error with Domoticz "Allow new zigbee devices to join "
PaulAmsterdam
- Domoticz version: latest
Unfortunately I am stuck with solving the problem with: "Allow new zigbee devices to join"
By using the Zigbee frontend I was able to add a device. I also see it in domoticz Zigbee2mqtt. But when I check the box for "Allow new zigbee devices to join" in domoticz I get this error message in the log.
2025-02-08 12:51:52.395 Error: zigbee2: Call to function 'onMessage' failed, exception details:
2025-02-08 12:51:52.450 Error: zigbee2: Traceback (most recent call last):
2025-02-08 12:51:52.450 Error: zigbee2: File "/home/pi/domoticz/plugins/zigbee2mqtt/plugin.py", line 299, in onMessage
2025-02-08 12:51:52.450 Error: zigbee2: _plugin.onMessage(Connection, Data)
2025-02-08 12:51:52.450 Error: zigbee2: File "/home/pi/domoticz/plugins/zigbee2mqtt/plugin.py", line 137, in onMessage
2025-02-08 12:51:52.450 Error: zigbee2: self.mqttClient.onMessage(Connection, Data)
2025-02-08 12:51:52.450 Error: zigbee2: File "/home/pi/domoticz/plugins/zigbee2mqtt/mqtt.py", line 167, in onMessage
2025-02-08 12:51:52.450 Error: zigbee2: self.on_mqtt_message_cb(topic, message)
2025-02-08 12:51:52.450 Error: zigbee2: File "/home/pi/domoticz/plugins/zigbee2mqtt/plugin.py", line 155, in onMQTTPublish
2025-02-08 12:51:52.450 Error: zigbee2: self.api.handle_mqtt_message(topic, message)
2025-02-08 12:51:52.450 Error: zigbee2: File "/home/pi/domoticz/plugins/zigbee2mqtt/api/api.py", line 36, in handle_mqtt_message
2025-02-08 12:51:52.450 Error: zigbee2: command.handle_mqtt_message(topic, message)
2025-02-08 12:51:52.450 Error: zigbee2: File "/home/pi/domoticz/plugins/zigbee2mqtt/api/bridge.py", line 18, in handle_mqtt_message
2025-02-08 12:51:52.450 Error: zigbee2: self.send_response(message['data']['value'])
2025-02-08 12:51:52.450 Error: zigbee2: ~~~~~~~~~~~~~~~^^^^^^^^^
2025-02-08 12:51:52.450 Error: zigbee2: KeyError: 'value'
Pairing zigbee in Domoticz doesn't work either.
I reinstalled everything and is uptodate..
Does anyone know what the solution is for this problem or what I'm doing wrong?
I'm using a Raspberry PI5.
- Domoticz version: 2025.1
Re: error with Domoticz "Allow new zigbee devices to join "
Ah, you are using the old zigbee2mqtt plugin...
Better use the MQTT AD hardware gateway to connect with zigbee2mqtt.
See wiki, alternative 1 https://wiki.domoticz.com/Zigbee2MQTT
PaulAmsterdam
I followed the instructions of https://wiki.domoticz.com/Zigbee2MQTT But not in Docker.
You followed alternative 2 which is using a plugin that has not been maintained for 2 years now. Better remove the plugin and use the MQTT AD (AutoDiscover) method.PaulAmsterdam wrote: Saturday 08 February 2025 14:35 I followed the instructions of https://wiki.domoticz.com/Zigbee2MQTT But not in Docker.
FlyingDomotic
- Domoticz version: 2020.2
You may also use the same button in zigbee2mqtt (classical) UI, not related to Domoticz. It works here.
PaulAmsterdam
That’s right, that works for me too, but wants it to work in Domoticz as well.
On another Raspberry, which has been running for a while, and everything installed in the same way I do now, everything works within Domoticz.
FlyingDomotic
What versions of Domoticz and Z2M plug-in do you have?
PaulAmsterdam
Ik maak gebruik van een
Raspberry PI4,
OS: Bookworm
Domoticz versie: 2024.7,
Zigbeemqtt: 3.2.0-beta
Mosquitto: 2.0.11
Raspberry PI4,
OS: Bookworm
Mosquitto: 2.0.11
FlyingDomotic
What's the version of zigbee2mqtt Domoticz plug-in did you install (go to Domoticz "Configuration" > "Hardware", click on you zigbee2mqtt plugin, and read version in details under devices list) ?
PaulAmsterdam
Plugin version: Zigbee2MQTT Plugin (v. 3.2.0-beta)
FlyingDomotic
I just checked with same OS/Z2M/plugin version, and I don't saw this button.
Are you sure this is a zigbee2mqtt plug-in device?
To check, have a look to "setup" / "devices" tab, search for the button (enter part of its name in "search" at top/right of window) and look to the "hardware" column. Check that this is Z2M plug-in name, and not "MQTT autodiscovery" one.
PaulAmsterdam
Wederom bedankt voor je meedenken.
Ik heb alles opnieuw geïnstalleerd; Mosquitto, Zigbee2Mqtt. Beide niet in docker. Ook Domoticz opnieuw geïnstalleerd.
Nu niet de de plugin gebruikt maar nu "MQTT Auto Discovery Client Gateway with LAN interface" en de beschrijving in https://wiki.domoticz.com/Zigbee2MQTT gebruikt.
Alles, Zigbee, werkt nu zoals het zou moeten en kan nu weer verder.
Bedankt voor het meedenken!
Thanks for explaining in Dutch you have moved from zigbee2mqtt plugin to MQTT AD hardware gateway
PaulAmsterdam
Sorry, forgot to translate the text.
