This could not have happened without the help of everyone who contributed to make this happen!
Forum moderators, users, beta testers and specially all those who contributed with code! Thank you once again!!!
As always, PLEASE make a FULL backup of your Domoticz folder (or in case of an embedded system, your SD card!)
This way you can always return to the previous version you were running before this update!
Thanks to all volunteers who helped with the implementation! I know it was a lot of work with a lot of stress!
Here are the most important changes (there are way too many changes to list them all):
For a full detailed overview visit:Version 2025.1 (May 5th 2025)
- Implemented: Battery level for Setpoint sensors
- Implemented: Charts, zoom option for 'Day' view
- Implemented: Data Pushers, added P1 actual value
- Implemented: EnOcean, now able to choose an optional base_id as sender_id instead of the chip_id (#6213)
- Implemented: Floorplan, Add support for stop button (Ventation blinds)
- Implemented: RFXCom, Updated SDK
- Implemented: Support for Honeywell Series 5/PIR
- Implemented: Text sensor, now posible to edit direct from the GUI
- Implemented: YouLess, added Water meter
- Implemented: More default icons
- Implemented: MQTT-AD, added support for Gas device class
- Implemented: MQTT-AD, added support for Text device class
- Implemented: MQTT-AD, better precision for kWh sensors
- Implemented: MQTT-AD, enabled 'device_automation' component to be compatible with upcoming (2025) Zigbee2MQTT version
- Implemented: MQTT-AD, handling single onoff color mode as a normal light/switch
- Implemented: MQTT-AD, power sensors for the Tuya SPM02
- Implemented: MQTT-AD, support sensors that report humidity but sends 'null' values
- Implemented: MQTT-AD, support for string field state objects
- Implemented: MQTT Push 'Retained' mode option
- Implemented: Rain devices can now be replacement with different types of rain devices
- Implemented: RFXCom, Falmec Support
- Implemented: RTL433, Support Generic Switch (Door) sensor
- Implemented: Tado, oauth2 support
- Changed: dzVents, possible to pass a Domoticz device ID in notify() through the extra parameter
- Changed: Energy Dashboard now also available for non-admin users
- Changed: Energy Dashboard, Text object clipping rectangle
- Changed: Google Firebase Cloud Messaging (FCM) alternative way to pass a Domoticz device ID through the extra field ('|Device=<devidx>')
- Changed: Internal webserver refactoring
- Changed: Netatmo Improved and automated login process for devices (to obtain client ID and Password with user selectable scopes)
- Changed: Removed Highcharts 'Download PNG/JPG/SVG' buttons until export server is fixed
- Changed: Using OpenStreetMap for Latitude/Longitude query in settings
- Changed: Hardware/User/Application/Variables setup page (update/delete/add buttons)
- Changed: Smoke Detectors are now able (internally) to use keep-alive timestamps
- Fixed: Application shutdown, solved possible crash (#6310)
- Fixed: AtagOne, fixed getting device_id and better debuginfo
- Fixed: Charts, dynamic title based on selected range
- Fixed: Computed Meter summation
- Fixed: Custom Icons, making sure they are valid and loaded OK
- Fixed: Floorplan, corrected open/close icon behaviour
- Fixed: Floorplan, now handles protected selectors
- Fixed: MQTT Push, making sure direct push is working
- Fixed: Possible mutex lock issue when logging
- Fixed: Pushers, corrected Gas value rounding
- Fixed: Python framework, invalid sValue when creating a General/kWh sensor
- Fixed: RFXCom 868 MHz Weather device
- Fixed: RFXCom, WS90 Weather device
- Removed: Thermosmart thermostat (Product no longer supported/available by the manufacturer)
- Removed: API: Old RType calls have been replaced (see also wiki https://wiki.domoticz.com/Domoticz_API/ ... and_newer) )
- Updated: HighCharts
- Updated: Self Signed Certificate (Valid till 2035)
- Updated: Translations
https://github.com/domoticz/domoticz/commits/master/
https://github.com/domoticz/domoticz/bl ... istory.txt
You can also update manually by going to your Domoticz folder and issue the following command: ./updaterelease
Up up and away
If you encounter update issues please start a new topic in the Bugs and Problems subforum viewforum.php?f=6
