Problems upgrading to 2025.1 on Windows11
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
dino
Post by dino »
I have upgraded Domoticz to 2051.1 on Windows 11. When finished to install the configuration not loaded...
Where domoticz save the config? the install overwirte all? :( :( :( there is a way to found the configuration?
Thaks
D.
habahabahaba
Domoticz version: 2024.4
Re: Problems upgrading to 2025.1 on Windows11
Post by habahabahaba »
Did you clear the browser cach?
dino
Post by dino »
Closed and reopen but nothing appear... I need to reload the config
WouterO
Post by WouterO »
Closing and re-opening your browser does not clear the browser cache.
See e.g., https://support.atlassian.com/bitbucket ... nd-safari/
Domoticz version: 2025.1
Alternative is to open Domoticz in a private/incognito browser session. If it shows correctly then you have a browser cache issue before.
dino
Post by dino »
I have reloaded an old config, not the last :-(
There is a way to find the configurations in the directory?
The configuration is in the file domoticz.db which is not over written by an update.
