I found it on the internet - maybe it can be inspiring for someone.
https://raw.githubusercontent.com/rwbl/ ... rkbook.pdf
I just discovered that it's already in the thread:
viewtopic.php?t=26874
But I haven't come across it here myself yet, so maybe someone will rediscover it like I did.
Domoticz Home Automation Workbook
kimot
- Domoticz version: v3.8153
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
- psubiaco
Re: Domoticz Home Automation Workbook
Good to know a book exists. I believe it should be linked inside the www.domoticz.com website as like as Domoticz Wiki!
Paolo
lost
+Author allowed this for wiki (on waaren request, the year before he passed away), according to this post:psubiaco wrote: Sunday 02 November 2025 23:56 Good to know a book exists. I believe it should be linked inside the www.domoticz.com website as like as Domoticz Wiki!
viewtopic.php?p=239835#p239835
- Domoticz version: 2025.1
It is already long time on the Wiki https://wiki.domoticz.com/Domoticz_workbook_(external)
But it is already 5 years old and not changed since first publication. A lot has changed in Domoticz since then... So use with common sense.
- lemassykoi
I'm trying to update Domoticz Wiki, but I'm unable to login.
I recovered my account from MediaWiki, but I'm unable to login with my username and password from mediawiki.
and when clicking on "Help with logging in", it opens a webpage on mediawiki.org, where I'm already logged in.
Any idea? Thanks.
Any idea? Thanks.
You have to send a PM to gizmocuz to create or reactivate an account.
What do you want to edit on the wiki?
- lemassykoi
Thanks.
On the page https://wiki.domoticz.com/Developing_a_ ... vice_Types
there is an error about sensor type 29
"sValue are two numbers separated by semicolon like "123;123456" The first number is the actual power in Watt, the second number is actual energy in kWh."
it's not in kWh but in Wh
Fixed, thanks for reportinglemassykoi wrote: Wednesday 05 November 2025 13:58 Thanks.
