Cannot get zigbee running Topic is solved
hjzwiers
I have MQTT, Zigbee and Zwave running in a single container. I get Zigbee started but I cant get it running. Can anyone help?
services:
eclipse-mosquitto:
container_name: myMosquitto
image: 'eclipse-mosquitto:latest'
restart: always
volumes:
- /home/hjz/docker/mosquitto/conf/mosquitto.conf:/mosquitto.conf
- /home/hjz/docker/mosquitto/data:/mosquitto/data
- /home/hjz/docker/mosquitto/log:/mosquitto/log
ports:
- '1883:1883'
- '9001:9001'
command: "mosquitto -c /mosquitto-no-auth.conf"
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
restart: unless-stopped
volumes:
- /home/hjz/docker/zigbee2mqtt/data:/app/data
- /home/hjz/docker/zigbee2mqtt/run/udev:/run/udev:ro
ports:
# Frontend port
- '8085:8085'
environment:
- TZ=Europe/Amsterdam
devices:
# Make sure this matched your adapter location
- /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment if you want logs time and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_t ... time_zones
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/serial/by-id/usb-0658_0200-if00:/dev/zwave'
volumes:
- /home/hjz/docker/zwjs/store:/usr/src/app/store
ports:
- '8091:8091' # port for web interface
- '3001:3001' # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
And my config file
version: 4
homeassistant: true
permit_join: true
frontend:
enabled: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.2.71:1883
serial:
port: /dev/ttyUSB0
#port: /dev/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0
#adapter: zstack
advanced:
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
device_options:
legacy: false
hjz@debian:~/docker$ docker compose up -d
[+] Running 3/0
✔ Container myMosquitto Running 0.0s
✔ Container zwave-js-ui Running 0.0s
✔ Container zigbee2mqtt Started
services:
eclipse-mosquitto:
restart: always
volumes:
ports:
- '1883:1883'
- '9001:9001'
zigbee2mqtt:
volumes:
ports:
# Frontend port
- '8085:8085'
environment:
devices:
zwave-js-ui:
restart: always
tty: true
stop_signal: SIGINT
environment:
networks:
- zwave
devices:
volumes:
ports:
networks:
zwave:
volumes:
zwave-config:
And my config file
version: 4
homeassistant: true
permit_join: true
frontend:
enabled: true
mqtt:
serial:
port: /dev/ttyUSB0
#adapter: zstack
advanced:
legacy_api: false
device_options:
legacy: false
[+] Running 3/0
hjzwiers
Re: Cannot get zigbee running
I needed to put the config file in "ember" mode with the Sonoff stick, no extra result, the MQTT file is empty
version: 4
homeassistant: false
permit_join: true
frontend:
enabled: true
mqtt:
serial:
# port: /dev/ttyUSB0
adapter: ember
version: 4
permit_join: true
frontend:
enabled: true
mqtt:
serial:
adapter: ember
- Domoticz version: 2025.1
What does the zigbee2mqtt log file say?
hjzwiers
[2025-02-03 20:04:45] info: z2m: Logging to console, file (filename: log.log)
[2025-02-03 20:04:45] info: z2m: Starting Zigbee2MQTT version 2.1.0 (commit #5e9d53f0aa94c947837dbb8252b1c70ff3bc08a2)
[2025-02-03 20:04:45] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-03 20:04:45] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-03 20:04:45] error: z2m: Error while starting zigbee-herdsman
[2025-02-03 20:04:45] error: z2m: Failed to start zigbee-herdsman
[2025-02-03 20:04:45] error: z2m: Check https://www.zigbee2mqtt.io/guide/instal ... ntime.html for possible solutions
[2025-02-03 20:04:45] error: z2m: Exiting...
[2025-02-03 20:04:45] error: z2m: Error: Error: No such file or directory, cannot open /dev/ttyUSB0
hjzwiers
I changed the usb port to the front and the ID doesn't change ..........
Check the docker instructions for zigbee2mqtt
https://www.zigbee2mqtt.io/guide/instal ... ocker.html
Add /dev/ttyUSB0 to the zigbee2mqtt docker container device setting.
device=/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0:/dev/ttyUSB0Domoticz running on Udoo X86 (on Ubuntu)
hjzwiers
I checked and it matched, I ran the code with the :/dev/ttyUSB0 extension already, failed.
I also added quotes, no improvement
jannl
- Domoticz version: 2025.5.x
At first, you do not have a single container configured, but several. You just have 1 docker compose file.
