Scene active/inactiv switch
swen
Domoticz version: 2025.1
Post by swen »
hi,
I would like to be able to switch a scene between active and inactive with a dummy switch.
I have tested this with this dzVents script:
--Dummy Switch: 'Beschattung Automatik'  Idx: 4269
--Scene       : 'TestSzene'              Idx:   22
local dz        = domoticz
    logging = {
        level = domoticz.LOG_INFO,
        marker = '-----'
        devices = { 'Beschattung Automatik' }
   	execute = function(dz, switch)
        if (dz.devices(4269).active) then
            dz.scenes('TestSzene').active = true
            dz.log('scene true')
            dz.scenes('TestSzene').active = false
            dz.log('scene false')
But it doesn't work, the scene is always active.
The dummy switch works correct. I can see this in the log.
Does anyone know a solution?
jvdz
Domoticz version: 4.107
Re: Scene active/inactiv switch
Post by jvdz »
I haven't tested it but think it should be something like this:
local dz        = domoticz
    logging = {
        marker = '-----'
        if (switch.state == 'On') then
            dz.scenes('TestSzene').switchOn()
            dz.scenes('TestSzene').switchOff()
swen
Post by swen »
I've already tested it. Also after
dz.scenes('TestScene').switchOff()
the timer triggers the scene.
But that's exactly what I want to prevent.
Domoticz version: 2024.7
You cannot inactivate a scene. It can only be activated (switched on). A group can be switched on/off.
https://wiki.domoticz.com/Managing_Devi ... or_Groups)
swen
Post by swen »
Hi, thanks for the info.
I did some more tests and found no other solution.
groups are also unsuitable.
So I will program my five scenes and their timers in dzVenzts.
Thanks and bye
