CLuaHandler: cannot open watermeter.lua: No such file or directory
hjzwiers
CLuaHandler: cannot open /opt/domoticz/userdata/scripts/lua_parsers/watermeter.lua: No such file or directory
But the file is in /opt/stacks/domoticz/config/scripts/lua/watermeter.lua
I have made the location and file available, but no result. That why I need it through MQTT
- Domoticz version: 2025.1
Re: CLuaHandler: cannot open watermeter.lua: No such file or directory
If you are running from docker: check your volumes. You probably have to make an extra link to /opt/domoticz/userdata/scripts (but I am no docker expert....)
eddieb
volumes:
- ./config:/opt/domoticz/userdata
- ./config/www/templates:/opt/domoticz/www/templates
what I put in ./config/scripts/lua appears in /opt/domoticz/userdata/scripts/lua
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
hjzwiers
I think i understand ...
I put the line in the config file, added the script in /opt/stacks/domoticz/config/scripts/lua/watermeter.lua
and restarted, but I still get: CLuaHandler: cannot open /opt/domoticz/userdata/scripts/lua_parsers/watermeter.lua: No such file or directory
you should put it in
/opt/stacks/domoticz/config/scripts/lua_parsers/watermeter.lua
You can check what happens if you login to the container with
and list the contents of folder /opt/domoticz/userdata/scripts/lua_parsers
docker exec -it domoticzCode: Select all
ls -l /opt/domoticz/userdata/scripts/lua_parsersDomoticz running on Udoo X86 (on Ubuntu)
eddieb
hmm,
my directory has a different name ...
root@domoticz2:~# docker exec -it domoticz bash
root@domoticz:/opt/domoticz# ls -l /opt/domoticz/userdata/scripts/lua/
total 132
-rw-r--r-- 1 root root 69100 Jun 12 14:00 JSON.lua
-rw-r--r-- 1 root root 12387 Jun 12 14:00 XmlParser.lua
drwxr-xr-x 2 root root 4096 Jun 12 14:37 garbagecalendar
-rw-r--r-- 1 root root 1870 Jun 12 14:00 script_device_demo.lua
-rw-r--r-- 1 root root 1932 Jun 12 14:00 script_time_demo.lua
-rwxr-xr-x 1 root root 21692 Jun 12 14:00 script_time_garbagecalendar.lua
-rw-r--r-- 1 root root 5968 Jun 12 14:00 xml2lua.lua
drwxr-xr-x 2 root root 4096 Jun 12 14:00 xmlhandlerRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
hjzwiers
The point is that I don't have that directory, and if I make it it doesn't work!
/opt/stacks/domoticz/config/scripts/lua/watermeter.lua: this directory is made by the system : same problem as @eddieb
I don't know what you mean with getting direct entrance to the directory .....
And what if you create it from within the container?
hjzwiers
I,d like to try, can you lead me through the process please?
Please do the following:
waltervl wrote: Thursday 12 June 2025 17:22 what happens if you login to the container withand list the contents of folder /opt/domoticz/userdata/scripts/lua_parsersCode: Select all
hjzwiers
hjz@debian:/opt/stacks/domoticz$docker exec -it domoticz
docker: 'docker exec' requires at least 2 arguments
Usage: docker exec [OPTIONS] CONTAINER COMMAND [ARG...]
See 'docker exec --help' for more information
I did it from the docker directory, but it is asking for more arguments?
eddieb
docker exec -it domoticz bashRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
hjzwiers
I had to use: sudo docker exec -it domoticz bash
i was within the docker: root@355aab15c8a9
ls -l /opt/domoticz/userdata/scripts/lua_parsers : response was "No such file or directory"
I then made the directory lua_parsers and copied the file into it.
Ran domoticz and it worked!!
I got domoticz-solaredge also working that way! Good learning point!
You have to be aware you have to do this everytime you update the Domoticz Docker image!
hjzwiers
Thanks for the heads up.
I've now edited most of the plugins within the docker file, I don't know if that's the way, but it got domoticz-solaredge started up.
