2024.7 stops working every few days
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.3
Re: 2024.7 stops working every few days
Update: after removing the Reolink plugin Domoticz was running without problems for some months. In december 2024 i installed the Reolink plugin again, after some weeks Domoticz starting craching again. After removing the Reolink plugin again Domoticz seems to be stable again. If Domoticz was not responding, i only had to restart the Domoticz server, not reboot the Rasberry.
- Domoticz version: 2024.7
I found the root cause: weak WiFi signal strength causing communication difficulties for some Daikin units...Syndomo wrote: ↑Sunday 02 February 2025 0:56 Follow-up: I seem to have got the situation back under control by setting the Daikin LAN/HTTP polling interval back to 300 seconds instead of 20 seconds for all units.
HOWEVER
- in Domoticz 2024.4 it worked well with the short polling interval of 20 seconds
- in Domoticz 2024.7 the situation got unstable...
No idea why this didn't occur with 2024.4 as my WiFi wasn't changed.
Raspberry Pi 4 4GB - Bookworm - Domoticz v2024.7
