Dockge and Zigbee not running
hjzwiers
I have set this up in Dockge:
services:
zigbee2mqtt:
container_name: zigbee2mqtt
image: ghcr.io/koenkk/zigbee2mqtt
restart: unless-stopped
volumes:
- ./data:/app/data
- /run/udev:/run/udev:ro
ports:
# Frontend port
- 8099:8099
environment:
- TZ=Europe/Amsterdam
devices:
# Make sure this matched your adapter location
- /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_cc03fed5943aef11aca9331455516304-if00-port0:/dev/ttyUSB0
networks: {}
with my config file:
version: 4
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://192.168.2.71:1883'
user: hjz
password: 7184!@#$
serial:
port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_cc03fed5943aef11aca9331455516304-if00-port0
adapter: ember
advanced:
log_level: info
channel: 11
network_key: GENERATE
pan_id: GENERATE
ext_pan_id: GENERATE
frontend:
enabled: true
package: zigbee2mqtt-frontend
port: 8099
homeassistant:
enabled: true
onboarding: true
It says "service device services.zigbee2mqtt.devices.[0] is missing a mount target" and I cannot connect to the front end ...... Do you have an idea what is wrong?
services:
zigbee2mqtt:
volumes:
- ./data:/app/data
ports:
# Frontend port
- 8099:8099
environment:
devices:
networks: {}
version: 4
mqtt:
user: hjz
password: 7184!@#$
serial:
adapter: ember
advanced:
log_level: info
channel: 11
pan_id: GENERATE
frontend:
enabled: true
port: 8099
homeassistant:
enabled: true
onboarding: true
- Domoticz version: 2026.3
Re: Dockge and Zigbee not running
I think you should skip DockGe for now and concentrate on getting Domoticz and Zigbee2MQTT running as Docker containers (without DockGe)
eddieb
I doubt it has anything to do with Dockge ... Just a docker management interface. `
The yml can be started from cli as normal docker
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Port for the USB in the zigbee2mqtt config should be /dev/ttyUSB0 and not /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_cc03fed5943aef11aca9331455516304-if00-port0
So from your system the docker translates
into
/dev/ttyUSB0
Then in your config of zigbee2mqtt within the docker container you should use /dev/ttyUSB0. The /dev/serial/by-id/ is unkown for zigbee2mqtt in the zigbee2mqtt docker container.
into
/dev/ttyUSB0
eddieb
Ok, below my compose.yml for zigbee2mqtt
starting this gives the following log
suggestions are welcome
services:
zigbee2mqtt:
dns_search: .
environment:
volumes:
- ./data:/app/data
ports:
# frontend port
- 8888:8888
devices:
- /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D9C37B-if00:/dev/ttyUSB0
group_add:
- dialout
# user: 1000:1000
networks: {}Code: Select all
Using '/app/data' as data directory
Starting Zigbee2MQTT without watchdog.
[2025-06-10 20:36:20] info: z2m: Logging to console, file (filename: log.log)
[2025-06-10 20:36:20] info: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #aec59cb774aa09a793ae41cd60e6a5cef15b293c
[2025-06-10 20:36:20] info: z2m: Starting zigbee-herdsman (4.0.0)
[2025-06-10 20:36:20] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-06-10 20:36:25] info: zh:zstack:znp: Serialport opened
[2025-06-10 20:37:30] error: z2m: Error while starting zigbee-herdsman
[2025-06-10 20:37:30] error: z2m: Failed to start zigbee-herdsman
[2025-06-10 20:37:30] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-06-10 20:37:30] error: z2m: Exiting...
[2025-06-10 20:37:30] error: z2m: Error: AREQ - ZDO - stateChangeInd after 60000ms
at Object.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/utils/waitress.ts:67:23)
at ZnpAdapterManager.beginStartup (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:279:27)
at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:370:13)
at ZnpAdapterManager.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:87:21)
at ZStackAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:104:13)
at start (/app/index.js:149:5)
Container stoppedRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
- Varazir
this is my setup https://gist.github.com/varazir/65909bd ... 41aef37103
Now day's when I get an error I past it into chatgpt or Gemini and usually get good answer back.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
hjzwiers
the right settings are full version in the compose file (dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_cc03fed5943aef11aca9331455516304-if00-port0:/dev/ttyUSB0) and the short version (port: /dev/ttyUSB0) in the config file.
