reboot multiple times a day
goblin
Domoticz version: 2023.1
Post by goblin »
hello all,
i am running two RPI with domoticz but one is rebooting multiple times a day and can't figure out why.
i have found something on Domoticz troubleshooting about crashlog / signal handling.
Below a snapshot of the lines around the signal_handler.
Thread 2 (Thread 0x6d8ff200 (LWP 4287)):
#0 __waitpid (options=0, stat_loc=0x6d8fde18, pid=4288) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 __waitpid (pid=4288, stat_loc=0x6d8fde18, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
#2 0x006ca0ba in dumpstack_gdb(bool) ()
#3 0x006ca510 in signal_handler(int, siginfo_t*, void*) ()
#4 <signal handler called>
#5 raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#6 <signal handler called>
#7 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#8 0x768d0280 in __GI_abort () at abort.c:79
#9 0x00b81fc0 in __gnu_cxx::__verbose_terminate_handler() ()
#10 0x00b28140 in __cxxabiv1::__terminate(void (*)()) ()
#11 0x00b28196 in std::terminate() ()
#12 0x00a05d92 in boost::asio::detail::posix_thread::func<boost::asio::system_context::thread_function>::run() ()
#13 0x007a5d7e in boost_asio_detail_posix_thread_function ()
#14 0x76adc494 in start_thread (arg=0x6d8ff200) at pthread_create.c:486
#15 0x7698fe98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
domoticz works most of the time but a lot of functions are not e.g. (any timer related switch) turn of after 5 minutes.
help would be very appreciated
goblin
Re: reboot multiple times a day
Post by goblin »
good evening,
i think i have found it.
i am using "Monit Service Manager"
it is running for 10 hours after stopping the monitor.
next challenge is to figure out why.
regards
jvdz
Domoticz version: 4.107
Post by jvdz »
There normally is an monit log where you can see the actions it has taken.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
