I followed these instructions to create and uplod custom icons.
ZIP file generated, content look identical to what it should be in the instructions.
However when I select and upload nothing happens.
I used these instructions before and everything worked like explained in the wiki.
This time it doesn't and I cannot find the reason why.
There is nothing in the log.
Cannot upload Custom Icons
HvdW
- Domoticz version: 2023.2
Bugs bug me.
- psubiaco
Re: Cannot upload Custom Icons
Post the zip file here, or post the link to it, so we can check it!
Paolo
- psubiaco
Check the attached file :
you have to put in the same directory, for example
icons.txt
and zip those files into Volvo.zip to submit to Domoticz.
icons.txt
Paolo
Droll
- Domoticz version: 2024.7
You got all files, but "Domoticz.png" is empty, 0KB
3 out of 4 files is OK, just "missing" the small one..
The above file names are just an example..
Arne Kjetil
icons.txt
Arne Kjetil
HvdW
Mm..
I downloaded Ziggo.zip from the examples to make shure it isn't the file that is corrupt or something.
Nope, I can upload it, it doesn't give a warning and still nothing.
BTW Even tried it in a Domoticz install on Windows..... nothing.
There are other custom icons installed, so in the past installation has completed without a problem.
EDIT 15 minutes later
Surprise!
In my case the icons don't install on Domoticz running on Windows, the icons don't install on Domoticz running on RPI3+ on bookworm , the icons install smoothly on Domoticz running on RPI4 on bullseye.
Surprise!
Bugs bug me.
