Problems with installing Sonoff ZigBee 3.0 USB-Dongle Plus-E
jack100
I connected an Sonoff ZigBee 3.0 USB-Dongle Plus-E ZBDongle-E at my raspberry pi with Domoticz.
Install the plugin zigbee2mqtt.
In Domoticz at the zigbee2mqtt plugin the next fields:
MQTT server address: localhost
Poort: 1883
Zigbee2Mqtt Topic: zigbee2mqtt
In the configuration.yaml the next:
base_topic: zigbee2mqtt
server: 'mqtt://localhost'
In the Zigbee2MQTT API Transport I see this:
2025-01-29 16:13:52 {"type": "response", "requestId": 5, "isError": false, "payload": []} Zigbee2MQTT
2025-01-29 16:13:52 {"type":"request","requestId":5,"command":"groups_get","params":{}} my username of domoticz (IP: 192.168.178.26)
2025-01-29 16:13:52 {"type": "response", "requestId": 4, "isError": false, "payload": []} Zigbee2MQTT
2025-01-29 16:13:52 {"type":"request","requestId":4,"command":"devices_get","params":{}} my username of domoticz (IP: 192.168.178.26)
In the log of Domoticz I see this:
2025-01-29 16:11:18.115 Error: Zigbee2MQTT: Failed to connect to: localhost:1883, Description: Connection refused
2025-01-29 16:11:18.115 Error: Zigbee2MQTT: Disconnected from MQTT Server: localhost:1883
2025-01-29 16:11:28.131 Error: Zigbee2MQTT: Failed to connect to: localhost:1883, Description: Connection refused
What going wrong here?
Who can help me?
Jack
Poort: 1883
Who can help me?
Jack
azonneveld
- Domoticz version: 2024.4
Re: Problems with installing Sonoff ZigBee 3.0 USB-Dongle Plus-E
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
- Domoticz version: 2025.1
If you start with Zigbee2MQTT it is better to directly move to the Domoticz MQTT AutoDiscover hardware gateway instead of the python plugin. I dont think there is a lot of maintenance on the plugin recently.
See wiki https://wiki.domoticz.com/Zigbee2MQTT
jack100
Fine!
The mosquitto errors in the log are solved.
I again installed mosquitto.
jack100
With the zigbee2mqtt plugin no zigbee sensors wil disappear. Pairing will not happen.
I will now try with the "MQTT Auto Discovery Client Gateway with LAN interface".
In the I copy:
homeassistant:
# Enable the integration (default: false)
enabled: true
What is the right configuration.yaml?
In domoticz in the "MQTT Auto Discovery Client Gateway with LAN interface".
Remote address: localhost
Poort: 1883
Gebruikersnaam: empty
Wachtwoord:empty
Automatische ontdekking voorvoegsel: homeassistant
Now how I get this screen under Alternative 1: Use Domoticz MQTT Autodiscover??
Enter the MQTT broker details real IP address (do not use localhost or 127.0.0.1) and port (eg 1883).
What IP address and port number then?
How can I control if domoticz see my sonoff dongle? Port number?
Jack
In the I copy:
homeassistant:
enabled: true
Poort: 1883
Wachtwoord:empty
Jack
Last edited by jack100 on Wednesday 29 January 2025 21:47, edited 1 time in total.
Zigbee pairing has nothing to do with mqtt or Domoticz!!
Check the zigbee2mqtt settings and options as that application is connecting with the zigbee2mqtt usb stick.
https://www.zigbee2mqtt.io/
If zigbee2mqtt user interface shows nodes/ devices but in Domoticz no devices then check MQTT if zigbee2mqtt is sending data.
jack100
I start with a fresh installation of zigbee2mqtt.
https://www.zigbee2mqtt.io/guide/instal ... installing
# Set up Node.js repository, install Node.js, pnpm and required dependencies
# NOTE 1: Older i386 hardware can work with [unofficial-builds.nodejs.org](https://unofficial-builds.nodejs.org/do ... e/v20.9.0/ e.g. Version 20.9.0 should work.
