Python Plugin: Volvo EV
mvveelen
Re: Python Plugin: Volvo EV
Post by mvveelen »
Sorry, haven't done anything with Github. At least not for the last years.
diff --git a/plugin.py b/plugin.py
index ead9b6d..ff2300d 100644
--- a/plugin.py
+++ b/plugin.py
@@ -314,52 +314,52 @@ def CheckRefreshToken():
         else:
             Debug("Not logged in, retrying in "+str(MINTIMEBETWEENLOGINATTEMPTS-(time.time()-lastloginattempttimestamp))+" seconds")
-def VolvoAPI(url,mediatype):
+def VolvoAPI(url, mediatype):
     global vin
-    Debug("VolvoAPI("+url+","+mediatype+") called")
+    Debug("VolvoAPI(" + url + "," + mediatype + ") called")
     try:
-        starttime=datetime.datetime.now()
+        starttime = datetime.datetime.now()
         status = requests.get(
             url,
-            headers= {
+            headers={
                 "accept": mediatype,
                 "vcc-api-key": vccapikey,
                 "Authorization": "Bearer " + access_token
             timeout=TIMEOUT
-        endtime=datetime.datetime.now()
+        endtime = datetime.datetime.now()
         Debug("\nResult:")
         Debug(status)
-        Debug("Result took "+str(endtime-starttime))
+        Debug("Result took " + str(endtime - starttime))
         try:
             resp_json = status.json()
         except Exception as json_error:
-            Error("Response from "+url+" is not valid JSON: "+str(json_error))
-            output=status.text
-            Error("Raw response: "+output)
-            UpdateTextSensor(Parameters["Name"],APISTATUS,APISTATUSNAME,f"API Error: {output}")
+            Error("Response from " + url + " is not valid JSON: " + str(json_error))
+            output = status.text if status is not None else ""
+            Error("Raw response: " + output)
+            UpdateTextSensor(Parameters["Name"], APISTATUS, APISTATUSNAME, f"API Error: {output}")
             return None
         if status.status_code != 200:
-            Error("VolvoAPI failed calling "+url+", HTTP Statuscode "+str(status.status_code))
-            Error("Response: "+json.dumps(resp_json, indent=4))
+            Error("VolvoAPI failed calling " + url + ", HTTP Statuscode " + str(status.status_code))
+            Error("Response: " + json.dumps(resp_json, indent=4))
akamming
Post by akamming »
mvveelen wrote: Friday 07 November 2025 21:31 Sorry, haven't done anything with Github. At least not for the last years.
--- a/plugin.py
+++ b/plugin.py
         else:
     global vin
     try:
             url,
-            headers= {
+            headers={
             timeout=TIMEOUT
         Debug("\nResult:")
         Debug(status)
         try:
             return None
I see what you did, i made a similar change now in the repository (but gives a bit more info tot the API Error field). I cannot test, since i never have this issue, so please update your plugin to the latest code and let me know the results...
mvveelen
Post by mvveelen »
Done, but after a while:
2025-11-08 10:54:32.875 Error: Volvo: Call to function 'onHeartbeat' failed, exception details:
2025-11-08 10:54:32.878 Error: Volvo: Traceback (most recent call last):
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1712, in onHeartbeat
2025-11-08 10:54:32.878 Error: Volvo: _plugin.onHeartbeat()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1677, in onHeartbeat
2025-11-08 10:54:32.878 Error: Volvo: Heartbeat()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1426, in Heartbeat
2025-11-08 10:54:32.878 Error: Volvo: UpdateDevices()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1388, in UpdateDevices
2025-11-08 10:54:32.878 Error: Volvo: UpdateLastKnownLocation()
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~~~~~~~~~~~^^
2025-11-08 10:54:32.878 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1332, in UpdateLastKnownLocation
2025-11-08 10:54:32.878 Error: Volvo: TripSpeed=int(((Triplength*1000.0)/TripDuration.total_seconds())*3.6)
2025-11-08 10:54:32.878 Error: Volvo: ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2025-11-08 10:54:32.878 Error: Volvo: ZeroDivisionError: float division by zero
akamming
Post by akamming »
mvveelen wrote: Saturday 08 November 2025 11:48 Done, but after a while:
Could you switch on debugging and post the full plug-in logging?
Btw: this is all just attacking the symptoms. Your real issue is that you have connectivity issues. Are you still working on that?
EDIT:
Just to be safe, i made some handling around this division... so pls upgrade to latest version.
My remark on the connection issue still stands, now in some connection error cases it will now report some sensors to 0 instead of the real value, cause due to the connection issue which prevents it from getting data. So you get less errors in the log, but your issue is not solved
mvveelen
Post by mvveelen »
I've updated just now, but I don't know why there are connectivity issues like you say. The NUC is connected by wire and I have a fast internet connection via KPN (glass). Could it be that I poll the server too often? I've got the interval set to every 60 seconds.
akamming
Post by akamming »
mvveelen wrote: Sunday 26 October 2025 10:58 I've migrated my Domoticz installation from a Raspberry Pi 3B+ to a NUC. Everything is working fine now, also the Volvo plugin.
But.
Once in a while I see a bunch of errors although the plugin is working fine.
What can be the cause of it and....what could be the solution to prevent these errors (which I didn't have on my RPi)? I could, of course, switch off error logging, but that's not a solution.
