Yes on 2.4.0. I just repeated this all again, stopped z2m docker, disabled the MQTT Auto Discovery hardware item in Dz, deleted all discovery topics and base topics from the broker using Mqtt Explorer. I also deleted all devices relating to the airfilter in the Dz device list.
Then I restarted the z2m container and let it create all the discovery and base topics. I then enabled the MQTT Auto Discovery hardware item in Dz and let the device be re-discovered. The new Starkwind devices were created, including a selector switch for the fan speed and a custom sensor also for the fan speed.
These topics were created on the broker...
zigbee2mqtt/starkwind airfilter
{"air_quality":"hazardous","child_lock":"UNLOCK","device_age":799097,"fan_mode":"7","fan_speed":7,"fan_state":"ON","filter_age":348351,"identify":null,"led_enable":true,"linkquality":15,"pm25":152,"replace_filter":true,"update":{"installed_version":69633,"latest_version":69633,"state":"idle"}}
and
z2m/fan/0x2c1165fffea5bcac/fan/config
{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/starkwind airfilter/set/fan_state","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x2c1165fffea5bcac"],"manufacturer":"IKEA","model":"STARKVIND air purifier","model_id":"E2007","name":"starkwind airfilter","sw_version":"1.1.001","via_device":"zigbee2mqtt_bridge_0x00124b002298908f"},"name":null,"object_id":"starkwind_airfilter","origin":{"name":"Zigbee2MQTT","sw":"2.4.0","url":"https://www.zigbee2mqtt.io"},"percentage_command_template":"{{ {0:'off', 1:'1', 2:'2', 3:'3', 4:'4', 5:'5', 6:'6', 7:'7', 8:'8', 9:'9'}[value] | default('') }}","percentage_command_topic":"zigbee2mqtt/starkwind airfilter/set/fan_mode","percentage_state_topic":"zigbee2mqtt/starkwind airfilter","percentage_value_template":"{{ {'off':0, '1':1, '2':2, '3':3, '4':4, '5':5, '6':6, '7':7, '8':8, '9':9}[value_json.fan_mode] | default('None') }}","preset_mode_command_topic":"zigbee2mqtt/starkwind airfilter/set/fan_mode","preset_mode_state_topic":"zigbee2mqtt/starkwind airfilter","preset_mode_value_template":"{{ value_json.fan_mode if value_json.fan_mode in ['auto'] else 'None' | default('None') }}","preset_modes":["auto"],"speed_range_max":9,"speed_range_min":1,"state_topic":"zigbee2mqtt/starkwind airfilter","state_value_template":"{{ value_json.fan_state }}","unique_id":"0x2c1165fffea5bcac_fan_zigbee2mqtt"}
I changed the speed directly on the fan hardware and this change was reflected in z2m, mosquitto and Dz. Then I went to change the fan to level 4 and instead it turned "off" with the error again ...
Zigbee MQTT: Climate device invalid/unknown preset_mode received! (0x2c1165fffea5bcac_fan_zigbee2mqtt: [object object])
On the broker after this appeared..
{"fan_mode":4}
But the fan switched off and in Dz it changed to off and in z2m it changed to off. Curiously there is an extra "On/Off" switch endpoint in z2m which doesn't appear in Dz. If I switch this (and not the "fan mode" endpoint) in the z2m GUI the fan will turn on. It will also turn on in z2m using the fan speed selector.
