Clicking the widget for turning on (for example) the fan causes the fan to come on straight away, so message from domoticz to mqtt to z2m is working pretty much instantly but the widget does not change state, the time it takes to reflect the current device state seems to change, for instance while typing this I timed it and it took 1 min 10 sec for the widget to update. Refreshing the browser or even opening the Domoticz UI on another PC still shows the widget to be showing the incorrect state. This only seems to relate to zigbee devices, I have never seen the issue with anything running Tasmota. If you have switched something on and the widget is stuck in off you then cannot switch it off becuse every press of the widget says switching on.
Any ideas clever people as it's driving me nuts
