Thanks for the new version, but I have a problem, after the update in the "own" tab it doesn't show me anything from zigbee2mgtt and plugins manager.
Wojtek
[2025.1] custom pages menu not shown Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2025.1
Re: [2025.1] custom pages menu not shown
Do you use docker?
Does the user that logins has access to the custom menu?
Are the htm(l) files of zigbee2mqtt and plugin manager in the domoticz/www/views folder?
wojtech
Thanks for the answer, no it is not in docker, the user has access to the "custom" tab. I do not see such files in this folder. I restored the previous version of domoticz from a copy and everything is ok. When I installed 2025.1 the problem is again, after selecting zigbee2mqtt or python plugins manager only loading appears. Isn't the problem the old version of Python 3.7.3?
What if you restart the plugins? The plugin should copy the html files for their custom menu to the domoticz/www/views folder on startup of the plugin.
Also update the plugins to their latest version as in current Domoticz some old API call have been deprecated and it could be your plugin code is still using them. See the plugin documentation how to update the plugin.
- Domoberry
- Domoticz version: 2024.7
While setting up a new Domoticz system using Docker (Compose) on RPI5, the Custom menu initially did not show. If you are reading this post due to the same issue, note that the Wiki (https://wiki.domoticz.com/Custom_menu) also states you need to:
- enable the Custom menu un Setup/Users
- add your custom .htm(l) file in domoticz/www/templates
- add a mount in the docker-compose.yml file for this directory, like
In my case, this line was already present in the yml file, albeit commented out.
Next, as I understood, 'restarting' the Domoticz docker container will not be sufficient, you need to 'down' and 'up -d' it again to force a reread of the yml file.
./config/domoticz/templates:/opt/domoticz/www/templatesNext, as I understood, 'restarting' the Domoticz docker container will not be sufficient, you need to 'down' and 'up -d' it again to force a reread of the yml file.
Users browsing this forum: BartSr and 1 guest