# NOTE 2: For Ubuntu see tip below
# NOTE 3: Curl might have to be installed first via apt update && apt install curl
sudo curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
sudo apt-get install -y nodejs git make g++ gcc libsystemd-dev
npm install -g pnpm
After copy/past and run in putty of "nmp install -g pnpm" i get errors. (o.a. access denied).
Will not accept: npm install -g pnpm
After "pnpm --version", -bash: pnpm: command not found.
After "node --version", I see V20.18.2
After "pnpm i --frozen-lockfile", -bash: pnpm: command not found.
Jack
npm install -g pnpm
Jack
Last edited by jack100 on Wednesday 29 January 2025 21:31, edited 1 time in total.
Alternative is the docker way of installing zigbee2mqtt.
jack100
No an another solution?
Is npm and pnpm both necessary?
And when it install seperately?
wim57
I think you need to use: sudo npm install -g pnpm
jack100
Wim, you are an angel!!
https://www.zigbee2mqtt.io/guide/instal ... linux.html
npm install -g pnpm
# Verify that the correct nodejs and pnpm version has been installed
node --version # Should output V18.x, V20.x, V22.X
pnpm --version # Should output 9.X
# Create a directory for zigbee2mqtt and set your user as owner of it
sudo mkdir /opt/zigbee2mqtt
sudo chown -R ${USER}: /opt/zigbee2mqtt
# Clone Zigbee2MQTT repository
git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt
# Install dependencies (as user "pi")
cd /opt/zigbee2mqtt
# Build Zigbee2MQTT
pnpm run build
No errors now!
Tomorrow the next step
Jack
npm install -g pnpm
cd /opt/zigbee2mqtt
# Build Zigbee2MQTT
pnpm run build
No errors now!
Jack
jack100
We continue
After:
cd /opt/zigbee2mqtt
pnpm start
I see in putty the next:
Starting Zigbee2MQTT without watchdog.
After several seconds:
Error: listen EADDRINUSE: address already in use :::8080
DELIFECYCLED Command failed with exit code 1. (in red text)
p1@raspberrypi: /opt/zigbee2mqtt $
which settings are not correct??
In domoticz I use: MQTT Auto Discovery Client Gateway with LAN interface
Poort: 1883
Add this in the configuration.yaml
# Optional: Home Assistant integration (MQTT discovery)
homeassistant:
enabled: true
Jack
We continue
After:
cd /opt/zigbee2mqtt
pnpm start
Poort: 1883
homeassistant:
enabled: true
Jack
wim57
You probably have set port 8080 for Domoticz web-interface as well as for Z2M frontend. So you have to change the Z2M frontend port in configuration.yaml.
jack100
which port number can I choose?
jack100
Zigbee2mqtt see my Sonoff Dongle.
When I type in putty: $ ls -l /dev/ttyUSB0
I see: crw-rw----1 root dialout 188, 0 Jan 30 16:52 /dev/ttyUSB0
When I type in putty: ls -l /dev/serial/by-id
I see: lrwxrwxrwx 1 root root 13 Jan 30 16:52 usb-ITead_Sonoff_Zigbee_3.0. and more
After:
cd /opt/zigbee2mqtt
pnpm start
I see some errors about the adapter.
-Configuration is not consistent with adapter state/backup!
-Please update configuration to prevent further issues.
-And more.
When in de configuration.yaml "homeassistant" change from false to true and save.
After reboot it change again in false.
Whats happens here?
Jack
After:
cd /opt/zigbee2mqtt
pnpm start
-And more.
Whats happens here?
Jack
Also check the zigbee2mqtt forum for the errors you see: https://github.com/Koenkk/zigbee2mqtt/discussions
jack100
For the Sonoff Dongle Plus-E I add the next in the configuration.yaml
serial:
adapter: ember # (is the right? Or zstack?)
port: /dev/ttyUSB0
After:
cd /opt/zigbee2mqtt
pnpm start
The following errors disappear:
-z2m Error while starting zigbee-herdsman
-z2m Failed to start zigbee-hersman
Jack
serial:
port: /dev/ttyUSB0
After:
cd /opt/zigbee2mqtt
pnpm start
Jack
azonneveld
Users browsing this forum: cmisip and 1 guest
