Script not working as expected...
HennyN
Domoticz version: 2024.7
Post by HennyN »
Hello HELP :? :roll:
What is wrong with this script??????
        on = { timer = { 'every 2 minutes' }},
        execute = function(domoticz, device, timer)
        local vandaagKwh      = domoticz.devices('Power').counterToday
        local vandaagM3Gas    = domoticz.devices('Gas').counterToday
        local StroomKosten  = domoticz.devices('StroomKosten')
        local GasKosten     = domoticz.devices('GasKosten')
        local TotaalKosten  = domoticz.devices('EnergieKosten')
        local startDateCoolBlue = '2023-10-18'
        local endDateCoolBlue = '2024-10-18'
        local currentDate = domoticz.time.rawDate
        local currentTime = domoticz.time.rawTime
            local gasM3Prijs = 0.1356156 -- Coolblue
            local kwhPrijs = 0.313136 -- Normaal tarief CoolBlue
            if (currentTime == 'between 20:00:00 and 07:00:00') or (domoticz.day == 'Saturday') or (domoticz.day == 'Sunday') then
                local kwhPrijs = 0.294744 -- Daltarief CoolBlue
    	-- Vaste kosten in Euro's per dag (zoals vastrecht) CoolBlue
        local kwhPrijsVast = 0.949003
    	local gasM3PrijsVast = 0.657998
    	-- Kosten berekenen
    	local KwhKosten = tonumber(domoticz.utils.round( (kwhPrijs * vandaagKwh) + kwhPrijsVast,2))
    	local GasM3Kosten = tonumber(domoticz.utils.round( (gasM3Prijs * vandaagM3Gas) + gasM3PrijsVast,2))
    	local KostenTotaal = KwhKosten + GasM3Kosten
        print ("===============================================================")
        print ("Dit is de kilowattuurprijs die in de berekening wordt gebruikt.")
        print (kwhPrijs)
        print (gasM3Prijs)
        print (currentTime)
        print (currentDate)
        local KwhKosten = tonumber(domoticz.utils.round( kwhPrijs * vandaagKwh,2))
        local GasM3Kosten = tonumber(domoticz.utils.round( gasM3Prijs * vandaagM3Gas,2))
        -- Kosten updaten
        StroomKosten.updateCustomSensor(KwhKosten)
        GasKosten.updateCustomSensor(GasM3Kosten)
        TotaalKosten.updateCustomSensor(KostenTotaal)
The result is always:
2025-02-17 22:58:00.386 dzVents: ------ Start internal script: Test:, trigger: "every 2 minutes"
2025-02-17 22:58:00.402 dzVents: ===============================================================
2025-02-17 22:58:00.402 dzVents: Dit is de kilowattuurprijs die in de berekening wordt gebruikt.
2025-02-17 22:58:00.402 dzVents: 0.313136
2025-02-17 22:58:00.402 dzVents: 0.1356156
2025-02-17 22:58:00.402 dzVents: 22:58:00
2025-02-17 22:58:00.402 dzVents: 2025-02-17
2025-02-17 22:58:00.403 dzVents: ===============================================================
2025-02-17 22:58:00.403 dzVents: ------ Finished Test
Between 20:00 and 07:00 the kwhPrijs should be 0.294744 and not 0.313136
So something is wrong in this script..... But I cann't find it. I don't see it. :? :roll:
Help is much appreciated
Regards, Henny
HvdW
Domoticz version: 2023.2
Re: Script not working as expected...
Post by HvdW »
To start with the first expression in the domoticz execute part could be
domoticz.devices('Power').dump()
It will show you the complete output in the log.
You will see that there are different counters for T1 (low) and T2 (high) so the section of evening and weekends is no longer necessary.
The smart meter delivers everything automagically.
Think about using a text sensor to display your data instead of having 3 different display sensors.
I alles AI to have a look at your script and this was the result
    active = true,
        if (currentTime >= '20:00:00' and currentTime < '07:00:00') or (domoticz.day == 'Saturday') or (domoticz.day == 'Sunday') then
        -- Kosten berekenen
        local KwhKosten = tonumber(domoticz.utils.round((kwhPrijs * vandaagKwh) + kwhPrijsVast, 2))
        local GasM3Kosten = tonumber(domoticz.utils.round((gasM3Prijs * vandaagM3Gas) + gasM3PrijsVast, 2))
        print (kwhPrijs)
        print (gasM3Prijs)
        print (currentTime)
        print (currentDate)
        -- Kosten updaten
When you declare a local variable inside an if else statement lua wont be able to handle it outside that statement.