Its working now, thanks. I have the data in the remote viewer, now to get them in domoticz ..... (I have auto MQTT Auto Discovery on but still wonder where the sensors are .....)
- Varazir
Screenshot your settings for the auto MQTT Auto Discovery settings in Domoticz..
This is mine. I hade some issue suing local host and 172.0.0.1 so I use the IP my pie get from my router.
- Varazir
hjzwiers wrote: Tuesday 10 June 2025 22:11 the right settings are full version in the compose file (dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_cc03fed5943aef11aca9331455516304-if00-port0:/dev/ttyUSB0) and the short version (port: /dev/ttyUSB0) in the config file.
Remote viewer you mean you connect to your MQTT server with MQTT explorer ?
eddieb
running mqtt-explorer in docker on your docker host
compose.yaml
compose.yaml
services:
mqtt-explorer:
container_name: mqtt-explorer
image: smeagolworms4/mqtt-explorer
dns_search: .
ports:
- 4000:4000
volumes:
- ./config:/mqtt-explorer/config
networks: {}
- gizmocuz
MQTT Explorer is a GUI application
Don't just copy/paste any AI generated stuff here
https://mqtt-explorer.com/
The setup files from Varazir are a good start, but this is not the best way to work with docker compose
1. For each project you create a folder
2. In this folder you make a file 'docker-compose.yml' where you place the config in
3. You use local volume folders, that is, they will be created inside this folder, so you can easily make a backup
For example
volumes:
- ./data:/app/path/data
4. You test it first inside this folder with
docker compose up (without the -d flag, so you see all messages)
5. Once you are sure all is working, stop the docker (control-c)
docker compose down
docker compose stop
6. Now run the docker as a background deamon
docker compose up -d (with the -d flag)
This is all basic stuff, there are tons of web pages with tutorials
A AI bot will not be a tutorial, just use your google search phrase and add 'tutorial' or 'example' behind it
For example
volumes:
docker compose down
docker compose stop
- Varazir
Ya I should note that it's very specific where I store my data. I liked to have all data in the home folder. Start with ./ is standard and dockge takes care of the creating the folder.gizmocuz wrote: Wednesday 11 June 2025 7:54 MQTT Explorer is a GUI application
For example
volumes:
docker compose down
docker compose stop
eddieb
Yeah, same here.
all my docker stuff is in /opt/stacks/
each in its own directory
all can be started from cli with docker compose up -d but I prefer dockge
I am still busy trying to get everything working the way I like to have it, especially some python stuff is giving me some problems.
# ls -al /opt/stacks/
total 60
drwxr-xr-x 15 root root 4096 May 30 10:34 .
drwxr-xr-x 5 root root 4096 May 22 18:53 ..
drwxr-xr-x 3 root root 4096 Jun 11 06:40 dockge
drwxr-xr-x 3 root root 4096 Jun 5 11:19 domoticz
drwxr-xr-x 2 root root 4096 May 22 18:55 dozzle
drwxr-xr-x 2 root root 4096 May 30 10:32 iperf-server
drwxr-xr-x 4 root root 4096 May 25 09:51 monit
drwxr-xr-x 5 1883 1883 4096 May 22 20:06 mosquitto
drwxr-xr-x 3 root root 4096 May 25 09:01 mqtt-explorer
drwxr-xr-x 3 root root 4096 May 22 20:11 node-red
drwxr-xr-x 2 root root 4096 May 30 08:39 openspeedtest
drwxr-xr-x 3 root root 4096 May 30 10:34 portainer
drwxr-xr-x 3 root root 4096 May 22 19:59 tasmoadmin
drwxr-xr-x 2 root root 4096 May 22 18:58 watchtower
drwxr-xr-x 3 root root 4096 Jun 10 22:10 zigbee2mqttRPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
