integration ismartgate in domoticz
Filnet
Domoticz version: 2025.2 ß
Post by Filnet »
Has anyone done this?
Thank you for your help.
Domoticz version: 2025.1
Re: integration ismartgate in domoticz
There is a python module for this device so it could be implemented with a Python plugin.
https://github.com/bdraco/ismartgate
If you lack python plugin knowledge you can make a simple python script and have a virtual Domoticz device switch the gate/door.
You should make another python script that polls the status of the gate/door and push the data to Domoticz.
Filnet
Post by Filnet »
Thank you, waltervi.
I have seen this python plugin.
I will try this solution.
Perhaps an idea is to use AI (chatgpt, copilot etc) to try to create a Domoticz python plugin for it using the existing python module. No idea how it works out but it is the trend.....
I did the experiment with Copilot. Not tested so I am wondering it will work:
iSmartGate DomoticzEx Python Plugin
This plugin uses the DomoticzEx framework to integrate your iSmartGate-managed garage doors and gates into Domoticz as Switch devices. It handles login, discovery, command execution, and state synchronization via heartbeat.
Installation
0. Install the python ismartgate module
pip3 install ismartgate
1. Navigate to your Domoticz plugins folder and create a new directory:
cd ~/domoticz/plugins
mkdir ismartgate
2. Save the below mentioned plugin code content as plugin.py in folder
~/domoticz/plugins/ismartgate
3. Restart Domoticz:
sudo systemctl restart domoticz
4. In Domoticz Setup → Hardware, add a new hardware item:
Type: iSmartGate
Address: <iSmartGate_HOST_OR_IP[:PORT]>
Username: your iSmartGate account email
Password: your iSmartGate password
Mode1: Heartbeat interval in seconds (default 30)
5. Click Add.
Switch devices will be created for each gate/door.
plugin.py code
<plugin key="ismartgate" name="iSmartGate" author="Walter" version="1.0" externallink="https://github.com/bdraco/ismartgate">
  <description>
    <h2>iSmartGate Integration (DomoticzEx)</h2>
    Discover and control all your iSmartGate garage doors and gates as Domoticz switches.
  </description>
  <params>
    <param field="Address"  label="iSmartGate Host/IP[:Port]"      width="200px" required="true"/>
    <param field="Username" label="Username (email)"              width="200px" required="true"/>
    <param field="Password" label="Password"                      width="200px" required="true" password="true"/>
    <param field="Mode1"    label="Heartbeat Interval (seconds)"  width="50px"  required="true" default="30"/>
  </params>
</plugin>
import DomoticzEx as D
import ismartgate
class Plugin(D.Plugin):
    def __init__(self):
        super().__init__()
        self.gate = None
        self.unit_map = {}
    def onStart(self):
        D.Log("iSmartGate Plugin starting")
        host     = D.Parameters["Address"]
        user     = D.Parameters["Username"]
        pwd      = D.Parameters["Password"]
        interval = D.intParam("Mode1", 30)
        D.Heartbeat(interval)
        try:
            self.gate = ismartgate.ISmartGate(host)
            self.gate.login(user, pwd)
            D.Log("Logged in to iSmartGate")
        except Exception as e:
            D.LogError(f"Login failed: {e}")
            return
        try:
            self.gate.get_devices()
            unit = 1
            for dev_id, dev in sorted(self.gate.devices.items()):
                name = dev.friendly_name or f"Gate {dev_id}"
                if unit not in D.Devices:
                    D.Device(Unit=unit, Name=name, TypeName="Switch").Create()
                    D.Log(f"Created device {unit}: {name}")
                self.unit_map[unit] = dev_id
                unit += 1
            D.LogError(f"Device discovery failed: {e}")
    def onHeartbeat(self):
        if not self.gate:
            return
        try:
            for unit, dev_id in self.unit_map.items():
                device = D.Devices[unit]
                state  = self.gate.devices[dev_id].state
                nVal   = 1 if state else 0
                sVal   = str(nVal)
                if device.nValue != nVal:
                    D.Log(f"Updating {device.Name} → {'On' if nVal else 'Off'}")
                    device.Update(nValue=nVal, sValue=sVal)
            D.LogError(f"Heartbeat error: {e}")
    def onCommand(self, Unit, Command, Level, Hue):
        if Unit not in self.unit_map or not self.gate:
            return
        dev_id = self.unit_map[Unit]
        try:
            if Command == "On":
                D.Log(f"Opening device {dev_id}")
                self.gate.open(dev_id)
            elif Command == "Off":
                D.Log(f"Closing device {dev_id}")
                self.gate.close(dev_id)
            else:
                D.Log(f"Ignored unsupported command: {Command}")
            D.LogError(f"Command error: {e}")
# Create plugin instance
global _plugin
_plugin = Plugin()
def onStart():     _plugin.onStart()
def onStop():      _plugin.onStop()
def onHeartbeat(): _plugin.onHeartbeat()
def onCommand(Unit, Command, Level, Hue): _plugin.onCommand(Unit, Command, Level, Hue)
Filnet
Post by Filnet »
I tried this procedure, but I had to add the argument "--break-system-packages" to pip3 to complete the installation.