Bugs bug me.
HennyN
Post by HennyN »
Oké, thanks.
I don't quite understand the inpact of your last sentence.
I found the script here:
https://ehoco.nl/stroom-gas-en-waterkos ... -domoticz/
and here is something similar.
https://krijnermerins.nl/domoticz/dagel ... -domoticz/
From the responses, I understand that it works, but so it doesn't with me. Possibly something has changed the script syntax of Domoticz in the meantime
I'm going to have another look at what other data comes out of the smart meter.
Regards, Henny
HennyN
Post by HennyN »
@HvdW
Your AI generated script doesn't work neither.
Or the script is not right, or I'm doing something wrong. :? :roll:
Regards, Henny
HvdW
Post by HvdW »
I made this for you.
The only thing you have to do is create a new TexSensor.
In this script it is named 'YourTextSensor'.
Give it any name you like but don't forget to adapt it in the script.
-- Definieer de prijzen en vaste lasten
local kwhPrijsT1 = 0.294744
local kwhPrijsT2 = 0.313136
local kwhPrijsVast = 0.949003 -- vaste lasten stroom per dag
local gasM3PrijsVast = 0.657998 -- vaste lasten gas per dag
-- Helper function
local function spaces(count)
    return string.rep("&nbsp;", count)
        timer = {
            'every 1 minutes',
            'at 00:00' -- Reset om middernacht
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = "----- Energie kosten berekening -----"
    data = {
        -- Variabelen om vorige waarden en cumulatief verbruik op te slaan
        previousTotalUsageT1 = { initial = nil },
        previousTotalUsageT2 = { initial = nil },
        stroomVandaagT1 = { initial = 0 },
        stroomVandaagT2 = { initial = 0 },
    execute = function(domoticz, trigger)
        -- Haal de devices op
        local powerDevice = domoticz.devices('Power')
        local gasDevice = domoticz.devices('Gas')
        if trigger.isTimer and trigger.triggerInfo == 'at 00:00' then
            -- Reset waarden om middernacht
            domoticz.data.stroomVandaagT1 = 0
            domoticz.data.stroomVandaagT2 = 0
            domoticz.data.previousTotalUsageT1 = powerDevice.rawData[1]
            domoticz.data.previousTotalUsageT2 = powerDevice.rawData[2]
            domoticz.log("Waarden zijn gereset voor een nieuwe dag.", domoticz.LOG_INFO)
            -- Haal de huidige waarden op
            local totalUsageT1 = powerDevice.rawData[1] -- totalUsage T1 in Watt
            local totalUsageT2 = powerDevice.rawData[2] -- totalUsage T2 in Watt
            local gasVandaag = gasDevice.counterToday -- gasverbruik vandaag
            -- Bereken het stroomverbruik sinds de laatste meting (T1 en T2) en converteer van Watt naar kWh
            if domoticz.data.previousTotalUsageT1 ~= nil and domoticz.data.previousTotalUsageT2 ~= nil then
                local diffT1 = totalUsageT1 - domoticz.data.previousTotalUsageT1
                local diffT2 = totalUsageT2 - domoticz.data.previousTotalUsageT2
                if diffT1 >= 0 then  -- Voorkom negatieve waarden (bijv. bij meterreset)
                    domoticz.data.stroomVandaagT1 = domoticz.data.stroomVandaagT1 + (diffT1 / 1000) -- Converteer Watt naar kWh
                    domoticz.log("Negatieve T1 waarde gedetecteerd, mogelijk meterreset", domoticz.LOG_WARNING)
                if diffT2 >= 0 then  -- Voorkom negatieve waarden
                    domoticz.data.stroomVandaagT2 = domoticz.data.stroomVandaagT2 + (diffT2 / 1000) -- Converteer Watt naar kWh
                    domoticz.log("Negatieve T2 waarde gedetecteerd, mogelijk meterreset", domoticz.LOG_WARNING)
                domoticz.log("Initialisatie van stroom meterstanden", domoticz.LOG_INFO)
            -- Sla de huidige waarden op voor de volgende iteratie
            domoticz.data.previousTotalUsageT1 = totalUsageT1
            domoticz.data.previousTotalUsageT2 = totalUsageT2
            -- Bereken de kosten voor vandaag
            local kostenStroomT1Vandaag = domoticz.data.stroomVandaagT1 * kwhPrijsT1
            local kostenStroomT2Vandaag = domoticz.data.stroomVandaagT2 * kwhPrijsT2
            local kostenStroomVandaag = kostenStroomT1Vandaag + kostenStroomT2Vandaag + kwhPrijsVast
