...running for more than 10 seconds
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Filnet
Domoticz version: 2025.2 ß
Post by Filnet »
For some time now, I have been consistently receiving this message every time the automatic backup starts:
2025-09-26 08:00:00.565 Status: Starting automatic database backup procedure...
2025-09-26 08:00:02.604 Status: Ending automatic database backup procedure...
2025-09-26 08:00:10.321 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
gizmocuz
Re: ...running for more than 10 seconds
Post by gizmocuz »
Probably the database backup takes a lot of time.
Maybe your database is very large (check why this is...)
You could also have a script that wants to access the database frequently and it cannot because a backup is being made
I would disable the automatic backup feature at all, and once in a while make a backup from the settings page
Filnet
Post by Filnet »
Thank you for your help.
I solved my problem: Two of my process used 'osCommand'. I converted them in asynchronous mode.
Users browsing this forum: Mithrandir99 and 1 guest
