date in the data persistent
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pierrotori
Domoticz version: 2024.4
Post by pierrotori »
when i use the command dz.data.stat_xxxx.add and i check the date in the data persistent file, i have this
["xxxx"] = {
[1] = {
["time"] = "2025-1-7 19:30:0.343";
["data"] = "blabla";
the problem is the time must be 20:30 and not 19:30
my rpi and container docker are at the right time
Could you check your time in data persistent file?
Pierrotori
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2025.1
Re: date in the data persistent
Why is it a problem?
It probably is UTC time that is stored in the file as that is common practice.
pierrotori
i have a delta of 2 hours with the new version
["mesure"] = {
[1] = {
["time"] = "2025-6-12 19:15:2.427";
["data"] = 1;
in the docker-compose i put TZ=Europe/Paris and the date in the container is up
root@af0c9761cdcc:/opt/domoticz# date
Thu Jun 12 21:15:09 CEST 2025
i would like to have the same date in the data persistent and the date system
Then you probably have to write a persistent file yourself.
Why do you want the exact correct time in that file? As it is possibly not designed to have the exact time in that file but the UTC time. The time in that file is only needed to calculate time differences to manage the size of data fields