            local kostenGasVandaag = (gasVandaag * gasM3Prijs) + gasM3PrijsVast
            local totaleKostenVandaag = kostenStroomVandaag + kostenGasVandaag
            -- Log de berekende waarden
            domoticz.log(string.format("totalUsageT1 (T1): %.3f Watt", totalUsageT1), domoticz.LOG_DEBUG)
            domoticz.log(string.format("totalUsageT2 (T2): %.3f Watt", totalUsageT2), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Stroom vandaag (T1): %.3f kWh", domoticz.data.stroomVandaagT1), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Stroom vandaag (T2): %.3f kWh", domoticz.data.stroomVandaagT2), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Kosten Stroom T1 vandaag: %.3f €", kostenStroomT1Vandaag), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Kosten Stroom T2 vandaag: %.3f €", kostenStroomT2Vandaag), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Kosten Stroom vandaag: %.3f €", kostenStroomT1Vandaag + kostenStroomT2Vandaag), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Gas vandaag: %.3f m³", gasVandaag), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Kosten Gas vandaag: %.3f €", kostenGasVandaag), domoticz.LOG_DEBUG)
            domoticz.log(string.format("Totale kosten vandaag: %.3f €", totaleKostenVandaag), domoticz.LOG_DEBUG)
            -- Gebruik powerDevice.counterToday voor de totale stroom vandaag (dit is al in kWh)
            local totalStroomVandaag = powerDevice.counterToday
            -- Maak de tekst voor de sensor
            local tekst = string.format(
                "Gas vandaag: %.3f m³\n" ..
                "Stroom vandaag: %.3f kWh\n" ..
                "Stroom T1 vandaag: %.3f kWh\n" ..
                "Stroom T2 vandaag: %.3f kWh\n" ..
                "Vaste kosten Stroom: %.3f €\n" ..
                spaces(15) .. "Vaste kosten Gas: %.3f €\n" ..
                spaces(15) .. "Kosten T1 vandaag: %.3f €\n" ..
                spaces(15) .. "Kosten T2 vandaag: %.3f €\n" ..
                spaces(15) .. "Kosten Energie vandaag: %.3f €",
                gasVandaag,
                totalStroomVandaag,
                domoticz.data.stroomVandaagT1,
                domoticz.data.stroomVandaagT2,
                kwhPrijsVast,
                gasM3PrijsVast,
                kostenStroomT1Vandaag,
                kostenStroomT2Vandaag,
                totaleKostenVandaag
            -- Update de tekstsensor
            local textDevice = domoticz.devices('YourTextSensor') -- Zorg dat de naam exact overeenkomt!
            if textDevice then
                textDevice.updateText(tekst)
                domoticz.log("Fout: Tekstsensor 'YourTextSensor' niet gevonden!", domoticz.LOG_ERROR)
After installing it won't display the data you expect.
After the reset at 00:00 it will show what you expect at 00:01.
Bugs bug me.
HennyN
Post by HennyN »
@HvdW,
I see you are an expert in this matter. I will implement and test it tomorrow. I spent quite some time experimenting again this afternoon, but to no result.
Thanks for now and I'll let you know if it works and gives the result I'm hoping for.
That sensor I'll call ‘EnergieRekening’ I think.
I'm also going to see if I understand how that script is put together and works.
My current contract has no difference in prices, so high and low is the same. The previous one did have different tariffs. That was also the reason I started working on this script. And I found out that https://krijnermerins.nl/domoticz/dagel ... omoticz/'s script didn't work at all.
I wanted to calculate with my previous supplier's tariffs until 18 October 2024. And from that date with the new tariffs, so that I could compare the costs per year in real terms.
Thanks for your help
Regards Henny
HvdW
Post by HvdW »
Whatever you do, after saving your script, watch the log.
When your script executes, watch the log.
Bugs bug me.
HennyN
Post by HennyN »
@HvdW
This works excellent.
With this as a base, I can move on, and see what else I need, and customise it to my needs.
Great work.
Regards,
Henny
HennyN
Post by HennyN »
Problem solved :D
See viewtopic.php?t=43344
