Simple Script not working
TeamKleijn
Post by TeamKleijn »
Hello all,
I want to conditionally Switch off the printer and screens poweer supply when the below Computers are not responding at pings anymore and if the 'Printer en Schermen Lock' isn't switched on (Virtual switch). If the three conditions are true, the switch 'Printer en Schermen (Son85)' should be gone off.
 if (otherdevices['Computer_1'] == 'Off' and  otherdevices['Computer_2'] == 'Off' and otherdevices['Printer en Schermen Lock'] == 'Off') then
	commandArray['Printer en Schermen (Son85)'] = 'Off AFTER 5'
It doesn't work, why ???
Please Help
Rob
"Team Kleijn"
wim57
Re: Simple Script not working
Post by wim57 »
What is the trigger for your script?
You can use print statements for debugging, they show in the log.
HvdW
Domoticz version: 2023.2
Post by HvdW »
-- Logging function
function log(message)
  print(os.date("%Y-%m-%d %H:%M:%S") .. " - " .. message)
  log("All devices are off. Command to turn off 'Printer en Schermen (Son85)' after 5 minutes has been added.")
  if otherdevices['Computer_1'] ~= 'Off' then
    log("Computer_1 is not off.")
  if otherdevices['Computer_2'] ~= 'Off' then
    log("Computer_2 is not off.")
  if otherdevices['Printer en Schermen Lock'] ~= 'Off' then
    log("Printer en Schermen Lock is not off.")
Bugs bug me.
jannl
Domoticz version: 2022.2
Post by jannl »
I check the powerusage of the plug. If it is lower then the standby usage I switch it off.
When I switch it on, the computer is switched on because of a power resume setting in the bios, or I sent the magic WOL package. Depending on the computer.
But as wim asks, what triggers your script.
You can use print statements to check the status of the switches. And if it is a new switch, switch ut manually some times. It helped me in the past.
TeamKleijn
HvdW wrote: Sunday 09 February 2025 9:47
-- Logging function
I've installed this script into my Domoticz and after some little tweaks it works.
Thanks a lot HvdW for this information.
I'm happy it's working as i wished.
"Team Kleijn"
Rob
