How to view the output of a persistant data filter function?
Ray-Man
Domoticz version: 2021.1
Post by Ray-Man »
Hello all,
Breaking my head over the following:
I have a persistent data table.
this code:
print('Today item 01 = '..dz.data.TMPTODAY.get(1).data[1]..', '..dz.data.TMPTODAY.get(1).data[2])
print('Today item 48 = '..dz.data.TMPTODAY.get(48).data[1]..','..dz.data.TMPTODAY.get(48).data[2])
print('Today item 96 = '..dz.data.TMPTODAY.get(96).data[1]..','..dz.data.TMPTODAY.get(96).data[2])
Provides this output:
Today item 01 = 2025-10-05 00:00:00, 0.1477
Today item 48 = 2025-10-05 11:45:00, 0.1452
Today item 96 = 2025-10-05 23:45:00, 0.152
From this list I only want to filter future data (or filter out previous data per now). I tried..
local MyVar = dz.data.TMPTODAY
    local VanafNu = MyVar.filter(function (item)
        return (dz.time.dateToDate(item.data[1], 'yyyy-mm-dd hh:MM:ss', 'yyyy-mm-dd hh:MM:ss', 0) >= dz.time.rawDateTime)
        end)
... and it doesn't give any errors, followed by code to at least show the filtered data in the log.
I tried (new line after 'end)')
print('TEST OUTPUT = '..VanafNu)
print('TEST OUTPUT = '..VanafNu[1])
but all I get is
lua:214: attempt to concatenate a table value (local 'VanafNu')
lua:214: attempt to concatenate a nil value (field '?')
How to access the filtered data?
Domoticz version: 2025.1
Re: How to view the output of a persistant data filter function?
I never used the filter function of dzvents but it looks like it is not designed for your use case.
And the Domoticz time object is a real complex object as it is a kind of a table also.
So perhaps you have to create your own filter function.
Ragdag
Post by Ragdag »
Ray-Man wrote: Sunday 05 October 2025 17:57 Hello all,
this code:
        end)
but all I get is
Give this a try - I'm not 100% sure but I believe this is the issue:
The .filter() method returns a new historical data object (a table), not a simple value. You can't concatenate it directly with a string, and you need to use the same accessor methods (.get(), .size, etc.) as on the original data.
Here's how to properly access the filtered data:
local VanafNu = MyVar.filter(function(item)
    return item.data[1] >= dz.time.rawDateTime
end)
-- Check how many items passed the filter
print('Filtered count: ' .. VanafNu.size)
-- Access individual items using .get()
if VanafNu.size > 0 then
    print('First future item: ' .. VanafNu.get(1).data[1] .. ', ' .. VanafNu.get(1).data[2])
-- Or iterate through all filtered items
VanafNu.forEach(function(item)
    print('Future: ' .. item.data[1] .. ', ' .. item.data[2])
end)
A few notes:
  1. Since your datetime strings are already in yyyy-mm-dd hh:MM:ss format, they're lexicographically sortable. You can compare them directly as strings against dz.time.rawDateTime without the dateToDate conversion.
  2. The filtered result behaves like the original historical data object. Use .get(n) to access items, .size for the count, and .forEach() for iteration.
  3. Why your attempts failed:
    • ..VanafNu - Can't concatenate a table
    • ..VanafNu[1] - The object uses .get(1) not [1] for access
Let us know if this works!
