waltervl wrote: Saturday 10 May 2025 12:35
A RPi4 with a good SD card and a good power supply (!) should do the trick.....
That zigbee is losing nodes should have nothing to do with SD card but with the zigbee controller stick as there the connection is stored.
A bad power supply can give a lot of issues!
Perhaps moving the gpio to esp will also help.
I don't agree in total Walter, I had often issues with the regular SD cards, now im usinf the high endurance and I now sins a single year have strange behaviour again.
Yesterday I restarted the device as as dzvent script of 12 line gave a error on line 17 (the previous attempt) and even the runAfter was constant the issue and already replaced, but kept popping up in the log on that script. So a reboot and tried again, all of a sudden 6 zigbee devices where gone, this morning I had to remove them manually out og z4d and in domoticz, after pairing all worked fine till this afternoon, 5 other devices all of a sudden gone! To me that is strange behaviour! SD cards are a cheap fix to replace.
So thats why i have the question whats a good solution for a steady smart home setup. Btw the powersupply is
This one It only powers the pi4
@sjonnie this mmc card adpter isnt a bad idea! I didnt think of that as a SD replacment.
