In the Domoticz settings, my home longitude/lattitude values are filled in.
How can i access these settings from LUA (so nót dzvents!)?
I would like to use these values to com[are with the values as returned from my car API, so I can see if the car is actually on the driveway or not!
access longitude/lttitude
- Domoticz version: 2024.7
Re: access longitude/lttitude
Perhaps check globalvariables table?
- habahabahaba
- Domoticz version: 2024.4
By using API request - /json.htm?type=settings ?
- jvdz
- Domoticz version: 4.107
Just an example script that uses the url provided by habahabahaba :
JSON = require 'JSON'
local url = "http://127.0.0.1:8080/json.htm?type=settings"
local handle=assert(io.popen('curl -s ' .. url))
local Dom_Data = handle:read('*all')
handle:close()
local decoded_response = JSON:decode(Dom_Data)
print(os.date("%X").." Latitude="..decoded_response["Location"]["Latitude"] .." Longitude="..decoded_response["Location"]["Longitude"] )
- Domoticz version: 2020.2
Thank you! That is exactly what I was looking for!!!
Makes me wonder, is there a list of data elements in that settings table?
Hans
- jvdz
Just use the link in a browser and you can see the complete Returned json and its content.
