Is it possible to change only the value of a variable via a JSON command?
Instead of:
/json.htm?type=command¶m=updateuservariable&idx=1&vname=VariableName&vtype=2&vvalue=NewValue
Use:
/json.htm?type=command¶m=updateuservariable&idx=1&vvalue=NewValue
or:
/json.htm?type=command¶m=updateuservariable&idx=1&vtype=2&vvalue=NewValue
for example?
It's very easy to change the variable name by accident when creating JSON commands on other devices
Change variable value only via JSON
- Domoticz version: 2564
Re: Change variable value only via JSON
Not sure how this is solved?
Nobody ever answered me...
Nor Me
I've trying to change the thermostat setpoint on a device through JSON. I'm going to experiment, there is a page on this stuff but I sort of expected a bit more detail. its in my JSON Post
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
the page is at http://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
- Domoticz version: 2022.2
Below how I change a uservariable of type string
http://ip:port/json.htm?type=command¶m=updateuservariable&idx=12&vname=test&vtype=0&vvalue=0
- Domoticz version: 4.11605
I can't set my setpoint.
This is what I have, I try to send;
http://192.168.178.25:8080/json.htm?typ ... e=SetPoint;
I send 33 degrees, Data and Setpoint changed to zero (0.0) degrees.
Do I something wrong?
To get the values works perfect with this script;
$json_string = file_get_contents("http://192.168.178.25:8080/json.htm?typ ... es&rid=$id");
$parsed_json = json_decode($json_string, true);
$parsed_json = $parsed_json['result'][0];
$q = $parsed_json[$item];
Gigabyte with Debian, 4 Shelly's 2.5 (rollerblinds), 3 Shelly's dimmers, 3 Shelly plugs,
8 x DB1820, ESPeasy with 8 relay's, RFXcom, Enocean USB300, 2 x Enocean STM 330.
to the question from cjnicholl
According to the source code, you have to provide all the variables:
if (idx.empty() || variablename.empty() || variablevalue.empty() || variabletype.empty())
return;
return;
