                return nil
            local kwhOrder = {}
            for i = 0, 23 do
                if kwh[i] then
                    local order = 1
                    dz.log("nr, value=" .. i..':'..kwh[i], dz.LOG_INFO)
                    for j = 0, 23 do
                        if kwh[j] and kwh[j] < kwh[i] then
                            order = order + 1
                    kwhOrder[i] = order
                    dz.log("position=" .. order, dz.LOG_INFO)
                    kwhOrder[i] = 0
            return kwhOrder[hour]
            local currentHourPosition = getKwhOrderPosition(dz.time.hour)
            dz.log("currentHourPosition=" .. currentHourPosition, dz.LOG_INFO)
Jeakes
Domoticz version: 2021.1
Re: Enever: managed Counter kWh -> 1..24 scale for price index?
Post by Jeakes »
I made a script that calculates over 24 hours which hours are the cheapest.
You need to adjust these parameters:
local switchIdx = 478 -- IDX of your switch
local managedCounterIdx = 470 -- IDX of the managed counter ever
local percentage_goedkoop = 0.72 -- percentage of hours (0.8 is 80%) is the cheapest
I managed it with great difficulty and chatgpt with my buddy.
Succes
script.txt
(6.65 KiB) Downloaded 39 times
gizmocuz
Post by gizmocuz »
For a general rule that does not involve any calculations
Winter: between 01.00am-06.00am
Summer: between 11.00am-17.00pm
For battery charging there must be done quite a lot more (price difference, multiple charge/discharge slots in a day etc)
But trust me on the above, these timeslots are perfect for your car.
Sometimes the price/kWh is so high that you don't want to charge it (but sometimes you have to), this could be a simple check (if price > xx then don't charge)
On my personal github project page I have scripts (nodeJS) that does a good calculation for battery charge hours (but this is based on a price difference)
Kedi
Post by Kedi »
Put hour and price in an array.
Loop over the array and find the lowest price.
Take 2 or more hours before the lowest price and than 2 or more hours after the lowest price.
This should give you a timespan of 4 or more hours in which prices are relative low.
@Jeakes Why run it every minute?
Jeakes
Post by Jeakes »
For test every minute, after that every hour
renerene
Post by renerene »
Ah, you are using a JSON call to fetch log history data
        local function fetchHourlyData(idx)
            local url = dz.settings['Domoticz url'] ..
                        "/json.htm?type=graph&sensor=counter&idx=" .. idx ..
                        "&range=day"
            dz.openURL({
                url = url,
                method = "GET",
                callback = "hourlyPriceData"
That makes it relative complex, the dzVent script needs to be splitted in two sections: make the call and examine the results.
For me, this is not worth it for the moment to re-program for Enever. I'm using my old script that defines the 1..24 price index value per hour based on general Entsoe prices. And use the Enever plugin for exact price.
Wish there would be an easier way to access log data with dzVents. I can see some great functionality here, also in other use cases.
something like device.getHistory (IDX, date) would be great.
Trust me, when you're a nerd this will not do.
Sometime price is different in weekends. Sometimes it is between winter and summer (spring). Sometimes tI want my car to charge a little bit, using three hours of the cheapest hours. Sometimes I need full power setting my "charge hours" variable to 24.
gizmocuz
Post by gizmocuz »
I guess it depends on the type of battery in your car.
There are two types:
- one that needs to be discharged to 20% and charge to 80% (or similar percentages)
- one that needs to be topped all the time. So put it on the charger and charge whenever possible
You need to know the type of your car, because threading the battery wrong, will decrease its life!
Mine (and probably most batteries today) have the first type.
So, I try to plugin when I reach about 20% (or when I have a long tripped planned the next day), so I need to charge,
and then you should use the above timeslots.
NMC:
https://www.youtube.com/watch?v=w4lvDGtfI9U
LFP:
https://www.youtube.com/watch?v=w1zKfIQUQ-s
And really, the difference between the price of a 3 hour slot and a 5/6 hour slot is cents!
Keep it simple, i'm a nerd as well but have other things to worry about ;-)
hjzwiers
Post by hjzwiers »
I have Enever running with the API key.
