Version: 2025.1 - though has been like this for as long as I can remember.
Platform: Debian trixie LXC on proxmox 9.0.3
Plugin/Hardware: Humidity sensor
Description: Searched th eforum and can't find any mention of this: - A humidity only sensor also has temperature in history graphs, and only displays temperature, which there is no data for, until changed to humidity in the browser, the comparing graph is always blank as it only displays temperature, which there is no data for, humidity is not displayed, or displayable.
Humidity only sensor has temperature artefacts. Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2025.1
Re: Humidity only sensor has temperature artefacts.
I created a PR to remove the temperature labels in the log charts of a Humidity only device: https://github.com/domoticz/domoticz/pull/6373
When @Gizmocuz approves it will be in the next following beta after that.
It will not fix the missing compare charts as that is currently only defined for Temperature data in these kind of devices. It was a little bit out of my comfort zone to implement that. Perhaps somebody else can fix this.
aardwolf2
Thanks for fixing.
It is fixed now in latest 2025 beta, including the compare function with big thanks to @gizmocuz
aardwolf2
<Bill and Ted>Excellent!</Bill and Ted>
Cheers all.
