Failed to load 'plugin.py'
pfloryann
Domoticz version: 4.1
Post by pfloryann »
HI,
i upgraded to debian 12 and domoticz beta 2025.1 (build 16703) and i have this errors:
2025-05-22 16:38:11.612 Error: Purificator Xiaomi: (AirPurifier) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-AirPurifier/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/usr/local/lib/python3.11/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.11/dist-packages'.
2025-05-22 16:38:11.829 Error: Purificator Xiaomi: Traceback (most recent call last):
2025-05-22 16:38:11.829 Error: Purificator Xiaomi: File "/home/pi/domoticz/plugins/domoticz-AirPurifier/plugin.py", line 73, in <module>
2025-05-22 16:38:11.829 Error: Purificator Xiaomi: import miio.airpurifier
2025-05-22 16:38:11.829 Error: Purificator Xiaomi: ModuleNotFoundError: No module named 'miio'
2025-05-22 16:38:12.683 Error: Broadlink RM4C: (Broadlink) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Broadlink/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/usr/local/lib/python3.11/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.11/dist-packages'.
Thank you!
Domoticz on Raspberry Pi 4 with Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy
Domoticz version: 2024.7
Re: Failed to load 'plugin.py'
Seems you have to re install the python module/ requirements. See the instructions in on the plugin repository.
See also wiki https://wiki.domoticz.com/Using_Python_ ... ules_fails
And also viewtopic.php?t=42960
pfloryann
Post by pfloryann »
No result.
I trying to install the broadlink plugin on fresh domoticz and i have this:
error.txt
(18.95 KiB) Downloaded 18 times
pfloryann
Post by pfloryann »
I fixed.
So if you have this error:
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
I entered
sudo rm /usr/lib/python3.11/EXTERNALLY-MANAGED