Update interval is (unchanged): 60
The errors:
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~~~~~^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/ssl.py", line 1304, in recv_into
2025-10-26 10:30:01.490 Error: Volvo: return self.read(nbytes, buffer)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~^^^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/ssl.py", line 1138, in read
2025-10-26 10:30:01.490 Error: Volvo: return self._sslobj.read(len, buffer)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: ConnectionResetError: [Errno 104] Connection reset by peer
2025-10-26 10:30:01.490 Error: Volvo: During handling of the above exception, another exception occurred:
2025-10-26 10:30:01.490 Error: Volvo: Traceback (most recent call last):
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 667, in send
2025-10-26 10:30:01.490 Error: Volvo: resp = conn.urlopen(
2025-10-26 10:30:01.490 Error: Volvo: method=request.method,
2025-10-26 10:30:01.490 Error: Volvo: ...<9 lines>...
2025-10-26 10:30:01.490 Error: Volvo: chunked=chunked,
2025-10-26 10:30:01.490 Error: Volvo: )
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in urlopen
2025-10-26 10:30:01.490 Error: Volvo: retries = retries.increment(
2025-10-26 10:30:01.490 Error: Volvo: method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 474, in increment
2025-10-26 10:30:01.490 Error: Volvo: raise reraise(type(error), error, _stacktrace)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/util/util.py", line 38, in reraise
2025-10-26 10:30:01.490 Error: Volvo: raise value.with_traceback(tb)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in urlopen
2025-10-26 10:30:01.490 Error: Volvo: response = self._make_request(
2025-10-26 10:30:01.490 Error: Volvo: conn,
2025-10-26 10:30:01.490 Error: Volvo: ...<10 lines>...
2025-10-26 10:30:01.490 Error: Volvo: **response_kw,
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 534, in _make_request
2025-10-26 10:30:01.490 Error: Volvo: response = conn.getresponse()
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 516, in getresponse
2025-10-26 10:30:01.490 Error: Volvo: httplib_response = super().getresponse()
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/http/client.py", line 1430, in getresponse
2025-10-26 10:30:01.490 Error: Volvo: response.begin()
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/http/client.py", line 331, in begin
2025-10-26 10:30:01.490 Error: Volvo: version, status, reason = self._read_status()
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/http/client.py", line 292, in _read_status
2025-10-26 10:30:01.490 Error: Volvo: line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3.13/socket.py", line 719, in readinto
2025-10-26 10:30:01.490 Error: Volvo: return self._sock.recv_into(b)
2025-10-26 10:30:01.490 Error: Volvo: urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 323, in VolvoAPI
2025-10-26 10:30:01.490 Error: Volvo: status = requests.get(
2025-10-26 10:30:01.490 Error: Volvo: url,
2025-10-26 10:30:01.490 Error: Volvo: ...<5 lines>...
2025-10-26 10:30:01.490 Error: Volvo: timeout=TIMEOUT
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/api.py", line 73, in get
2025-10-26 10:30:01.490 Error: Volvo: return request("get", url, params=params, **kwargs)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
2025-10-26 10:30:01.490 Error: Volvo: return session.request(method=method, url=url, **kwargs)
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 589, in request
2025-10-26 10:30:01.490 Error: Volvo: resp = self.send(prep, **send_kwargs)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 703, in send
2025-10-26 10:30:01.490 Error: Volvo: r = adapter.send(request, **kwargs)
2025-10-26 10:30:01.490 Error: Volvo: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 682, in send
2025-10-26 10:30:01.490 Error: Volvo: raise ConnectionError(err, request=request)
2025-10-26 10:30:01.490 Error: Volvo: requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1712, in onHeartbeat
2025-10-26 10:30:01.490 Error: Volvo: _plugin.onHeartbeat()
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1677, in onHeartbeat
2025-10-26 10:30:01.490 Error: Volvo: Heartbeat()
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1426, in Heartbeat
2025-10-26 10:30:01.490 Error: Volvo: UpdateDevices()
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1372, in UpdateDevices
2025-10-26 10:30:01.490 Error: Volvo: GetLocation() #Location must be known before GetRechargeStatus te detect local charging and to detect if carhasmoved
2025-10-26 10:30:01.490 Error: Volvo: ~~~~~~~~~~~^^
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 1104, in GetLocation
2025-10-26 10:30:01.490 Error: Volvo: Location = VolvoAPI("https://api.volvocars.com/location/v1/vehicles/" + vin + "/location", "application/json")
2025-10-26 10:30:01.490 Error: Volvo: File "/home/marco/domoticz/plugins/Domoticz_VolvoRecharge_Plugin/plugin.py", line 359, in VolvoAPI
2025-10-26 10:30:01.490 Error: Volvo: output=status.text
2025-10-26 10:30:01.490 Error: Volvo: ^^^^^^
2025-10-26 10:30:01.490 Error: Volvo: UnboundLocalError: cannot access local variable 'status' where it is not associated with a value
It's this logging what start this, The "ConnectionResetError: [Errno 104] Connection reset by peer" is the actual error which happens on your system.
This means that something (the “peer”) abruptly closes the TCP connection while your the plugin was trying to read or write data.
The domoticz Python plugin is making an HTTPS request to the Volvo API, The Volvo server (or something in between) sent a TCP RST packet, forcefully ending the connection. So the reset does not happens in Domoticz or Python.
I've asked chatgpt, and 2 possible causes:
- TLS/SSL issues (Some APIs require modern TLS versions or SNI support. Outdated Python versions or requests libraries can fail to negotiate properly.)
- or a router, proxy, or firewall might reset idle or long-running connections.
mvveelen
Post by mvveelen »
No errors since the latest update. Yet.
Edit: ik zag zojuist dat de NUC de netwerkverbinding mocht sluiten (auto), dat heb ik aangepast naar ON. Misschien lag daar wel de oorzaak....