The usb (I also use persistent USB (see the wiki and/or forum)) line in my docker-compose.yml file is:
I am missing the colon (:) in your file, but I am not sure if that actually is needed
devices:
- /dev/ttyACM-NewZigbee:/dev/ttyACM-NewZigbee
Currently with newer OS the /dev/serial/by-id/ way is the best way. No need to make a USB device persistent the old way. Also indicated in the Wiki for some time now.jannl wrote: Tuesday 04 February 2025 7:45 At first, you do not have a single container configured, but several. You just have 1 docker compose file.
The usb (I also use persistent USB (see the wiki and/or forum)) line in my docker-compose.yml file is:I am missing the colon (:) in your file, but I am not sure if that actually is neededCode: Select all
devices: - /dev/ttyACM-NewZigbee:/dev/ttyACM-NewZigbee
Kedi
If you put more that 1 service in 1 compose file, I always put some healthchecks and depends_on in those files.
You can have race conditions for starting up the different services.
Beter is to have separate compose files for each service, than you have at first manual control about the startup order.
hjzwiers
I did all the checks:
version: 4
permit_join: true
frontend:
enabled: true
mqtt:
serial:
adapter: zstack
advanced:
log_level: info
zigbee2mqtt:
volumes:
ports:
# Frontend port
- '8085:8085'
environment:
devices:
- '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0:/dev/ttyUSB0'
All I get now is that the docker is started, and also no logging anymore.... This cannot be so complex.
version: 4
permit_join: true
frontend:
enabled: true
mqtt:
serial:
adapter: zstack
advanced:
log_level: info
zigbee2mqtt:
volumes:
ports:
# Frontend port
- '8085:8085'
environment:
devices:
jannl
The upper part is the zigbee2mqtt configuration yaml?
Shouldn;t the port be /dev/ttyUSB0 as set in de sigbee2mqtt container settings?
FlyingDomotic
- Domoticz version: 2020.2
It seems that port is not the right one. Try with:
port: '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0:/dev/ttyUSB0'
jannl
The port in the configuration.yaml should be (based on the setting in the docker-compose.yml)
serial:
port: /dev/ttyUSB0
hjzwiers
[2025-02-04 16:04:11] debug: z2m: Removing old log directory '/app/data/log/2025-02-04.15-54-00'
[2025-02-04 16:04:11] info: z2m: Logging to console, file (filename: log.log)
[2025-02-04 16:04:11] debug: z2m: Can't load state from file /app/data/state.json (doesn't exist)
[2025-02-04 16:04:11] info: z2m: Starting Zigbee2MQTT version 2.1.0 (commit #5e9d53f0aa94c947837dbb8252b1c70ff3bc08a2)
[2025-02-04 16:04:11] debug: z2m: sd-notify loaded
[2025-02-04 16:04:11] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-04 16:04:11] debug: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":6754,\"extendedPanID\":[221,221,221,221,221,221,221,221],\"channelList\":[11],\"networkKey\":\"HIDDEN\"}>
[2025-02-04 16:04:11] debug: zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyACM0"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyU>
[2025-02-04 16:04:11] debug: zh:adapter:discovery: Unable to match USB adapter: zstack | /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0
[2025-02-04 16:04:11] debug: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channel>
[2025-02-04 16:04:11] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0","baudRate":115200>
[2025-02-04 16:04:11] error: z2m: Error while starting zigbee-herdsman
[2025-02-04 16:04:11] error: z2m: Failed to start zigbee-herdsman
[2025-02-04 16:04:11] error: z2m: Check https://www.zigbee2mqtt.io/guide/instal ... ntime.html for possible solutions
[2025-02-04 16:04:11] error: z2m: Exiting...
[2025-02-04 16:04:11] error: z2m: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b
It seems it cannot find the adapter, but it is exactly as written, what to do? I tried to change to port to /dev/ttyUSB0, no result
jannl
This path: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f87384e6086bef1181b697adc169b110-if00-port0 is most likely not reachable from with the docker container.
Try my comments.
Try my comments.
hjzwiers
I found further documentation and with the help from Walter and Jannl I got it going.
Only I cannot connect anything, small detail. Is there any way you can the the broadcasting of the transmitter?
Check the zigbee2mqtt manual https://www.zigbee2mqtt.io/guide/usage/ ... vices.html
jannl
And check http://<your-ip>:8085, where 8085 is your frontend port
hjzwiers
It is working, still waiting for clients, sent back the sonoff 260 plugs, tomorrow I will get new ones
