database details
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
BartSr
Domoticz version: V2024.7
database details
Post by BartSr »
hi!
anyone who can point me to table/column of:
-timers of switches and the enable/disable timer switch
-same for switching notifications on off
thanks
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
Re: database details
Use the APIs for this.
BartSr
Post by BartSr »
Thanks Walter.
Can you give me some more specific info?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
gizmocuz
Post by gizmocuz »
Have a look at the documentation here
https://wiki.domoticz.com/Domoticz_API/JSON_URL%27s
BartSr
Post by BartSr »
thanks Rob. Lot to dig in
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
I digged into the API and found e.g. for timers the command:
/json.htm?type=command&param=getschedules&filter=device
That's nice! But now I'm looking for the syntax to set e.g. active to false
Can I use this command?
/json.htm?type=command&param=updatetimer&idx=timerID&active=true&timertype=3&hour=0&min=20&randomness=true&command=0&days=12345</source>
So I can retrieve a full overview of all timer schedules. Did I miss same for notifications? (something like GetAllNotifications).
Or did I overlook that.
Thanks so far again.
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
NO, first retrieve the timers and states with the getschedules command.
Then you can enable or disable the timer you want with the call
/json.htm?type=command&param=enabletimer&idx=timerID
Or
/json.htm?type=command&param=disabletimer&idx=timerID
BartSr
Post by BartSr »
Thanks Walter. Any idea about 2nd Q?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Read the timer/schedules section of the API wiki
https://wiki.domoticz.com/Domoticz_API/ ... _Schedules
It is all there.
BartSr
Post by BartSr »
Walter, maybe you missed that 2nd Q is about notifications.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
There is a notifications section in the API wiki https://wiki.domoticz.com/Domoticz_API/ ... ifications
BartSr
Post by BartSr »
Thanks Walter
I am looking for a command that lists ALL notifications just as is possible for timerschedules
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
There seems no such query, only per device.
It is also not needed for the normal user interface as notifications are only handled per device.
The API is created for linking the web user interface with the core program.
Users browsing this forum: Xenomes and 1 guest
