Thx for the information!
Netatmo authentication changes Oct 2022
Re: Netatmo authentication changes Oct 2022
Updated to beta 16626.
Followed instructions on the wiki page.
When I activate the netatmo hardware, i get error "No access granted, forcing login again (Refresh tokens): invalid_grant".
- Thuis
Yes me also, 16626, after a while errors, then in hardware click update and it is correct, for a while. So manually update every 2 to 3 hours or so to keep everything going.sailmich wrote: ↑Tuesday 15 April 2025 14:32Not for me. I'm on domoticz beta 16626. I always get errors after a couple of hours.cadkey wrote: ↑Thursday 10 April 2025 0:23 @JurgenLB fixed the issue here:
https://github.com/domoticz/domoticz/pull/6297To get rid of it I do have to hit the update button for netatmo on domoticz hardware page.
- Spoiler: show
Cheers
2025-04-24 10:52:33.058 Error: Netatmo Thuis: Error data ... url: https://api.netatmo.com/api/homesdata?& ... rites=true&, response: {
2025-04-24 10:52:33.058 "error": {
2025-04-24 10:52:33.058 "code": 3,
2025-04-24 10:52:33.058 "message": "Access token expired"
2025-04-24 10:52:33.058 }
I Love Domoticz ! And the community around it :-)
- Domoticz version: 2024.7
today the Pull Request with the needed changes are merged.
Hopefully everybody can use the update.
Kind Regards
Kind Regards
Thanks for this PR merged.
We wait the new beta release for use your new feature
- Thuis
Yes, again thank you very much for all the hard work, making it going along with the future
I see that all beta build versions have been created today. Previously only the Windows version was up to date.
So latest Netatmo fix should be available!
OK for two hours.
After I have these errors :
2025-04-26 09:48:14.006 Error: Météo: cloud Dashboard for module [Buanderie] no longer updated (module possibly disconnected) since Sat Apr 26 05:58:58 2025
2025-04-26 09:48:14.006 Error: Météo: cloud Dashboard for module [cave] no longer updated (module possibly disconnected) since Sat Apr 26 05:58:32 2025
2025-04-26 09:48:14.007 Error: Météo: cloud Dashboard for module [Salon] no longer updated (module possibly disconnected) since Sat Apr 26 05:58:44 2025
2025-04-26 09:48:14.007 Error: Météo: cloud Dashboard for module [Météo abri] no longer updated (module possibly disconnected) since Sat Apr 26 05:55:05 2025
2025-04-26 09:48:14.007 Error: Météo: cloud Dashboard for module [Serre] no longer updated (module possibly disconnected) since Sat Apr 26 05:54:48 2025
2025-04-26 09:48:14.007 Error: Météo: cloud Dashboard for module [Chambre] no longer updated (module possibly disconnected) since Sat Apr 26 05:54:16 2025
2025-04-26 09:48:14.007 Error: Météo: cloud Dashboard for module [unknown06:00:00:04:**:**] no longer updated (module possibly disconnected) since Sat Apr 26 05:55:00 2025
2025-04-26 09:48:14.007 Error: Météo: cloud Dashboard for module [unknown05:00:00:07:**:**] no longer updated (module possibly disconnected) since Sat Apr 26 05:55:00 2025
I have try one stop/start of plugin and one reboot.
Always in error ...
Sorry but this is not again stable
OK for two hours.
Always in error ...
The error messages are not related to authentication but to requests on the weather modules. These queries are only made after authentication. So the authentication worked. It's a cloud problem, disconnection of the weather modules at the station, wifi interruption, etc.
If you look at the API documentation, it was the getstationsdata request that returned the errors. https://dev.netatmo.com/apidocumentatio ... ationsdata
@jcb2
this error is when the time from "module last seen" is older than 5 min. so we don't keep filling our sensor with old data.
What I find strange is the "Unknown" in the message, normally the code uses the names returned from the API.
Maybe if you enable Debug you can see more message and you can identify the problem.
