Python scripts don't run since upgrading to v2025.1 Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
StratosHF
Domoticz version: 2025.1
Post by StratosHF »
I upgraded from v2024.7 to v2025.1 last night. The upgrade (via the gui) went ok but this morning a few of my tasks didn't run as expected. Looking at the logs I see its related to Python scripts....
2025-05-06 06:10:02.467 Error: Error executing script command (/home/pi/BedroomLED.py). returned: 256
2025-05-06 06:11:01.483 Error: Error executing script command (/home/pi/FrostWarning.py). returned: 256
2025-05-06 06:20:01.784 Error: Error executing script command (/home/pi/LampsAM.py). returned: 256
As an example the scripts are typically called via an on action...
script:///home/pi/FrostWarning.py.
Looking at History.txt, there isn't any obvious changes which would cause a problem. The logs from the restart do state...
2025-05-05 17:47:24.315 Status: PluginSystem: Started, Python version '3.7.3', 1 plugin definitions loaded.
Is it possible that my Python2.7 scripts are now trying to run as Python3 ?
Any thoughts?
Thanks.
Re: Python scripts don't run since upgrading to v2025.1
Could well be, I am surprised python2 scripts even were still running on current environments.
Does the log file mentions anything special when you trigger the on action?
StratosHF
Post by StratosHF »
Fixed it!
The issue was due to my json commands using an out of date command...
/json.htm?type=devices
now needs to be
/json.htm?type=command&param=getdevices
https://wiki.domoticz.com/Domoticz_API/JSON_URL%27s
All my own fault!