I installed a managed counter and a switchIdx accoriding to your instructions:
local switchIdx = 3103 -- IDX van je schakelaar
local managedCounterIdx = 3102 -- IDX van de managed counter
I also tried Enever's managed counter 2977, same error
I tried running your script, but i keep getting the following errors:
2025-11-13 14:32:00.156 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=gra ... &range=day
2025-11-13 14:32:00.267 Error: dzVents: Cheap Hours Script: HTTP/1.1 response: 404 ==>> Not Found
2025-11-13 14:32:00.267 Error: dzVents: Cheap Hours Script: Fout bij ophalen van gegevens van Domoticz.
I wonder why it is so difficult to get a running script from domoticz ......I am running domoticz in a container managed by dockge
Last edited by hjzwiers on Thursday 13 November 2025 14:56, edited 1 time in total.
Domoticz version: 2025.1
API calls have changed since 2023: https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
http://127.0.0.1:8080/json.htm?type=graph&sensor=counter&idx=3102&range=day
should be
http://127.0.0.1:8080/json.htm?type=command&param=graph&sensor=counter&idx=3102&range=day
hjzwiers
Post by hjzwiers »
Thanks for the quick answer! That was it. When will getting the data on a 15 minute basis be made available in Domoticz?
I had to use the managed counter of Enever.
hjzwiers wrote: Thursday 13 November 2025 15:07 When will getting the data on a 15 minute basis be made available in Domoticz?
No idea, until someone feels the urge to use the quarterly updates and has development skills.......
Henielma
Domoticz version: 2025.2
Post by Henielma »
To collect the 15 min prices via Enever I made a DzVents script to place this info in a user variable. This information I use to control a home battery to charge at the cheapest 11 kwarters of a day and discharge at the most expensive kwarters a day.
The EneverGet DzVents script can be used by other as inspiration to collect the kwarter prices from Enever.
See the attached file for the script. Fill in your own token and create the user variable "StroomprijsMorgen" and it should work.
EneverGet.txt
(3.29 KiB) Downloaded 11 times
hjzwiers
Post by hjzwiers »
I just integrated the script of the hourly prices, and that script also locates the lowest prices ...... maybe later, need to get some experience with it first
hjzwiers
Post by hjzwiers »
I added StroomprijsMorgen as a uservariable and my token was added, but i still get the following error:
2025-11-17 16:36:00.193 Error: dzVents: Enever stroomprijs: Kon JSON niet parsen uit StroomprijzenMorgen
Ik heb StroomprijzenMorgen ook als user variable toegevoegd, maar dat was hem niet ....
Henielma
Post by Henielma »
How do the user variables look like? Is it something like this:
Schermafbeelding 2025-11-17 225838.png (117.97 KiB) Viewed 134 times
Or is your StroomprijsMorgen empty?
hjzwiers
Post by hjzwiers »
I turned StroomprijzenMorgen into StroomprijsMorgen, but still the error.
I checked the https site and I receive the site with the data.
but i still get 2025-11-17 23:15:00.272 Error: dzVents: Enever stroomprijs: Kon JSON niet parsen uit StroomprijzenMorgen.
What else can it be?
hjzwiers
Post by hjzwiers »
I think I got it to work.
How do you readout a managed counter? I'm working on it, i see the values in the variable logging
Henielma
Post by Henielma »
I do not completely understand what you want to know but probably the following code part helps you:
            local jsonString = domoticz.variables('StroomprijsVandaag').value
            if hourNow >= cyclus2Tot then -- gebruik vanaf 22 uur de StroomprijsMorgen informatie
                jsonString = domoticz.variables('StroomprijsMorgen').value
                hourNow = "00"
            -- JSON decoderen
            local data = domoticz.utils.fromJSON(jsonString)
            if not data then
                domoticz.log("Kon JSON niet decoderen: " .. tostring(jsonString), domoticz.LOG_ERROR)
                return
            local entries = {}      -- Plaats de json data tot 10 uur in de ochtend in een lua structuur
            local dataUur = cyclus1Vanaf
            for _, e in ipairs(data) do
                dataUur = string.sub(e.datum, 12, 14)  -- kopieer het uur van de dataregel in dataUur
                if (dataUur < cyclus1Tot and hourNow < cyclus1Tot) or (dataUur >= cyclus1Tot and dataUur < cyclus2Tot and hourNow >= cyclus1Tot) then -- domoticz.time.matchesRule('at 0:01-9:59') Afhankelijk van de huidige tijd de uren tot 10 uur gebruiken of die van 10 tot 22 uur
                    table.insert(entries, {d = e.datum, v = tonumber(e.prijsTI)})
            -- sorteren op prijs v
            table.sort(entries, function(a, b) return a.v < b.v end)
