I have been using my Dzevents for a while not, recently I updated my docker as i had to move to a new machine.
In mt script i always used:
http://xxxxxxxxxxx:8080/json.htm?type=g ... ange=month to get my P1 data for the month.
I just discovered that it is not working anymore trying to figure out so help appreciated:
page can’t be found
No webpage was found for the web address: http://xxxxxxxxxxxx:8080/json.htm?type= ... ange=month
HTTP ERROR 404
Thanks,
Hemant
Dzevent issue after updating docker image
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: Dzevent issue after updating docker image
For docker environments you have to add the internal IP of the docker container to the Domoticz trusted sites in security settings.
My docker is hosted and my subnet is added as trusted. I can access the http port 80 but the jason api does not work.
You have to login into the docker. Ontainer and find out the internal IP in that container as dzvents is calling the API from within the container. Also switch on Allow basic auth on http.
In the Domoticz log you probably also see a session from that IP being denied.
Thanks will try, is this something new, as i dis not change any settings just pulled new stable image.
Hemant
Hemant
New for 2023 version see wiki https://wiki.domoticz.com/Security
Double checked, Allow basic Auth over plain was already green (enabled)
in trusted network I have my whole subnet
so accessing plain http://domoticz-ip:8080 is no issues i can control and do everything
problem comes when i try
I get page not found error 404.
My docker is hosted that mean IP of host is same as in docker i check using:
docker inspect \
--format '{{ .NetworkSettings.IPAddress }}' domoticz
No IP is rerturned as it's hosted.
this is what i use in my script:
Cheers,
Hemant
http://domoticz-ip:8080/json.htm?type=graph&sensor=counter&idx=64&range=month
docker inspect \
local function triggerJSON(id, period, delay)
local delay = delay or 0
local URLString = "http://domoticz-ip:8080/json.htm?type=graph&sensor=counter&range=" ..
period .. "&idx=" .. id
dz.openURL({ url = URLString,
method = "GET",
callback = httpResponses .. "_" .. period}).afterSec(delay)
Cheers,
Hemant
OK
So in 2023.2 these API calls have changed:
See also wiki https://wiki.domoticz.com/Domoticz_API/ ... Gas,_Water
/json.htm?type=graph will be /json.htm?type=command¶m=graph