What Types off devices do you Have ?
Buanderie, cave, Salon, Météo abri, Serre, Chambre, unknown06:00:00:04:**:**, unknown05:00:00:07:**:**
I updated domoticz about 4 hours ago to the newest release 16657. Up to now no interruptions anymore!
These are most likely additional weather modules (the small modules). This would mean three (or two) homes declared in your installation given the number of modules.
I assume you removed additional modules? The IDs of these modules are still attached to a main Netatmo weather module but not returned in the query since these modules are no longer present (disconnected as I explained above).
@jcb2 do you confirm?
I use the weather devices (2x bases + additionals modules, wind, rain)
I have deleted the app in Netatmo and after I have theses errors :
Now I wait a little bit and retry later.
2025-04-27 03:43:33.110 Status: Météo: Worker started...
2025-04-27 03:43:34.111 Status: Météo: Requesting new access_token
2025-04-27 03:43:34.286 Error: Météo: No access granted, forcing login again (Refresh tokens): invalid_grant
2025-04-27 03:43:34.286 Error: Météo: Refresh token false 0
2025-04-27 03:43:35.286 Status: Météo: Requesting new access_token
2025-04-27 03:43:35.443 Error: Météo: No access granted, forcing login again (Refresh tokens): invalid_grant
2025-04-27 03:43:35.444 Error: Météo: Refresh token false 0
2025-04-27 03:43:36.444 Status: Météo: Requesting new access_token
2025-04-27 03:43:36.615 Error: Météo: No access granted, forcing login again (Refresh tokens): invalid_grant
2025-04-27 03:43:36.616 Error: Météo: Refresh token false 0
2025-04-27 03:43:51.154 Status: Météo: Requesting new access_token
2025-04-27 03:43:51.419 Error: Météo: No access granted, forcing login again (Refresh tokens): invalid_grant
2025-04-27 03:43:51.419 Error: Météo: Refresh token false 0
2025-04-27 03:43:51.916 Status: Météo: Worker stopped...
Hello,cadkey wrote: ↑Saturday 26 April 2025 20:02 These are most likely additional weather modules (the small modules). This would mean three (or two) homes declared in your installation given the number of modules.
Yes it is exactly my situation
Sorry, into my new apps I have put a wrong IP number.
Now with the correct IP, I have one connection :
But I don't retrieve my devices into device list. (I have alowed the creation into parameters)
2025-04-27 04:34:26.630 Status: Météo: Station Data parsed Buanderie
2025-04-27 04:34:26.630 Status: Météo: Station Data parsed Météo abri
2025-04-27 04:34:26.630 Status: Météo: Weather 1
2025-04-27 04:34:26.630 Status: Météo: Get HomesData Details
2025-04-27 04:34:26.849 Status: Météo: Home id METEO updated.
2025-04-27 04:34:26.849 Status: Météo: Home id Buanderie et cave updated.
2025-04-27 04:34:26.850 Status: Météo: Home id Abri et serre updated.
2025-04-27 04:34:26.850 Status: Météo: Home Status Details, size (number of homes) is 3
2025-04-27 04:34:27.177 Status: Météo: Parse Persons
2025-04-27 04:34:27.177 Status: Météo: HomeStatus parsed
2025-04-27 04:34:27.325 Status: Météo: Parse Persons
2025-04-27 04:34:27.325 Status: Météo: HomeStatus parsed
2025-04-27 04:34:27.644 Status: Météo: Scenarios Data Recieved
2025-04-27 04:34:27.950 Status: Météo: Scenarios Data Recieved
2025-04-27 04:34:27.951 Status: Météo: Status 1
I think you can delete modules that are no longer installed.
You have to do it on https://home.netatmo.com or from the smartphone app.
Have you looked by the "Not Used" tab in the devices page?
Your log output seems OK to have devices.
But enabling Debug can give more information.
Kind Regards
OK the wifi was down for both station
Now I have all devices in not used at first time
MANY THANKS !
MANY THANKS !
