Sonoff SWV-BSP Usage & Experience?
kimhav
- Domoticz version: 2023.2
Looking at preparing for the summer with some automation for the garden and was wondering what the general experience are with the water valve Sonoff SWV-BSP; primary concern is how stable is it and if it does loose connectivity with the signee gateway will it then go int failsafe mode and close the valve and same question for low battery if it goes into failsafe mode and close the valve as well?
Filip
Re: Sonoff SWV-BSP Usage & Experience?
I recently bought 2 of them... I had the same thoughts... Currently I placed a switch on the power supply of the pump...
Goal is to be able to cut the pump if the valve would not close for one or other reason (communication problem, battery, ...).
I have - unfortunately - not an experience if problems would come up... We are only spring
F
F
jpaul
- Domoticz version: 2024.7
Is there a drop in water pressure with this device ? I've a no-name water valve but I can't use it because the pressure is too low when the device is plugged in.