$ pip3 install ismartgate --break-system-packages
Installing collected packages: ismartgate
Successfully installed ismartgate-5.0.2
But, I got the following error:
$ ismartgate
  File "/home/pi/.local/bin/ismartgate", line 5, in <module>
    from ismartgate.cli import ismartgate_cli
  File "/home/pi/.local/lib/python3.11/site-packages/ismartgate/__init__.py", line 17, in <module>
    from httpx import AsyncClient, RemoteProtocolError, Response
ImportError: cannot import name 'AsyncClient' from 'httpx' (/usr/local/lib/python3.11/dist-packages/httpx-1.0.dev1-py3.11.egg/httpx/__init__.py)
Strangely, when I install ismartgate on another, blank Pi (without Domoticz and other add-ons), ismartgate works fine...
That other system were ismartgate is running is also using Python 3.11?
Filnet
Post by Filnet »
Yes,
python 3.11.2 (on the two Raspberry)
Perhaps try
sudo pip3 install ismartgate --break-system-packages
Filnet
Post by Filnet »
I had already this.
I try again now...
The error message is always the same.
I have no real other option. Probably an interference/incompatibility with another python module you have installed on the system...
Filnet
Post by Filnet »
I keep your plugin, case of I found the key of my problem.
I do step by step a full installation of my domotic on the second Pi.
Filnet
Post by Filnet »
Hello waltervi,
...It's me!
I solved my problem: I deleted the folder httpx and reinstall with pip3 ...
Now "ismartgate" works fine.
But... plugin.py make issues:
2025-07-25 16:11:55.556 Error: iSmartGate: (ismartgate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/ismartgate/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/usr/local/lib/python3.11/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.11/dist-packages'.
2025-07-25 16:11:55.577 Error: iSmartGate: Exception: 'SyntaxError'. No traceback available.
No idea, I am not a plugin author, just asked AI to create one... Perhaps check with existing plugins if something is incorrect.or ask AI :)
FlyingDomotic
Post by FlyingDomotic »
AI is not smart enough to understand that this is a pyton file, and that first par should be a comment.
Let's try with:
  <description>
  </description>
  <params>
  </params>
</plugin>
import ismartgate
    def __init__(self):
        super().__init__()
        self.gate = None
        self.unit_map = {}
    def onStart(self):
        try:
            return
        try:
            unit = 1
                unit += 1
        if not self.gate:
            return
        try:
                sVal   = str(nVal)
            return
        try:
            if Command == "On":
            else:
global _plugin
_plugin = Plugin()
Filnet
Post by Filnet »
Thanks Flyingdomoticz.
Effectively, your plugin appears in the Hardware's list with the comment header.
But the following of the plugin is not good. The plugin don't find some libraries.
I solved the problem by using os_execute and processing the received response in a dzvents and a device switch 'Door Lock'.
This device command open or close.
I received info every minute for the state Opened/Closed.
I would like that the icon of the Device is update with this info but if I use 'domoticz.devices(DVCE_SWITCH).switchOn().checkFirst()', it's triggers a command. I would want only change the icon, not send a command.
Is'it a solution?
I know it's possible to change icon but I don't where they are.
In dzventz add .silent to the switch command eg
domoticz.devices(DVCE_SWITCH).switchOn().checkFirst().silent
It will not trigger further actions.
Filnet
Post by Filnet »
Fantastic!!
I hav'nt sawn this add in the doc!
Users browsing this forum: Gianluca and 1 guest
