Z4D plugin - stuck to 7.1.018
pipiche
Post by pipiche »
We have found an issue on 7.1.018 which prevent you to upgrade to any later version.
You need to do the update manualy by doing from the Z4D plugin directory
git pull
sudo python3 -m pip install -r requirements.txt --upgrade
If you have access right issue, this is most likely because domoticz is running root and some files belongs now to root. You can use the
sudo
command
