i had a power outage on my synology yesterday.
everything came back only domoticz was logging a lot of dzvents errors about things taking to long.
It turned out that synology had started a disc scrubbing actions which obviously made my complete nas very slow, so slow that domoticz is getting into trouble.
now my question, can i disable
EventSystem (Lua/Blockly/Scripts):
and
dzVents:
so the system does not use it so i can start the scrubbing action again without domoticz logging errors
after that i want to turn eventsystem and dzvents back on but i do not know if this will still keep my current dzvents scripts or will it delete those once i disable things
thanks
can i disable scripts and dzvents without loosing my scripts
- madpatrick
- Domoticz version: 2025.1
Re: can i disable scripts and dzvents without loosing my scripts
There is a on/off switch the scripts UI.
This enables of disables the script. It will get lost or break anything
Or you can handle it in the script
https://wiki.domoticz.com/DzVents:_next ... (optional)
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
- Domoticz version: 2024.7
I just tried it on my test system. And as expected no scripts will be deleted if you disable eventsystem and dzvents.
To be sure you can make a database backup through menu setup-settings.
You can also just stop Domoticz temporary.
- Domoticz version: 2022.2
thanks for your help guys.
they idea is to disable it, do the scrubbing thing and enable it again.
i have auto backup enabled so i can fall back on older backups
