After moving from buster to bookworm on a Pi2 using GPIO intensively, I discovered that the sysfs method is not working anymore even if sysfs option is still available in domoticz latest version.
So my question is what is the recommanded solution to use GPIO in domoticz/bookworm ?
Best regards
Best solution for GPIO
- Domoticz version: 2024.7
Re: Best solution for GPIO
On newer RPI OS's the GPIO PIN number range has changed. So Sysfs should still work but you need different pin numbers.
See also https://github.com/domoticz/domoticz/issues/6040
Alternatively use IO devices not directly connected to the RPi but with for example ESP devices with ESPHome.
