Thanks walter, I managed to get something working with a python gpio2mqttAD script, still a work in progress but functional.
import paho.mqtt.client as mqtt
import RPi.GPIO as GPIO
import time
import json
# GPIO setup
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
# Define relay GPIO pins (BCM numbering)
RELAY_PINS = [17, 27, 22, 23] # Pin 23 = GPIO23 (Physical 16)
for pin in RELAY_PINS:
GPIO.setup(pin, GPIO.OUT)
GPIO.output(pin, GPIO.HIGH) # Inverted logic: HIGH = OFF (for active low relays)
# MQTT settings
MQTT_BROKER = "localhost" # Address of your MQTT broker (e.g., localhost or IP)
MQTT_PORT = 1883
MQTT_TOPIC_PREFIX = "domoticzSolar"
MQTT_DISCOVERY_PREFIX = "homeassistant/switch" # Home Assistant discovery style
# MQTT client setup
mqtt_client = mqtt.Client()
# Function to generate a unique ID based on GPIO pin
def get_unique_id(pin):
return f"gpio-relay-board-{pin}"
def on_connect(client, userdata, flags, rc):
print(f"Connected to MQTT broker with result code {rc}")
# Send discovery message for each relay (only once)
for i, pin in enumerate(RELAY_PINS, start=1):
relay_name = f"Relay {i}"
relay_id = f"relay{i}"
unique_id = get_unique_id(pin) # Static unique ID based on GPIO pin
# Prepare the MQTT discovery payload
discovery_payload = {
"name": relay_name,
"command_topic": f"{MQTT_TOPIC_PREFIX}/{relay_id}/set",
"state_topic": f"{MQTT_TOPIC_PREFIX}/{relay_id}/state",
"payload_on": "ON",
"payload_off": "OFF",
"state_on": "ON",
"state_off": "OFF",
"retain": True, # Ensure the configuration persists after restart
"unique_id": unique_id,
"device": {
"identifiers": [unique_id], # Device identifier as unique_id
"name": "GPIO Relay Board",
"model": "Pi GPIO",
"manufacturer": "YourName"
"device_class": "switch"
# Send the discovery message to the broker only once
discovery_topic = f"{MQTT_DISCOVERY_PREFIX}/gpio-relay-board-{pin}/config"
mqtt_client.publish(discovery_topic, json.dumps(discovery_payload), retain=True)
print(f"Published MQTT discovery message for {relay_name} with unique_id {unique_id}")
def on_message(client, userdata, msg):
topic_parts = msg.topic.split("/")
if len(topic_parts) < 3:
return
relay_name = topic_parts[1]
if relay_name.startswith("relay"):
try:
relay_num = int(relay_name[5:])
if 1 <= relay_num <= len(RELAY_PINS):
if msg.payload.decode() == "ON":
GPIO.output(RELAY_PINS[relay_num - 1], GPIO.LOW) # Inverted logic
mqtt_client.publish(f"{MQTT_TOPIC_PREFIX}/{relay_name}/state", "ON", retain=True)
elif msg.payload.decode() == "OFF":
GPIO.output(RELAY_PINS[relay_num - 1], GPIO.HIGH) # Inverted logic
mqtt_client.publish(f"{MQTT_TOPIC_PREFIX}/{relay_name}/state", "OFF", retain=True)
except ValueError:
print(f"Invalid relay number: {relay_name}")
def run_gpio_mqtt():
mqtt_client.on_connect = on_connect
mqtt_client.on_message = on_message
mqtt_client.connect(MQTT_BROKER, MQTT_PORT, 60)
mqtt_client.loop_start()
# Subscribe to relay control topics
for i in range(1, len(RELAY_PINS) + 1):
mqtt_client.subscribe(f"{MQTT_TOPIC_PREFIX}/relay{i}/set")
try:
while True:
time.sleep(1)
except KeyboardInterrupt:
print("Shutting down...")
GPIO.cleanup()
mqtt_client.disconnect()
if __name__ == "__main__":
run_gpio_mqtt()
I have to disable device creation as the domoticz creates new devices on each start, but it does work. Need to work on the auto discovery stuff.
