Zigbee2mqqt docker fails
Rob67ert
Post by Rob67ert »
After a new install, like to update to Domotics 2025.2 I get the following error:
docker: Error response from daemon: failed to set up container networking: driver failed programming external connectivity on endpoint zigbee2mqtt (414d1b4cbf9384b9de4016aabe6b4d8ec448211972ba2654f6dc5bc72458bf8d): failed to bind host port 0.0.0.0:8080/tcp: address already in use
How can I solve this?
Domoticz version: 2025.1
Re: Zigbee2mqqt docker fails
So you have to configure zigbee2mqtt to another port eg 8090. Port 8080 probably used by Domoticz already.
See also the note on this on the wiki https://wiki.domoticz.com/Zigbee2MQTT
Perhaps also read the other notes :-)
