Need help with script value
hemant5400z
Post by hemant5400z »
Hi All,
I'm trying to get data from General Kwh (Enphase) plugin.
local Produktiekwh = dz.devices(339)
however i'm getting error: attempt to perform arithmetic on a table value (local 'Produktiekwh')
I'm trying to pull value from: "Data" : "8865.927 kWh".
tried:
Produktiekwh = dz.devices(339).counter
Produktiekwh = dz.devices(339).Svalue
Any help appreciated, i know noob question :(
Thanks in advance
Hemant
Domoticz version: 2026.3
Re: Need help with script value
See wiki section kWh, Electricity (instant and counter) as that is the general kWh Sensor
https://wiki.domoticz.com/DzVents:_next ... d_counter)
.actualWatt: Number. Actual usage in Watt.
.counterToday: Number.
.updateElectricity(power, energy): Function. Supports command options.
.usage: Number.
.WhToday: Number. Total Wh usage of the day. Note the unit is Wh and not kWh!
.WhTotal: Number. Total Wh usage.
.WhActual: Number. Actual reading in Watt. Please use actualWatt
So it depends exactly what you want but I think it is WhTotal: Number. Total Wh usage.
Then the dzvents line should be
local Produktiekwh = dz.devices(339).WhTotal
Tukker
Domoticz version: 2023.2
Post by Tukker »
Try dz.devices(339).dump()
or maybe better, try this script
=== DOMOTICZ DEBUG HELPER SCRIPT ===
Geschreven voor dzVents 3.0+
Laatste update: 2024-06-15
FUNCTIES:
1. Toont systeeminformatie (Domoticz/dzVents versie)
2. Inspecteert devices (basisinfo + volledige structuur)
3. Toont tijdberekeningen (datum, zonnetijden)
4. Werkt via switch of custom event trigger
GEBRUIK:
1. Zet 'YourSwitchSelector' aan/uit om te triggeren
OF
2. Gebruik commando: dzVents.emit('DebugRequest')
CONFIGURATIE:
- Pas de TEST_DEVICES lijst aan voor je eigen devices
- Zet LOG_LEVEL op LOG_ERROR voor productie
-- Configuratieblok (buiten execute aanpasbaar)
local TEST_DEVICES = {
    'Power',
    --'TFA1 kamer',
    --'YourSwitch',
    --'YourTextSensor',
    --'Zonnepanelen',
    --'SmartEVSE'
local LOG_LEVEL = domoticz.LOG_DEBUG  -- LOG_ERROR voor productie
local TRIGGER_DEVICE = 'YourSwitchSelector'
-- Script hoofdstructuur
    active = true,
        devices = { TRIGGER_DEVICE },
        customEvents = { 'DebugRequest' },
        timer = {
            'every 1 minutes' -- every  x minutes
    logging = {
        level = LOG_LEVEL,
        marker = 'DEBUG HELPER',
    execute = function(dz, item)
        -- ===== SYSTEEMINFO =====
        dz.log('\n=== SYSTEEMINFORMATIE ===', dz.LOG_INFO)
        dz.log('Domoticz versie: ' .. (dz.settings.domoticzVersion or "Onbekend"), dz.LOG_INFO)
        dz.log('dzVents versie: ' .. (dz.utils.DZVERSION or "Onbekend"), dz.LOG_INFO)
        -- ===== DEVICE INSPECTIE =====
        dz.log('\n=== DEVICE INSPECTIE ===', dz.LOG_INFO)
        for _, devName in ipairs(TEST_DEVICES) do
            local device = dz.devices(devName)
            if device then
                dz.log(string.format('\n🛠️  %s (IDX: %d)', devName, device.id), dz.LOG_INFO)
                -- Basis device info
                dz.log('BASIS INFO:', dz.LOG_DEBUG)
                pcall(function() dz.log(device.dump(), dz.LOG_DEBUG) end)
                -- Uitgebreide info
                dz.log('UITGEBREIDE STRUCTUUR:', dz.LOG_DEBUG)
                pcall(function()
                    dz.log(dz.utils.toJSON({
                        name = device.name,
                        state = device.state,
                        lastUpdate = device.lastUpdate.raw,
                        data = device.rawData or "Geen rawData",
                        deviceType = device.deviceType,
                        deviceSubType = device.deviceSubType
                    }), dz.LOG_DEBUG)
                end)
                dz.log('❌ Device niet gevonden: ' .. devName, dz.LOG_ERROR)
        -- ===== TIJD BEREKENINGEN =====
        dz.log('\n=== TIJDGEGEVENS ===', dz.LOG_INFO)
        pcall(function()
            local now = os.date('*t')
            local lastDay = os.date('*t', os.time{year=now.year, month=now.month+1, day=0})
            dz.log('📅 Datum: ' .. os.date('%A %d %B %Y'), dz.LOG_INFO)
            dz.log('⏰ Tijd: ' .. os.date('%H:%M:%S'), dz.LOG_INFO)
            dz.log('🗓️ Laatste dag van de maand: ' .. lastDay.day, dz.LOG_INFO)
            dz.log('🌅 Zon op/onder: ' .. dz.time.sunriseInMinutes .. '/' .. dz.time.sunsetInMinutes, dz.LOG_INFO)
        end)
        dz.log('\n=== DEBUG VOLTOOID ===\n', dz.LOG_INFO)
You can use a virtual switch or the timer to execute the script.
Replace the name under TEST_DEVICES with the nam of your device.
PS
In many programming scripts one users camelCase where nValue and sValue are written like first word starting with lowercase and the second, third party starting in uppercase.
So sValue has a better chance than Svalue.
Bugs bug me.
HvdW wrote: Monday 26 May 2025 14:06 Try dz.devices(339).dump()
Seems to be overkill for something a noob, as Topic Starter claims is, can read in the docs....
hemant5400z
waltervl wrote: Monday 26 May 2025 13:55 See wiki section kWh, Electricity (instant and counter) as that is the general kWh Sensor
.usage: Number.
Ah yes that is what I was after with one minor addition, the
Whtotal is a kind of counter i would like to have
whtotal - whtotal from (18-02-2025) = actual production of contract year :) assuming the value in calendar_meter on 18-02 is 0:00 which is may start date.
hemant
That is possible but not an easy script, I believe there are already scripts available on this subject in this forum.
You generally have to search and summarize all daily total values from your contract date.
Edit: See for example viewtopic.php?t=42454
hemant5400z
Ah yes something similar,
in my case http://xxxx:8080/json.htm?type=command& ... 2026-02-17.
What i get is a large range of daily values, is it possible to do a SUM directly?
Hemant
No, else this would not need a complex script :-)
