[2025.1] blinds not working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
studiocascade
Post by studiocascade »
Installed this release yesterday.
Most things are working as expected, unfortunately not everything.
All my sunscreen and roller blinds aren't working anymore.
If I press one of the 'blinds' buttons, there's simply no reaction at all.
Also the connection from my HomeHabit tablet isn't working anymore.
The buttons won't change value anymore.
It looks like an issue with permissions.
I created a different user with admin privileges, but also from that account it's not working.
If someone has an idea for me how to fix this...
Thank you in advance.
Best regards,
Johan
Domoticz version: 2025.1
Re: [2025.1] blinds not working
I splitted this off the general 2025.1 update topic.
What integration do you use for your blinds? As it does not seem to be a permission issue. Do you use action scripts to switch the blinds?
studiocascade
Thanks for splitting it and excuse me for posting it in the wrong place.
Version: 2025.1
Platform: Raspberry Pi - Raspbian 11 (bullseye)
Plugin/Hardware: RFXCom
Description:
While i'm writing this, i think I will have to troubleshoot my RFXCom.
Although i'm sure I used "persistent USB" in the past, it looks like my RFXcom isn't recognized.
I have a mixed environment with ZWave, Mi-light and 433Mhz (KaKu clones).
The Zwave and Mi-light is working fine, but my lights aren't switched on and off automatically anymore by the dusk sensor (KaKu).
The blinds are also 433Mhz.
So i'm going to work on that first. I'll let you know!
Users browsing this forum: Ahrefs [Bot] and 1 guest
