ASR2-RF / SSR302 2 Channel Receiver Config?
kaivalagi
Post by kaivalagi »
I can't seem to find any info on the Secure SSR302 / Thermoplus ASR2-RF 2 channel receiver, either in these forums or in the open z-wave config files
Has anyone got one of these working in their setup? How hard is it to setup a config xml file for these? Is it do-able?
To better understand I tried to make some sense of the HRT4 ASR-ZW single channel receiver config values versus the details found here but I can't make real sense of it to understand what I'd need to do to get the 2 channel receiver (detailed here) up and working with a new config file?
I understand Vera users have this device working so it must be do-able but some help would be appreciated as I am at a bit of a loss!
edit: Am I over thinking it? Does it just need an entry in the manufacturer_specific.xml as follows and the device will work out the box?:
<Manufacturer id="0059" name="Horstmann">
		<Product type="0003" id="0002" name="ASR2-RF Thermostat Receiver"/>
I have yet to purchase the device as I want to be sure it will work! Surely someone has it working in their setup?
kaivalagi
Re: ASR2-RF / SSR302 2 Channel Receiver Config?
Post by kaivalagi »
I've obviously made the wrong assumption that an entry is required in the OZW config files for a device to be workable, another thing learnt lol, this time from the OZW mailing list :)
Fingers crossed I get it setup just fine once I get it delivered, ordering it Monday along with all the other bits I need (USB stick, TRVs, Sensors)
Would still be good to know if any of you have used this device before? Not a single post on it suggests not many are doing heating control in Domoticz?
Vintage_Stu
Post by Vintage_Stu »
Hi Kalvalagi, did you have any luck with this?
kaivalagi
Post by kaivalagi »
I decided to hold off on getting the bits and give it more thought and save up some more first too. There's zwave plus now present, evohome maturing and I need to look at zigbee too...
You pondering on getting a receiver?
Vintage_Stu
I picked up the SSR302 and an SCS317 at a really good price, so I installed it in place of an older non-zwave wireless stat and boiler control. It was no problem getting them talking to each other but so far I haven't added it to my fledgling Zwave network (had a go yesterday, ended up pretty much destroying my config!)
I took the plunge with ZWave as I figured it seemed to be the most mature of the technologies available, plus for my modest 2 bed terrace it should easily handle anything I can throw at it (plans are to upgrade the home cinema in the lounge with controllers for blinds, screen masking etc)
fabrice
Domoticz version: 2432
Post by fabrice »
Did you manage to have the SSR302 and Domoticz talk to each other?
I'm tempted by this device but I've the feeling I'll end up without central heating!
Also can you please confirm that it can control the hot water too?
Thank you
Fabrice
dawsmac
Post by dawsmac »
Would it be worth looking at this Again ? I have installed one and is show that I have 3 x Thermostat Mode 3 x Switch
is there any need for it own .xml ?
atharvai
Domoticz version: 3.5841
Post by atharvai »
Yup. I see 3 channels too. It seems that 1 & 2 are inter dependent. If I switch one the other switches in about 20s delay. Both of those seem to correspond to Zone 1. channel 3 seems to be Zone 2. This is the switches.
Having said that I'm not sure what Thermostat Mode means. I can't easily set or unset them from Utility page of Domoticz.
cyclops1982
Post by cyclops1982 »
Seeing the same here.
However, it shows up as "Horstmann Unknown: type=0003, id=0002" in domoticz. Can this be changed?
Then - i also don't get the status of the thermostat mode BACK from the device. So if i press the white button on the device, then i see it's on, but this status is not reflected in domoticz.
Does this simply have to do with a config file in openzwave? Or a fix there?
If so, how do i move forward on this?
Users browsing this forum: Gianluca and 1 guest
