Since changing the tick to standard mode Domoticz can no longer read the frames, the speed is indeed 9600bps with Domoticz in version 2024.7.
2025-09-27 05:30:26.641 Error: TeleinfoSTD: CRC check failed on Teleinfo line 'SMAXIN E208& 00 00!116 0 !' using both modes 1 and 2. Line skipped.
2025-09-27 05:30:26.671 Error: TeleinfoSTD: CRC check failed on Teleinfo line 'CA E09"#000' using both modes 1 and 2. Line skipped.
2025-09-27 05:30:26.749 Error: TeleinfoSTD: CRC check failed on Teleinfo line '01901 0 00RQQ12!27#0 3$SGE 013A0!:' using both modes 1 and 2. Line skipped.
2025-09-27 05:30:26.857 Error: TeleinfoSTD: CRC check failed on Teleinfo line 'NJOUBF00' using both modes 1 and 2. Line skipped.
2025-09-27 05:30:26.879 Error: TeleinfoSTD: CRC check failed on Teleinfo line 'NOEB+ @J' using both modes 1 and 2. Line skipped.
2025-09-27 05:30:27.160 Error: TeleinfoSTD: CRC check failed on Teleinfo line ' 0 1$ 0 2 0NNULENONUTILE OAAA NELENEE NONUT@C3160#5 TC 02 JATE E25 96 00 FF @ LE ^D010#71!*AC01 00' using both modes 1 and 2. Line skipped.
2025-09-27 05:30:27.370 Error: TeleinfoSTD: CRC check failed on Teleinfo line 'A0 1 0033!7C0000#82AC0 498 DES 0 710EAS0000 0 0 00 9 0 *AF 0 0 "ED1 126#90' using both modes 1 and 2. Line skipped.
I'use this device Bus 001 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port / Mobile Action MA-8910P with electronic assembly
Thank you for your help
Teleinfo mode standart
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
suisk1ptitmotard
