Domoticz install Raspberry5 (Debian Bookworm) failed
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pbcnf
Post by pbcnf »
Hello.I'm trying to install Domoticz 2025-2 on my raspberry 5 Debian Bookworm (2025_9_16). After launching the installation script (install_domoticz.sh) which checks the prerequisites, I arrive in a menu informing me that Domoticz needs a static address. From there, it's impossible to click "OK" to continue the installation. I was connected with ssh, but suspecting an emulator problem, I tried with a keyboard and mouse directly connected to the raspberry via USB, but the same result. So it's impossible to go further with the installation. No problem with other menus like raspi-config. I tried with a previou :( s version (2024) but it's the same thing. Kind regards.
Domoticz version: 2025.1
Re: Domoticz install Raspberry5 (Debian Bookworm) failed
You ran this command?
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
pbcnf
Post by pbcnf »
Thanks for your answer. I ran with with the command "sudo curl -L install.domoticz.com | bash" . But that' ok now with your command :
sudo bash -c "$(curl -sSfL https://install.domoticz.com)" . I don't know why , but thanks a lot.
I wonder who told you that old instruction as this command is both on the download page and wiki for ages.
https://www.domoticz.com/downloads/
https://wiki.domoticz.com/Raspberry_Pi# ... asy%22_way
Users browsing this forum: Dave21w and 1 guest
