Goodafternoon,
I have a fresh Raspberry Pi 5 with new raspbian OS and latest 2024.7 Domoticz version. I used the domoticz.db backup from my older version to install all switches as they were.
Unfortunatly the timers to activate switches are not working anymore and I cannot get them to work by setting new ones, or use a blockly script. The event is simply even not logged. So the command doesn't reach the rfx. Manually everything works fine.
Any idea anyone?
Thanks for support!
Timers are not working Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2025.1
Re: Timers are not working
If you test timers do you leave a time delta of min 2 minutes? As that is needed for Domoticz to detect and trigger on timers.
The timers are also enabled instead of disabled?
PaulvH
Thanks for your reply Waltervl but yes delta > 2min, I cannot find a general "enable or disable" timer button but if you mean they are set to "active" that is a yes
Perhaps modify timers from a clean/private browser session as the timer API and related javascripts have been changed. And that could mix up things if you go from old to new Domoticz environment in the same browser session.
PaulvH
Solved, there was a new switch in this version at in the user setting area wich activated ownership for all the swithches. I only searched 2 days for it.
Thankns for support
Thankns for support
Then you also should not have seen those old switches in the tabs as these should be hidden for the user.
Users browsing this forum: eddieb and 1 guest
